SimTools Presets 2DOF Arduino Simulator with rear wipers
Discussion in 'Game Engine axes presets' started by RacingMat, Nov 6, 2013.
  1. RacingMat
    21,087Coins
    Here is the simple AxesPreset file I use for my 2 DOF playseat:
    - 2 DOF
    - roll and pitch DOFs
    - wiper motors are at rear
    Just unzip it and paste it to your local directory:
    C:\Users\Mathieu\AppData\Local\SimTools\GameEngine\AxesPresets
    No need to fiddle with your local directory!
    Simply drop your preset here to install them:
    And if you need to send one to a friend, or you want to post one, you can find all your presets here:
    • Like Like x 11
  2. bsft
    Thats fine, but you havent specified numbers in the forces. A percentage strength of the force doesnt really help.
  3. yobuddy
    51,656Coins
    Hi Guy's
    yobuddy :cheers
  4. eaorobbie
    20,506Coins
    Thanks Yobuddy, if they read the manual ,lol that would know this.
  5. bsft
    now why would we do that! ;)
  6. vell001
    vell001 New Member
    559Coins
    Hi, Racingmat
    I am using your AxisConfig, but my software must have some trouble; I don't know why: I turn on OutputTesting->Virtual Axis when my LFS is runing, then alert this dialog, what wrong with my software? 20140312000611.png
  7. RacingMat
    21,087Coins
  8. yobuddy
    51,656Coins
    @vell001
    If you can get it to have the error again, please click details and post the results.
    Then i can see the error your having and fix the problem!
    Thanks buddy!
  9. vell001
    vell001 New Member
    559Coins
    Thanks Mat,
    I think so, but I'm a little think impassability ah.
    vell001
  10. bsft
    Just use JRKS and you will never look back, also get more advice on your build. There are faults with Mats build , sorry Mat.
  11. vell001
    vell001 New Member
    559Coins
    Hi, @yobuddy
    This is the detail, I don't get any information from this message, please help me:(, thanks~
    Code:
    System.OverflowException: Arithmetic operation resulted in an overflow.
       at SimTools_GameEngine.frm_GameEngine.tmr_VirtualAxes_Tick(Object sender, EventArgs e)
       at System.Windows.Forms.Timer.OnTick(EventArgs e)
       at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    mscorlib
        Assembly Version: 4.0.0.0
        Win32 Version: 4.0.30319.18063 built by: FX45RTMGDR
    SimTools_GameEngine
        Assembly Version: 0.1.0.0
        Win32 Version: 0.1.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameEngine.exe
    Microsoft.VisualBasic
        Assembly Version: 10.0.0.0
        Win32 Version: 11.0.50709.17929 built by: FX45RTMREL
        CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
        Win32 Version: 4.0.30319.18021 built by: FX45RTMGDR
        CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
        Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
        CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
        Win32 Version: 4.0.30319.18036 built by: FX45RTMGDR
        CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
        CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
        Win32 Version: 4.0.30319.18060 built by: FX45RTMGDR
        CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
        CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
        CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Microsoft.GeneratedCode
        Assembly Version: 1.0.0.0
    PluginAPI
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/PluginAPI.DLL
    GTR2_Plugin
        CodeBase: file:///C:/Users/Administrator/AppData/Local/SimTools/GamePlugins/GTR2_Plugin.dll
    LiveForSpeed_Plugin
        CodeBase: file:///C:/Users/Administrator/AppData/Local/SimTools/GamePlugins/LiveForSpeed_Plugin.dll
    Accessibility
        CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    enabled.
    For example:
    <configuration>
    </configuration>
  12. vell001
    vell001 New Member
    559Coins
    thanks bsft, but I am following Mat, I am using arduino, what wrong with Mat's build? I can't find any faults of Mat's build
  13. bsft
    @vell001, ok then, I am mistaken to some extent, every build has faults. Good luck with the build.
  14. yobuddy
    51,656Coins
    @vell001
    can i get a pic of your interfaces settings and a shot of the tuning center while the virtual output is running thx.
  15. eaorobbie
    20,506Coins
    Nothing wrong with Mats code but the more ya spend on anything normally results in a better object, sometimes.
    The Ard is a cheapo option but not as good as the expensive Jrks, but still produces a motion sim no matter.
  16. eaorobbie
    20,506Coins
    Have you tried to repair, redownload the Net. framework, could be the error.
  17. Historiker
    9,205Coins
    RacingMat's code works very well, as I can attest.
    Good luck with your build and I hope you figure out this issue.
    • Agree Agree x 3
  18. vell001
    vell001 New Member
    559Coins
    @yobuddy
    Sorry about my disappearance, I am a little busy some time ago.
    here is my interface setting, and I am sure that is no problem. I don't know why my gui is misplaced
  19. McCorwin
    McCorwin Member Gold Contributor
    - 90Coins
    hello, just 1 question ;-) , why you didn't add sway, heave and yaw ????
  20. RacingMat
    21,087Coins
    @McCorwin : this is a starter preset that a beginner can use straight after finishing his build!
    Of course, you can alter this along your choice and preferences, add other effects.
    Often it is adviced to tune effect by effect separately (driving and feeling) and merging them at the end.
    yours
    Mat
