back again... 2DOF SIM WhiperMotors with Pol.JRK 12v12
Discussion in 'New users start here - FAQ' started by Mario Reinecke, Mar 11, 2014.
  1. Mario Reinecke
    Mario Reinecke New Member
    Kassel Germany
    587Coins
    Hi, im back again. I have to stop going on with my project in the last year cuz of private things...( sorry)
    But now im back to build my Sim!
    What i got now:
    -3 VW Whipermotors ( i have them earth isolated from case, was no Problem! I could make a short " how to" for the forum if needed .)
    - 3 Pololu JRK 12v12
    - Racing Seat
    - G27
    - metal frame
    - track IR
    - Oculus Rift
    - universal joint
    - 4x ball joint
    (i have 3 Motors and 3 Jrks, but first i try a 2 dof sim for practice experience)
    what i´ve ordered : (i´ll got all this Stuff in the next 2-3 days)
    - pro Gauge controller http://www.symprojects.com/shop/pro-gauge/
    ...to run the instruments
    - Power = 24 V 50 A or 12V 100 A 1200W Pulsar Robbe
    http://www.ebay.de/itm/121292068300?ru=http://www.ebay.de/sch/i.html?_sacat=0&_from=R40&_nkw=121292068300&_rdc=1
    - Potentiometer = http://www.ebay.de/itm/301055775244...eName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    - G27 Pedalmod = http://www.nixim.com/index.php?pageid=brakemod
    (i will mod the shifter too )
    maybe i buy some bodyshakers and run them with SimVibe later (have someone experience with simvibe ? does it work fine ?)
    I`ll beginn fixing the stuff together on saturday, first pictures ill post on Sunday.
    I think i`ll need a little help by configurating the Software and the JRK´s... and the best way to get my pots running..
  2. yobuddy
    51,255Coins
    Jealous!
  3. bsft
    What? Wiper motors again? :confused:
    Yep for sure Rob and or I can help you get setup with Simtools and jrks.
    Maybe you could put pots on the back like these single turn 360 deg pots
  4. Mario Reinecke
    Kassel Germany
    587Coins
    Hi Bsft,
    yes.. still whipermotors , if i crash them i try some other motors - maybe winchmotors.
    For the pots i need some gearing/ transmission cause they are not 360 deg ones...
    Can i try something like this ? :
  5. eaorobbie
    20,489Coins
    @Mario Reinecke yes that will work just as well.
    Let me know where you need help.
    Jrks run fine with SimTools.
  6. Mario Reinecke
    Kassel Germany
    587Coins
    Does it need special dimensions ( length of the arm or something ), or do i need to calibrate the pots later by JRK's software ? I dunno if the pots needed a special workingrange or not ?
  7. bsft
    you could always get the big motors from motion dynamics in Australia, just let me know if you do , I can pick them up and send them private post so you do not cop taxes and crap.
    The pots just get set like normal in JRK utility like you did before.
  8. bsft
    ive done that heaps of times before, its a good idea to use cheap pots so if the motor overshoots it doesnt break the pot
  9. Historiker
    9,208Coins
    Very generous of you Mario, that would be very helpful.
    By the way, I have been to Kassel, beautiful city. I spent a day hiking to the fountains and wandering the paths. Wonderful.
  10. Mario Reinecke
    Kassel Germany
    587Coins
    Thank you all for support ;)
    @bsft : how much are the Motors from Motion Dynamics ?
    @ Historiker : youve been in Kassel ? When?
    there are much more nicer Citys in germany than Kassel.
    But you are right it has some really beautifull Places. You said fountains so i think you have been to the " Hercules " water playing games"
  11. Historiker
    9,208Coins
    Yes, and the old castle on the way up, as well as visiting the home of the brothers Grimm. I spent a summer in Gottingen in 2008. On weekends I visited as many places as I could, DeutschBahn is awesome ;)
  12. eaorobbie
    20,489Coins
    Ok @Mario Reinecke , the length of arm is relevent to the amount of movement you will require for a seat mover style I would not got past 100mm of movement, meaning that the max position and the min position has a 100mm of travel between them.
    50mm up from horiziontal and 50mm down. This all is set in the Feedback tab of the Jrks.
    For the amount of range on the pot I would recommend as much as the 270 deg most cheap pots have so I would mount a motor and temporarily mount pot with lever as per video and experiment with the length so that about 100mm of movement equals near to the max of the pot, the more of the angle of the pot you use the better the resolution of movement (motion) will be achieved.
    The setup shown in the video is a good base to start from take a guess and have a play with one motor mounted and a pot, get use to setting up and using the Jrk Software to tune the PID and Feedback for the motor, once this is good you are ready to move on to SimTools.
  13. RaceRay
    Hamburg, Germany
    23,877Coins
    Deutsche Bahn is popular for their delay in arrival:D
    @Mario Reinecke Good to see your are continuing your project.
  14. bsft
    @Mario Reinecke I sent you a PM
  15. Mario Reinecke
    Kassel Germany
    587Coins
  16. Mario Reinecke
    Kassel Germany
    587Coins
    @All:
    what do you think brings more driving funeffect
    - mounting the Displays to frame (so they move with the rig)
    or
    - or leave them in a fixed position ?
    (maybe mounting the display is to hard for my whipermotors..)
  17. bsft
    what happened the last time you had wipers on a frame with screen on it? Especially considering the motors were mounted low.
  18. Mario Reinecke
    Kassel Germany
    587Coins
    nothing happened. I dont have had a rig before ! I tried to start building my rig in the last year, but must cut my plans cuz of private things...
    no im gonna to build and finishing it. Specially this weekend ;)
  19. Historiker
    9,208Coins
    I love having my monitor and controllers mounted to the platform, it feels much more natural to me. Granted I had to use much heavier duty motors (winch motors) but it is well worth it to me. Much more immersive.
    Thanks for the picture, I have many many of my own :D
  20. bsft
    sorry Mario, I got you confused with our Austrian counterpart
