I cant connect together arduino 2560 amd SimTools
Discussion in 'DIY Motion Simulator Projects' started by MagicMike, Feb 11, 2014.
  1. MagicMike
    MagicMike New Member
    961Coins
    I cant receive data on my arduino board! i just receive only 255, 255,255..
  2. prilad
    Dubna, Russia
    9,658Coins
    3DOF, DC motor, Arduino, 4DOF
    Hi, @MagicMike. How do you think is anybody can help you based on your information? ;)
    There are a lot of reasons:
    1 - your Arduino sketch is incorrect (wrong serial port initialization, wrong byte recognize, etc.)
    2 - your SimTools setup is incorrect
    3 - etc...
    Please post your sketch and SimTools Interface Setting...
    PS: How you detected that Arduino receive 255,255,255?
    Regards :cheers
  3. MagicMike
    961Coins
    const int ledPin = 2;
    void setup()
    Serial.begin(9600);
    pinMode(ledPin, OUTPUT);
    void loop() {
    byte brightness;
    if (Serial.available()) {
    brightness = Serial.read();
    analogWrite(ledPin, brightness);
    All i want is to grab the values from the sim tool and dim one simple led! Thank you :)
  4. prilad
    Dubna, Russia
    9,658Coins
  5. MagicMike
    961Coins
    Sorry! :)
      146.7 KB
      534
  6. prilad
    Dubna, Russia
    9,658Coins
    your COM port baud rates are different. 9600 in sketch and 115200 in SimTools.
  7. MagicMike
    961Coins
    Ok i have fix this error . Also this is another snapshot of Simtools
  8. prilad
    Dubna, Russia
    9,658Coins
  9. MagicMike
    961Coins
    Ok i fix that all ready! But the problem still here. I think the problem is about how i read the data from the SimTools
  10. prilad
    Dubna, Russia
    9,658Coins
    Try to change sketch like this (add "Serial.write(brightness);") and try to connect with Arduino by Serial Port Monitor in Arduino IDE
    You should receive correct data...
    Code:
    void setup()
    Serial.begin(9600);
    void loop() {
    byte brightness;
