value1
Codemasters F1 2013 plugin 2.0.0.1
SimTools plugin for Codemasters F1 2013
  1. value1
    14,270Coins
  2. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Guys, looks like roll is inverted, with a car in a left bank, virtual axis slider is all the way to the right...
  3. eaorobbie
    20,506Coins
    Nice catch yes you are correct.
  4. husam
    husam New Member
    323Coins
    2DOF, 3DOF, 4DOF
    I am still in phase of feeling dummy about what's happening here but I expected to use this plugin the reach the data using .net environment like C#, I got some compilation errors but I would know if already that possible.
  5. value1
    14,270Coins
    Hi @husam
    There's no need for C# to run a plugin with SimTools:
    Start the SimTools Plugin Updater, that you can find in the SimTools installation directory.
    Drag'n'drop the F12013_Plugin.zip (no need to unzip!!!) into the Updater window
    Close the updater.
    Start the GameManager
    Select the Entry F1 2013 and click on Patching.
    A Game Patching Path drawer slides out.
    Click on Edith path and follow the instructions (essentially: select the save-game path of F1 2013 like C:\Users\…yourname…\Documents\My Games\FormulaOne2013\hardwaresettings
    There should be a confirmation that the game was patched.
    Start GameEngine and the game and enjoy!
    (Assuming the axis and interface settings have already been done. Otherwise check the SimTools Quickstart Guide.)
  6. husam
    husam New Member
    323Coins
    2DOF, 3DOF, 4DOF
    Thank you Value for your explanation, I read the quick start and now I can understand what your plugin is for.
    Actually we are developing racing cars simulators by PLC and servo motors and need to manipulate the data coming from the game before converting them into pulses for the servo motors, I use C# to develop the software for data manipulation.
  7. boons4
    boons4 New Member
    157Coins
    Hi Guys... anyone manage to get this plugin and f1 2013 motion to work? its says not unavaliable for download the plugin i wonder why? I just chance upon this game and it is the BEST racing game fun i ever had beside Iracing.. Hope some one can make the plugin available. As i am using both xsim3 and sim tool i wonder are plugin interchangeable? thanks all.
  8. Historiker
    9,211Coins
  9. bsft
    Simtools and x-sim3 plugins are NOT interchangeable. Simtools has more plugins for more games and best of all...........they work.
  10. eaorobbie
    20,506Coins
    There is another option that you may use to achieve this , in the Interface Settings you can port the information coming out of simtools to a net port and have a udp listener read the port and do what you need it to do to run your simulator, or in turn most plc systems today have a usb port and can handle packized serial data comining to them,
    ? what plc do you intend to use or not willing to share that information, or if you dont intend to use simtools, forget the above.
  11. value1
    14,270Coins
  12. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    Hi @value1, I just tried the new update and added extra1 to my 4th axis, then tried it but it reacted really crazy, like before the race start it puts the simulator to one side while I not even drive away, and when I loose traction it not reacts at all...maybe something wrong with the update ?
    also another question, should I invert the roll or is it changed already ?
    anyway I don't want to sound un gratefull at all, I am just a total noob at sim building and aspecially the setting up on PC, so I thank you for all your work :thumbs
  13. value1
    14,270Coins
    Thank you @Al.Bundy for your feedback. I don't have F1 2013 so this was somewhat a shot in the dark.
    I have updated Codemasters F1 2013 plugin with a new update entry:
    Traction Loss corrected
    Read the rest of this update entry...
  14. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    Hey @value1, tested f1 2013 today and put my 4th axis to 100% on extra1 and woahh it works fabulous !!!! Really cool and feels just like real, thanks so much :cheers:thumbs
  15. rundmg
    rundmg Member
    Client Platform Engineer
    Pennsylvania - USA
    413Coins
    Not sure if this is the wrong play to post this if so im sorry, quick question is there a way to get this plugin to work with f1 2014 steam edition ?
  16. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    @rundmg, thats a good question, but unfortunate I cannot help you with it.
    It sure would be great to play f1 2014 with motion....the game is waiting here too!
    Maybe you could ask @value1 , he is the one who can make it possible with some magic ;)
  17. value1
    14,270Coins
    Please run the program and check the .exe name by pressing Ctrl-Alt-Del – Start Task Manager
    Right-click on F1 2014 and select Go To Process
    Read and report here the name you see highlighted (in the example below "iexplorer.exe")
    That's all.
  18. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    It says the following : F1_2014.exe *32
  19. value1
    14,270Coins
    @Al.Bundy: Please try this plugin and let me know if it worx.
    Thx
    T.
  20. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    @value1 Game manager says : F12014_Plugin.dll- is not a valid simtools plugin! .......:think
