need help with the gamemanager
Discussion in 'SimTools DIY Version' started by thesaxon, Jan 22, 2014.
  1. thesaxon
    thesaxon New Member
    - 96Coins
    hello at all,
    after installing the race 07 plugin for example with the plugin-updater with success, i cannot select any other game with the gamemanager to patch it. i studied the docu but found no solution.
    thanks for helping
  2. sgtjay5
    sgtjay5 Member
    674Coins
    Make sure your game has not started yet. Once the plugin sees the game's exe running, then it will lock SimTools to the game.
  3. thesaxon
    thesaxon New Member
    - 96Coins
    Thank you for answer. The game isn`t running and I cannot select another game than Live for Speed. How knows the gamemanager witch game is selectable?
    What path is the patchingpath for race07 ?
    ... a few minutes later I tried a adminaccount to install the plugins and it works now
  4. eaorobbie
    20,502Coins
    This will also work with the Steam edition and Race Ignition and GTR Evolution too.
