Showroom My new 3dof, 4motors, arduinoMéga + Sabertooth
Discussion in 'DIY Motion Simulator Projects' started by ericRacer, Nov 18, 2013.
  1. ericRacer
    Pilot
    Canada, Quebec
    942Coins
    Hi, first of all,
    I want to thank everyone who helped me and especially those who created X-sim, Simtool (my favorite) and plugins ..
    Here is some pictures of the frame :
    I didn't use a spring for the dead load , i transformed a jack into air cylinder.
  2. ericRacer
    Pilot
    Canada, Quebec
    942Coins
    the result of the air cylinder. It is adjustable with my air compressor close to the sim. And i can move it backward or forward for best balancing the dead load.
    For the sensor i used the hall effect (allegro A1301) . i follow this thread for building my own ;
    http://simhq.com/forum/ubbthreads.php/topics/3674791/DIY_Sealed_Minature_Hall_Pots_.html#Post3674791
    here is mine :
    DSC00206.JPG DSC00207.JPG DSC00208.JPG DSC00209.JPG DSC00214.JPG DSC00209.JPG
    it works very great but ......after built it , i realised that cost me almost the same price this one : 1560935-40.jpg
    around 20 dollars from digikey.
  3. prilad
    Dubna, Russia
    9,670Coins
    3DOF, DC motor, Arduino, 4DOF
    Hi, very interesting project! Have you any videos?
  4. ericRacer
    Pilot
    Canada, Quebec
    942Coins
    my first test with X-sim..
  5. ericRacer
    Pilot
    Canada, Quebec
    942Coins
    thanks....and yes
  6. ericRacer
    Pilot
    Canada, Quebec
    942Coins
    second test.....with wood frame
  7. ericRacer
    Pilot
    Canada, Quebec
    942Coins
    third test ...
    In those videos , i was using two arduino uno with x-sim , my sabertooth was settled in analogue mode with low-pass filter from arduino's pwm and the result was not as good as i was looking for.
    Recently (after this video), i replaced both arduinos uno against arduinoMéga 2560 because it has 3 mores serial port, with these comport i am able to use my Sabertooth in serial mode with better result.
    My last video will come soon.... with SimTool and my new code....
    • Like Like x 5
  8. eaorobbie
    20,506Coins
    Would have to totally agree a nice interestingly different build. Sweet.
  9. bsft
    Hello Eric, welcome. Nice build and hopefully we are more helpful than the "other" forum.
  10. ericRacer
    Pilot
    Canada, Quebec
    942Coins
  11. hooshang
    hooshang Active Member
    275Coins
    @ericRacer
    congratulation for the nice job and innovative pivot and also tidy assemble.
    iam also going to upgrade my sim board to Arduino Uno,what firmware do you used for
    your Arduino Eric?
    regards
    Hooshang
  12. ericRacer
    Pilot
    Canada, Quebec
    942Coins
    Hi Hooshang,
    thanks, :),
    I replaced Arduino Uno by Méga because it has 3 mores serial comport and it was easier for me to write my code for using Sabertooth in "Simplified Serial packetized " mode (i am not a programmer o_O)
    In those video i was using Uno with X-Sim and Xpid but the performance was not as good as i wanted. :sos
    then , i wrote my code (Xpid , inspiring me a lot ! :thumbs) and tried SimTool that i adopted ! It is wonderfull !
    Now the performance is really as good as i was looking for.
    here is my code and if someone has good idea to improve it >> don' be shy ! :grin
    Eric
  13. ericRacer
    Pilot
    Canada, Quebec
    942Coins
    Code:
    // pinning overview :
    //            PC6  1|    |28  PC5 (AI 5)
    //      (D 0) PD0  2|    |27  PC4 (AI 4)
    //      (D 1) PD1  3|    |26  PC3 (AI 3)
    //      (D 2) PD2  4|    |25  PC2 (AI 2)
    // PWM+ (D 3) PD3  5|    |24  PC1 (AI 1)
    //      (D 4) PD4  6|    |23  PC0 (AI 0)
    //            VCC  7|    |22  GND
    //            GND  8|    |21  AREF
    //            PB6  9|    |20  AVCC
    //            PB7 10|    |19  PB5 (D 13)
    // PWM+ (D 5) PD5 11|    |18  PB4 (D 12)
    // PWM+ (D 6) PD6 12|    |17  PB3 (D 11) PWM
    //      (D 7) PD7 13|    |16  PB2 (D 10) PWM
    //      (D 8) PB0 14|    |15  PB1 (D 9) PWM
    // Copyright (c) 2012 Dimension Engineering LLC
    // See license.txt for license details.        // We'll name the Sabertooth object ST.
    #include <SabertoothSimplified.h>
    SabertoothSimplified ST1(Serial3);    // RX (unused), TX on pin 14 (serial2)to S1 of M1,M2
    SabertoothSimplified ST2(Serial2);    // RX (unused), TX on pin 16 (serial2)to S1 of M3,M4
                                        // Connections to make:
                                        //  Arduino TX->1  ->  Sabertooth S1
                                        //  Arduino GND    ->  Sabertooth 0V
                                        //  Arduino VIN    ->  Sabertooth 5V (OPTIONAL, if you want the Sabertooth to power the Arduino)
                                  // If you want to use a pin other than TX->1, see the SoftwareSerial example.
    #if defined(ARDUINO) && ARDUINO >= 100
    #include "Arduino.h"
    #else
    #include "WProgram.h"
    #endif
    #define FASTADC  1                    //Hack to speed up the arduino analogue read function
    // defines for setting and clearing register bits
    #ifndef cbi
    #define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
    #endif
    #ifndef sbi
    #define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
    #endif
    double KP = 8.0;
    double KI = 6.0;
    double KD;
    double sampletime = .1;      // 1 mSec.
    //Define Variables we'll be connecting to
    double currentanalogue1 = A9;
    double currentanalogue2 = A8;
    double currentanalogue3 = A11;
    double currentanalogue4 = A10;
    double target1;
    double target2;
    double target3;
    double target4;
    int ledPin=13;          // for debugging
    int outMax = 127;
    int outMin = -126;
    double lastError_1, lastError_2, lastError_3, lastError_4;
    double error_1, error_2, error_3, error_4;
    double Output_1, Output_2, Output_3, Output_4;
    unsigned long lastTime;
    //Specify the links and initial tuning parameters PID
    int buffer            = 0;                    // Mémoire tampon pour les variables de comm.
    int disable;
    int buffercount        =-1;
    int commandbuffer[6];
    void setup() {
      Serial.begin(115200);                // Initialise la communication à 38400 bauds
      Serial2.begin(38400); // This is the baud rate you chose with the DIP switches. (dip SW 2, 4 et 5 => OFF)
      Serial3.begin(38400);
      pinMode(ledPin, OUTPUT);            // for debugging only
      disable=0;
    #if FASTADC
      // set analogue prescale to 16
      sbi(ADCSRA,ADPS2) ;
      cbi(ADCSRA,ADPS1) ;
      cbi(ADCSRA,ADPS0) ;
    #endif
    void FeedbackPotWorker()
      /*  convertion du pot 0-1023 en radian + calibration:
        motors(pot) :      Min  :  Max    :    Différence          degré -> radian
                1    :      123  :  884    :      761    :    761/3.14159(radian) = 242.2340
                2    :      175  :  824    :      649    :    649/3.14159(radian) = 206.5833
                3    :      174  :  842    :      668    :    668/3.14159(radian) = 212.6311
                4    :      338  :  700    :      362    :    362/3.14159(radian) = 115.2283
                la différence équivaut à 180°, donc 769/180° donnerait = 4.27 et égaliserait 1° mais ici le COS() doit être en radian donc
                769/3.14159(radian) = 244.78
      float currentanalog1 = (analogRead(A9)-123)/242.2340;
      float currentanalog2 = (analogRead(A8)-175)/206.5833;
      float currentanalog3 = (analogRead(A11)-174)/212.6311;
      float currentanalog4 = (analogRead(A10)-338)/115.2283;
      currentanalogue1 = (127*cos(currentanalog1))+127;        // conversion linéaire et transformation de 0 - 255 (127=milieu)
      currentanalogue2 = (127*cos(currentanalog2))+127;
      currentanalogue3 = (127*cos(currentanalog3))+127;
      currentanalogue4 = (127*cos(currentanalog4))+127;
      // pour 0-255 : (127*cos((float)A0/81.17))+127 -> degré en radian
      // pour 0-1023 : (512*cos((float)A0/325.9437))+512 -> degré en radian
      disable=0;
    void ParseCommand()
      if ( commandbuffer[0]=='R')                // "R" for data Receiving
        target1=commandbuffer[1];              // target must be between 0-255 (only 1 byte)
        target2=commandbuffer[2];
        target3=commandbuffer[3];
        target4=commandbuffer[4];
      if ( commandbuffer[0]=='P')                // P for PID => kp , ki , kd ans sampleTime
        KP=commandbuffer[1];              // target must be between 0-255 (only 1 byte)
        KI=commandbuffer[2];
        KD=commandbuffer[3];
        sampletime=commandbuffer[4];
    bool CheckChecksum()                  // Check for "E" as the packet end byte
        byte checksum = commandbuffer[5];
        if(checksum =='E'){return true;}
        return false;
    void SerialWorker()
      while(Serial.available())
        if(buffercount==-1)
          buffer = Serial.read();
          if(buffer != 'X'){
            buffercount=-1;
          else{
            buffercount=0;
        else
          commandbuffer[buffercount]=buffer;
          buffercount++;
          if(buffercount > 6)
            if (CheckChecksum()==true){ParseCommand();}
            buffercount=-1;
      disable=1;
    void CalculatePID()
      unsigned long now = millis();
      int timeChange = (now - lastTime);
      if(timeChange>=sampletime)
        error_1 = target1 - currentanalogue1;
        Output_1 = (KP * error_1) - (KI * lastError_1);
        if(Output_1 > outMax) Output_1 = outMax;
        else if(Output_1 < outMin) Output_1 = outMin;
        error_2 = target2 - currentanalogue2;
        Output_2 = (KP * error_2) - (KI * lastError_2);
        if(Output_2 > outMax) Output_2 = outMax;
        else if(Output_2 < outMin) Output_2 = outMin;
        error_3 = target3 - currentanalogue3;
        Output_3 = (KP * error_3) - (KI * lastError_3);
        if(Output_3 > outMax) Output_3 = outMax;
        else if(Output_3 < outMin) Output_3 = outMin;
        error_4 = target4 - currentanalogue4;
        Output_4 = (KP * error_4) - (KI * lastError_4);
        if(Output_4 > outMax) Output_4 = outMax;
        else if(Output_4 < outMin) Output_4 = outMin;
        /*Remember some variables for next time*/
        lastError_1 = error_1;
        lastError_2 = error_2;
        lastError_3 = error_3;
        lastError_4 = error_4;
        lastTime = now;
      disable=0;
    void Stop_Motors()
        ST1.motor(1, 0);                      // Tx is on Serial_2 pin 14  to S1 of sabertooth M1 & M2
        ST1.motor(2, 0);
        ST2.motor(1, 0);                      // Tx is on Serial_2 pin 16  to S1 of sabertooth M3 & M4
        ST2.motor(2, 0);
    disable=1;
    void SetCommand()
      ST1.motor(1, Output_1);                              // motor 1 , output pin connected on S1
      ST1.motor(2, Output_2);
      ST2.motor(1, Output_3);            // motor 3
      ST2.motor(2, Output_4);              // motor 4
    void loop()  {
      while (1==1)      //Important hack: Use this own real time loop code without arduino framework delays
        FeedbackPotWorker();
        SerialWorker();
        CalculatePID();
        if(disable==0)
          SetCommand();
            else
        Stop_Motors();
  14. bartez81
    bartez81 i like amps Gold Contributor
    Kraków
    - 22Coins
    2DOF, 3DOF, DC motor, AC motor, SCN6, Arduino, JRK, Motion platform
    Hi when i try to compile i get these error:
    sketch_dec18a:23: error: 'SabertoothSimplified' does not name a type
    sketch_dec18a:24: error: 'SabertoothSimplified' does not name a type
    sketch_dec18a.ino: In function 'void Stop_Motors()':
    sketch_dec18a:230: error: 'ST1' was not declared in this scope
    sketch_dec18a:232: error: 'ST2' was not declared in this scope
    sketch_dec18a.ino: In function 'void SetCommand()':
    sketch_dec18a:240: error: 'ST1' was not declared in this scope
    sketch_dec18a:242: error: 'ST2' was not declared in this scope
  15. yobuddy
    51,656Coins
  16. eaorobbie
    20,506Coins
    To me thats saying the sabertooth libary is not installed into the Ard IDE. This is needed to compile the code.
  17. bartez81
    Kraków
    - 22Coins
    u are right boss. :)
  18. ericRacer
    Pilot
    Canada, Quebec
    942Coins
    here is the library :
    http://www.dimensionengineering.com/info/arduino
    and you don't really need Arduino Mega, I tried with Duemilanove with the "SoftwareSerial" who is a library and that works very well too. :grin
    sorry for the wrong info but i am newbie and learning ! :confused:
    thanks
  19. ericRacer
    Pilot
    Canada, Quebec
    942Coins
    my last video, but sorry for the poor quality :( :
  20. eaorobbie
    20,506Coins
    Motion not bad considering its Ard run and 3DOF , going off track looks very scary, well done.
