Racing Seats - fixed or reclining?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by JBoogie, Feb 1, 2014.
  1. JBoogie
    JBoogie Member
    Pre-sales Engineer
    Northern VA
    1,527Coins
    Hey guys,
    Been trying to source parts and have a question on seats...Its difficult to find the actual weight of seats online but I am obviously trying to keep weight as low as possible. Are fixed back seats generally a bit lighter in weight than the reclining ones?
  2. yobuddy
    51,529Coins
  3. JBoogie
    JBoogie Member
    Pre-sales Engineer
    Northern VA
    1,527Coins
    Thanks @yobuddy ! That's a good option to keep weight and cost down! I do really like the look of the black and red though.
  4. yobuddy
    51,529Coins
  5. RacingMat
    21,082Coins
    Hello JBoogie!
    I agreed with yobuddy's opinion at beginning
    but for my next sim, I'll have more comfort and adjustments : I like being at ease while playing 1h30
    Mat
  6. bsft
    Comes down to personal preference as well. I have used both types. No real difference in feel of motion, although a Baja Buggy seat would really transfer vibration through it easy.
    I use a sports recliner on my current ride, firm, comfortable, but I still get the fine motion. The other sim has the fixed position seat.Holds me better though, but I dont find it as comfortable.
    Then again, I know of a bloke that uses a 30kg car seat on his with all the adjustments and vibration dampening. But thats what he likes.
    As for playing for 1-2 hours, yes, some form of comfort is nice and set the motion so you still have teeth and no shattered bones helps.
  7. yobuddy
    51,529Coins
    One last note on a fixed seat.
    Although it may not be a huge factor for a lot of simulators;
    If your simulator really needs to be balanced to function properly, using a fixed seat is the way to go.
    Because with an adjustable seat, the user can change the center of gravity buy altering the seat position.
  8. JBoogie
    JBoogie Member
    Pre-sales Engineer
    Northern VA
    1,527Coins
    Thanks guys! Good point @yobuddy about the balance being affected by reclining.
    BTW - I did a little more digging and finally figured out what I think is the weight for the two seats in the first post. The recliner is 28 lbs and the fixed seat is 20 lbs.
  9. eaorobbie
    20,502Coins
    I have used the same thing for years as @yobuddy has shown, super light and super strong, but can be a little uncomfortable after a couple of hours driving in it, but it doesnt absorb any of the motion the rig produces. Which is a big bonus compared to a sprung seat.
  10. boosted-lt1
    boosted-lt1 Member
    Michigan, USA
    748Coins
    2DOF, JRK
  11. bsft
    The lighter the better overall.
  12. yobuddy
    51,529Coins
    Yes, Mine did.
    I believe all of the Poly Highback Seats are about the same.
    The difference may only be your selection of seat covers per brand.
    If you are going to add the seat padding later, you may want to take a look at each brand and see which brand has the seat cover you like.
