Showroom 3070W 6DOF Seat Mover (WIP Surge_Sway table)
Discussion in 'DIY Motion Simulator Projects' started by Pit, Mar 5, 2014.
  1. Historiker
    9,205Coins
    Yes, that looks correct. :)
    Oder ich habe gesagt; ja, das ist richtig. :)
    Entschuldigung, miene Deutsch is nicht gut.
  2. Historiker
    9,205Coins
    darn...there should have been a "sollte" in there someplace, lol. It has been a long time since I used what little I learned about your language. Sorry. :D
  3. Pit
    30,510Coins
    OK, if I turn the potis what should happens in xSimCTRL?
    PS: Probably your German is better than my English... :)
  4. value1
    14,241Coins
    Oder soll ich sagen; ja, das ist richtig. :)
    Your German is great! :)
  5. Pit
    30,510Coins
    As I understood the poti will change the analog value. The value controls the rate at which an LED blinks. Unfortunately the rate does not change. So my assumption could be that the Arduino clone "Zduino" (Ch*** b***s***) is destroyed or what else.
  6. eaorobbie
    20,503Coins
    @Pit the pot is lineer and have you tested the pot with a multimeter too , could be pot the Chinese clones are not too bad to use, lol I use Freetronics clones for my dashboards.
  7. Pit
    30,510Coins
    Yesss :)
    For now I ordered some standard pots for testing with (POTI2W: 270°, 20%, 2W) cheap and working, for the final sim I ordered PD5WK010 (300°, 10%, 4W) but not available yet. The original Uno R3 will replace the Zduino. In the meantime I will continue building the sim. :)
  8. Pit
    30,510Coins
    Update: after reading and reading and reading - I will integrate a traction loss in the rear part of the rig. I should make it possible without changing to much due to my "open system".
  9. eaorobbie
    20,503Coins
    Pots you have listed above should be ok as test units, but beware the wipers can wear out inside them quickly if the shaft has any strain on them, but will serve well to get you started, for sure.
  10. Pit
    30,510Coins
    UPDATE!!! The Zduino is WORKING :) The Arduino potentiometer test (see some postings above) passed successfully by using the PD5WK010 pots. The Arduino board wich I ordered can now be used for the "traction loss" later.
  11. Pit
    30,510Coins
    I am making progress...day off today so working at home :)
  12. Pit
    30,510Coins
    I experienced a setback today mounting the winches on the platform. This platform is made by metal and has a "socle" by wood (see picture above). This combination works like a loudspeaker with an amplifier. :eek:
    I had to disassemble the platform. I think I will use MDF. Furthermore I could imagine to put up the winches on a stone or something else...I must think about it :confused:
  13. Historiker
    9,205Coins
    Notice that mine are mounted on solid blocks of wood (hickory) rather than a hollow box :D It is less likely to amplify the sound.
  14. RacingMat
    21,082Coins
    Hi Pit!
    Well done! I would just give you an advice: it's better if the rod can freely make a turn. In your case, if pot broke, the rod will smash on the steel structure...
    yours
    Mat
  15. Historiker
    9,205Coins
    Very good point Mat, I also learned that the hard way....and still have levers that do not fully rotate due to the nature of my winches :(
    The new winches for my 6DoF can rotate 360 degrees though.
  16. Pit
    30,510Coins
    Thanks @RacingMat. This issue has to be adjusted.
    Perhaps I will mount the winches into a solid and isolated box. This box can be opened and has an ventilation system. So far, so good but not easy to build and much work at all. But the noise is intolerable.
  17. bsft
    thats winches for you , noisy bastards they are
  18. Pit
    30,510Coins
    By using some low cost noise-dampening mats from BeQuiet I should win the race against the noise...isn't it? ;)
    As I'd mentioned just before the winches have to work in a closed box. Stay tuned...
  19. Pit
    30,510Coins
    ok now using Arduino UNO/Duemilanove 2dof firmware it is all OK, the motors speed up if i turn the pots. In the middle position of the pots the motor are stopping. If I would connect the pots to the motors I will kill them.
  20. Historiker
    9,205Coins
    Hi Pit, can you post more information about the winch motors that you are using? They do not look like anything that I have seen so far, I am interested.
    David
