prilad
Richard Burns Rally (SSE) plugin 2.0.0.0
SimTools game plugin for Richard Burns Rally (SSE version)
  1. eaorobbie
    20,481Coins
    Some plugins install a little funny, good practice if you are updating an existing plugin is to un patch the game with the Game Manager before installing the updated plugin.
    SimTools is designed so we dont have to manually copy stuff in certain places.
    Good to know your up and running , have fun.
  2. soraz
    soraz Member
    Noale VE, Italia
    5,162Coins
    i used copy only dll for no overwrite cfg file with maxmin values.
    i have some little asymmetric adjustment in surge and pitch value.
    i think copy and re-write/check every plug-in update.
    best regards.
  3. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Thanks for the plugin, it works great! \o/
  4. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Thank you @prilad for this plugin this is by far my most fav sim of all times :thumbs.
    I'm not setup for motion yet and was wondering if you can feel the motion of any jumps in this game?
  5. tombo
    tombo Active Member
    2,443Coins
    DC motor, Arduino
    i've just seen that only Gear, Speed and Rpm is supportet over Gamedash. Will it be possible to add more things? Because game would support more features like water temperature, meters driven etc.
    I've found a offset table for tis information, maybe it is usefull for you?
    http://www.geocities.jp/v317mt/reveng.html
    Thnaks for your work so far.
  6. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
  7. gigi
    gigi Active Member
    915Coins
    2DOF, JRK, 4DOF
    Hallo Prilad your plugin is really ok with rbr. Do you how if it works also with the mods "Real Rally" I installed this mods but I don't know how configure simtool for use Real Rally and have the motion
    gigi
  8. tombo
    tombo Active Member
    2,443Coins
    DC motor, Arduino
    i have a little Problem. I builded my new PC for the rig. I installed Rbr witch patch and tried to patch it for motion. I uses the folder Sci Games/Richard Burns Rally.
    It says not a valid path for patching. I don't remember how i did it on my old pc.
    Hope someone can help me with this issue.
    152,021Coins
    +11,061 / 56 / -2
    Mine is installed on my E drive so the path for me is the top directory and on mine that is E:/RBR
    So whatever is your install directory should work.
  10. tombo
    tombo Active Member
    2,443Coins
    DC motor, Arduino
    I have the right install folder, i think it has something to do with the patches like by erobbie on the first page. But i have installed v 1.02 Patch.
    The SSE exe is in the install directory so patch should be applyed correctly. I tried reinstall rbr but without success.
  11. soraz
    soraz Member
    Noale VE, Italia
    5,162Coins
    hi,
    today for help @Chosa4 i test my project and found a problem with gamedash.
    i have Windows 7 64bit, Simtools 1.3, Gamedash 1.1, a fresh RBR installation patched to 1.02 in original path and patched for motion with plugin 3003
    when run game simtools and gamedash recognize running game but the value in game dash remain all 0.
    i also test istallation in c:\rbr and run exe in compatibility XP mode and/or administration mode without success.
    thanks for any advance
  12. Chosa4
    Chosa4 Chosa4
    Photographer
    Lusaka, Zambia
    257Coins
    Thanks, I am also noticing that simtools and game dash recognise that the game is running but my tm1638+Ard still shows nothing.
  13. soraz
    soraz Member
    Noale VE, Italia
    5,162Coins
    another test, running simtools and game with or without administrator flag have same result.
    i see slide movement in virtual axis in output testing.
    i also trace udp comunication, but all value are 0
    <_Dash_1_Output>Speed,0</_Dash_1_Output>
    <_Dash_2_Output>RPM,0</_Dash_2_Output>
    <_Dash_3_Output>GEAR,0</_Dash_3_Output>
  14. Chosa4
    Chosa4 Chosa4
    Photographer
    Lusaka, Zambia
    257Coins
    Have you had any luck trying to figure out why the plugin is not working properly?
  15. Chosa4
    Chosa4 Chosa4
    Photographer
    Lusaka, Zambia
    257Coins
    Hello! anyone with any luck on our RBR GameDash problem?
  16. tombo
    tombo Active Member
    2,443Coins
    DC motor, Arduino
    i tried very much with gamedash and rbr and had the same problems like you that it displays always 0.
    I would be very happy if anyone can fix this.
  17. soraz
    soraz Member
    Noale VE, Italia
    5,162Coins
    hi,
    waiting of an upgrade from @prilad, i write this exe to send dash-data to game dash received from gauge-server plugin for RBR (http://topdrive.cba.pl/)
    you must disable game dash function in Game Manager and if you want only dash data without movement, you can run only gamedash and rbr2dashboard.
    regards
  18. prilad
    Dubna, Russia
    9,658Coins
    3DOF, DC motor, Arduino, 4DOF
    Hi guys. I'll check what's wrong with the data from the game. Soon.:blush
  19. tombo
    tombo Active Member
    2,443Coins
    DC motor, Arduino
    after all the new updates here, maybe someone can help me. I still try to patch the game on my new pc. All the time it says the path is invalid.
    I installed the v1.02 patch and selectet the folder with rbr.exe
    After many Rbr and Plugin installation it finally works and i get dash output with the exe from soraz.
  20. soraz
    soraz Member
    Noale VE, Italia
    5,162Coins
    now we waiting for a new version of plugin, but me too received same error in wrong patch sequence.
    the right way is install rbr, install patch 1.02, patch the game.
    if already patched you must update plugin and remove-patch before.
    regards
