Showroom project starts!
Discussion in 'DIY Motion Simulator Projects' started by K1FF, Dec 21, 2013.
  1. K1FF
    K1FF New Member
    723Coins
    SCN5
    Gday bsft !! thanks for that info!!! :) It is all interesting and looking into different types of rigs!! I have got the rig home for the moment to fit the seat and work out some more measurements!! I will get some more pics up soon !!!
  2. bsft
    Looks good, nifty idea of putting pedals on seat rails to adjust.
  3. ericRacer
    Pilot
    Canada, Quebec
    950Coins
    nice job and very fast job !
    good luck :thumbs
  4. K1FF
    K1FF New Member
    723Coins
    SCN5
    Little bit more done!! have to cut and lower where the steering wheel sits as its a bit high:rolleyes:
  5. bsft
    looks great!
  6. K1FF
    K1FF New Member
    723Coins
    SCN5
    Almost done!!! :grin And some pics!!! Its almost the same color as my car!! DSCN1523.JPG DSCN1524.JPG DSCN1526.JPG DSCN1528.JPG DSCN1532.JPG DSCN1535.JPG DSCN1536.JPG DSCN1537.JPG DSCN1531.JPG
  7. RaceRay
    Hamburg, Germany
    23,876Coins
    Please upload your images to the forum. (Drag and drop possible) photobucket says that bandwidth has been exceaded and your images are not shown currently:(
    Btw. I am talking about images in your first posts
  8. eaorobbie
    20,473Coins
    Oh red ones, and go fast, cool.
  9. K1FF
    K1FF New Member
    723Coins
    SCN5
  10. eaorobbie
    20,473Coins
    With more fine tuning of your motion the right would be a lot nicer, as in could not see much roll or sway or even surge on the video, but youtube frame rates don't help either.
    Nice clean looking project, do you have the details posted on how you hooked the simexperience kit to simtools, we have another user trying the same thing and not having much luck @patritti could use you help, thanks.
  11. K1FF
    K1FF New Member
    723Coins
    SCN5
    Gday eaorobbie!! thanks! it does move a lot more than it looks on the vid I am not using the simtools just yet (I WILL) am still using the the unnamed one Just to get it up and running!! in the simtools it was asking for SNC5 150 actuators ComPort settings :confused: And I wouldn't have a clue what or where to find them! Still Very Green at this side of stuff :(
  12. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    If he actually uses SimTools, I cannot say that from images, there are no separated RS USB adapters, but yet I could be mistaken.
  13. K1FF
    K1FF New Member
    723Coins
    SCN5
    Gday prodigy! the actuators plug into that black box at the back of the Sim then only one usb from the box to the pc if that is what you meant ?
  14. prodigy
    Croatia
    6,698Coins
    In the meantime I have seen in your post above that you don't use SimTools, that was interesting me, thanks for info.
    As far as I've read other topics and attempts of converting SimXperince SCN actuators, you would need to have two separated USB adapters for each actuator which you will plug into PC, you would need to cut SCN wires and make connectors for those USB adapters and change actuators ID numbers for both to have ID "0", there are some tools to change that, I think SimTools have that ability now, but I'm not 100% sure. You will not need to use SimXP black box anymore and SimCommander software.
    Please someone correct me about this if I am wrong.
    But if your SimXperience equipment is still under warranty, I wouldn't recommend to mess with it unless you are 100% sure that it will work with SimTools and you are willing to do that.
  15. eaorobbie
    20,473Coins
    I can tell which software from the motion cues , in Sim Commander, stands out if you have used it, very poor compared.
