Resolved game data-Input 0
Discussion in 'SimTools DIY Version' started by 741852cp, Nov 10, 2013.
  1. yobuddy
    51,532Coins
    The output testing will be fixed in the next release!
    Bug found and being worked on!
    • Like Like x 5
  2. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    Your work and unselfishness
    Bring us happy
    Thank
  3. yobuddy
    51,532Coins
    Any Time Buddy!
  4. Tim Sieh
    Tim Sieh New Member
    281Coins
    Hi, thank you very much for your excellent work! I have same bug as 741852cp has. and I downloaded the last version of Simtools. But this bug still happen. I'm running Dirt3 in Win764bit. Please help me!
  5. yobuddy
    51,532Coins
    I bet you don't have your axis config setup correctly?
    Have you read the doc's by chance?
  6. Tim Sieh
    Tim Sieh New Member
    281Coins
    Thanks for reply! I have read the doc. But I can't resolve this error by the doc. My situation is the game data input not correct. It is chaos. They changes very fast and erratic.
    I checked the hardware_settings_config.xml. But it looks like alright.
    I guess maybe the dll file of game plugin has problem?
    Thank you again for your help!
  7. yobuddy
    51,532Coins
    'hardware_settings_config.xml?'
    Where did you find that?
    I don't believe this to be a bug, you just don't have is setup correctly I believe.
  8. Tim Sieh
    Tim Sieh New Member
    281Coins
    I finally figure out this problem! I was running Simtools in win7 Chinese version. And I find a PC running in English version to test Simtools. And that bug is gone!
    So I think maybe the bug was the result of Language for non-Unicode.
    If anybody else run into the same situation. Try to change "Region and Language" setting.
    Thank you, your answer is really helpful!
  9. yobuddy
    51,532Coins
  10. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    Yes, buddies, what's ideas?
    Sorry, I badly for English
  11. eaorobbie
    20,503Coins
    Do you have a similar problem @741852cp
  12. yobuddy
    51,532Coins
    @741852cp, are you using version 1.2?
  13. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    Hello: eaorobbie, yobuddy
    I am using Sim tools 1.2 test, a good improvement, data overflow can be restored. Thank you for your work!
    Test results are as follows:
    win7 64, windowXP Chinese version
    Sim tools 1.2 software interface overlap, but
    Can be used.
    IL2, Race07, ms Flight X. Normal data output, a perfect run.
    LFS, Game Data-input, Axis chaos jumping
    win7 64 English
    All passed the test, perfect.
    Two weeks ago and Tim sieh discussion and Tim sieh the same as.
  14. ullypot501
    ullypot501 New Member
    276Coins
    3DOF, AC motor
    Hi everyone,
    We are starting a simulator project that will use inputs from the No Limits 2 and SimTools softwares.
    Unfortunately, I cannot seem to set up the two to communicate correctly because no values are displayed in the
    Game Data Input in Game Engine. I would like to ask for assistance in addressing this problem.
    Thank you.
      362.8 KB
      956
    153,824Coins
    +11,151 / 57 / -2
    Can you post pictures of you Interface and Axis settings as well.
  16. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    Hi @ullypot501, When the Game versions are updated our own @value1 updates the Plugin to match. You therefore have to make sure you have a plugin that matches the version of game you are using, or you will not get data changing in the Tuning Centre.
    Mike :thumbs
  17. fzxj520
    fzxj520 Active Member
    1,341Coins
    I also encountered the same problem. Use of local languages, RBR plugin output correctly, LFS plug-in error published output.
    After testing, the system changes the system locale to English, it is useful。
    Guess the question should be plug-in。
