prilad
NFS Hot Pursuit (v 1.0.5.0) Plugin 2014-01-21
SimTools game plugin for NFS Hot Pursuit (version 1.0.5.0)
  1. prilad
    Dubna, Russia
    9,663Coins
    3DOF, DC motor, Arduino, 4DOF
    prilad submitted a new resource:
    NFS Hot Pursuit (v 1.0.5.0) Plugin - SimTools game plugin for NFS Hot Pursuit (version 1.0.5.0)
    • Like Like x 5
  2. bsft
    Thanks man, I will look into this and install and have a go soon.
    .............now wheres that external hdd?..............
  3. value1
    15,078Coins
    Hi all
    I have a PC with a NVIDIA GeForce GT 640 and dual screen. NFS HP works fine on that.
    The PC for my motion platform however has a 2×GTX-560 Ti 448 SLI with tripple-screen.
    On this PC the game doesn't work, i.e. the graphics is messed up.
    I have tried turning two screens off, turning SLI off, enabling CPU only – no luck :(
    Anyone a trick to make it work?
  4. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
  5. bsft
    Use a bigger hammer.
    • Funny Funny x 2
  6. CraCk
    CraCk Member Gold Contributor
    Made in Ukraine
    670Coins
    I tested NFS Hot Pursuit on window xp. When you turn on the game I got no clear data. During the trip, the data do not change.
  7. value1
    15,078Coins
    Hi @CraCk
    Please check if you have NFS HP 1.0.5.0
    The plugin only works with this version.
    You may need to patch your game with the latest update.
  8. CraCk
    Made in Ukraine
    670Coins
    Hi value1
    I'm using version 1.0.5.0
  9. value1
    15,078Coins
    @abdo_tahan
    Hi Spe;)edy
    Thanks for your help! Yes, I'm using the internal SLI bridge and I don't want to remove a graphics card to play NSF HP on the motion platform. From what I see on youtube and other forums, it is possible to run NFS:HP in triple screen mode. I'll investigate more…
  10. bsft
    I have this game and patched it to 1.0.5 version as well, but still no luck with data coming out of the game.
    Does anyone have some steps to go through?
  11. speedy
    Alexandria , Egypt
    7,944Coins
    @bsft ... It is working fine with me except some low performance in my computer ... every thing is the same as you have ... check If you have axis and output settings are selected .
    It worked with me from the first time ...
    First, How can I make it run in "window mode" so I can video record it with SimTools ?
    it seems not recording the game in full screen view ... But numbers are bouncing in the SimTools ... I'm using screen video capture recording .
    Me too a C**cked version ,updated to 1.0.5.0 , plugin installed , game selected and patched , axes and output preset is selected and "SAVED" , game is running ,numbers are bouncing in the tuning center ... but my computer gives me low performance
  12. value1
    15,078Coins
  13. speedy
    Alexandria , Egypt
    7,944Coins
    Yes I tried ... :grin:grin:grin:grin .... Thanks @value1 ... but I guess I'm a looser in this area ... I don't get how to run the program inside it :oops: ?? it just wont run the .exe of the game ... is it has to be on the same directory of the game ?
    the ReadMe.txt ... is worse .
  14. bsft
    @abdo_tahan , where did you patch the game, exactly please?
  15. speedy
    Alexandria , Egypt
    7,944Coins
    First the game version updater is automatically assigned me the 1.0.5.0 update and did every thing by itself ...
    after that Do use GamePlugin updater program normally "Drag and drop the zip file of the game downloaded plugin ..
    Then Run Game Engine, and Run Game Manager and look for its task bar small square Icon ... double click it to open the Game Manager itself ... with the green back ground as connected to game engine >>> you know that ???
    Patching the NFS for motion select it in Game selection, and select this folder into in the Patching button ...
    C:\program files\Electronic arts\Need for speed(TM) Hot Pursuit
    where the NFS11.exe file is ...
  16. bsft
    I did that, but I will check again today if I missed something........
  17. bsft
    @abdo_tahan still no luck, I manually removed all plug related stuff from simtools folders, unpatched game, re-installed plugin, re-patched game, still nothing.
    Game is version 1.0.5.0, but .exe is still 1.0.0.0
    I patched the game in the program folder with the .exe file. So unless i missed something, its got me stufed.
  18. speedy
    Alexandria , Egypt
    7,944Coins
    @bsft ...Hey that's the error ... you mixed it ... patching the game from SimTools with the plugin is for Sim motion output ... not for updating the game version ...
    Now for updating the game version connect to internet and allow the game itself to Automatically/On demand update itself ... and check for the version it must be 1.0.5.0 ... then proceed as usual ...
  19. bsft
    ok, I will uninstall and re-install then and I will try that. It doesnt auto update unless I get the patch update to do it for me.
    Funny how after I installed game, started it, played a bit, then updated after that the .exe stayed the same
    Unless the update I chose doesnt update the .exe
  20. speedy
    Alexandria , Egypt
    7,944Coins
    @bsft ... Is this the file you're using ?...
    For me ... some time ago I opened the game and an update message came up, with the new version if it's OK to proceed ... I don't know where to activate it again to check for updates .
