DIY Free ButtKicker
Discussion in 'DIY peripherals' started by Ashraf, Feb 4, 2014.
  1. Ashraf
    Ashraf Member
    1,034Coins
    3DOF, Arduino, Motion platform, 6DOF
    Hello!
    After a stormy party in speakers diffusers torn, it was a pity to throw out them (it was good "pumped" sound), so I decided to bring them a second life, the pictures can explain technology, after connected to the amplifier at lower frequencies the effect is stunning :thumbs
    - If placed under the fifth point, the effect of immersion in the game ensured.
  2. bsft
    looks good, how did you set it up, with Simtools? or purely the sound from the game?
    Cheers, David.
    And whats the fifth point?
  3. Ashraf
    Ashraf Member
    1,034Coins
    - I connect by audio amplifier, sound from the game (though I have two amplifiers, the first sound for the middle range sound, second (more powerful) I use for the subwoofers.
    - and that Simtools is possible to connect an audio amplifier ?
    - is a conditional definition of the place on which we are sitting:grin, the first point of we usually think.
  4. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    Nice project @Ashraf ... give us a preview of the wiring and your recommendation of amplifiers to use ...
    Well it seems like you've got your butt-kicker working so I'm sorry but I don't want to see a video for that in a stereo level ... kidding :grin
  5. bsft
    It occurred to me that I game with headphones on, so I will need to figure out how I create 2 sound outputs.
  6. RacingMat
    21,058Coins
    Hi Ashraf!
    Well done! I have done some DIY buttkickers and burnt all of them ;-)
    What kind of glue did you use?
    And how much weight?
    Yours
    Mat
  7. Ashraf
    Ashraf Member
    1,034Coins
    Really google translator distorted the meaning?
    - under the fifth point on which everything means we are sitting: - chair, sofa, etc. and you thought about what man? :think
    I use spray foam
    - weight of what ? weight of speaker ? For something to improve the effect, there is an idea to add to the central bolt additional weight.
  8. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    bsft,
    If you're using the on-board sound card now, just purchase an add-in sound card, configure it for sim-vibe output and you're home free.
    Tom
  9. shanothegreat
    shanothegreat Member Gold Contributor
    Technician
    Melbourne, Australia
    496Coins
    2DOF, DC motor, JRK, SimforceGT
    I've found you can get reasonable performance with a separate amp for some cheap bass shakers and headphones, im currently trying to figure out how to get all the surround effects out of the headphones with just the outputs from an external sound card.
  10. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    Hi @shanothegreat, do a search for "Turtle beach DSS2" sound processor - surround sound from a stereo output.
    Mike :thumbs
  11. shanothegreat
    Technician
    496Coins
    Thanks Mike,
    I had a look at the specs, its sort of where I'm going, as in it would be great for the full 5.1, 7.1 through the headset except I would still be looking to splice into the output to run a separate sub channel for vibration effects.
    I know that someone out there will say stop being a tight-ass and spend some money on sim-vibe, maybe I will. A guy I just did a job for is a sound engineer and was telling me I can assign the outputs on my motherboards sound card to something different than what they are labelled.
    My rig is a triple screen set up with a swing away keyboard, acts as a bit of a work station, great for watching movies too. I noticed that I didn't have any speech when watching "Skyfall" very disappointed, great bass in the movie (sim) chair with the headphones on.
    I'll persevere for the moment with reassigning the 3.5mm jacks and see what I can come up with.
    Appreciate your reply
    Shane
  12. Historiker
    9,208Coins
    As far as gaming goes, hang in there. Simtools developers are still working on bass shaker support via a separate sound card.
    Here is what I use in the interim:
    http://vb-audio.pagesperso-orange.fr/Cable/VirtualCables.htm
    This allows me to copy the audio to a separate sound card and then use this card for my bass shakers. Both cards are volume/mixer adjustable so I can still control the volume of the game/movie, etc and control the amount of base being output by the second card.
  13. RacingMat
    21,058Coins
    Hi David!
    Windows allows to redirect sounds between two cards... without any software.
    I did this with Win7: I can do some screenshots if you want.
    • Optimistic Optimistic x 1
  14. Historiker
    9,208Coins
    yes Please!
  15. RacingMat
    21,058Coins
    Okay!
    What I have:
    - a soundcard on my motherboard ("Realtek")
    - and a PCI Soundblaster board ("Audigy")
    What we intend to do:
    -> make the Audigy "listening" the sound stream produced by the "realtek"
    What we get:
    - two distinct control levels
    First:
    1/ you need to enhance the "Stereo Mixer"
    it is located on "Recording" tab
    - update your driver (At first, I didn't and was stuck)
    - in english here: http://www.sagebrush.com/mixtech.htm
    2/ the mixer is bound to my Realtek and I make it listen Audigy sound card
    tada! after some trials and errors (the windows logic maybe weird), it will work!
    Mat
    • Informative Informative x 3
  16. Historiker
    9,208Coins
    Success! Thanks Mat.
  17. Nick Moxley
    Hey mat so any cheap 5.1 card will do right ?
  18. RacingMat
    21,058Coins
    Yes! or even 2.1
    Check what kind of slot you have (pci, ...) before buying ;-))
  19. dualin
    dualin Member
    Cáceres - Spain
    - 41Coins
    Hi, I'd like to use a buttkicker in my cockpit. Can you say me the cheapest amplifier to use with a buttkicker?? I don't want to spend a lot of money.
    Thanks in advance
    Best regards
    Dualin
    Enviado desde mi iPhone con Tapatalk
  20. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Amplifier? Money? You don't need anything of that, for sure there are friends of yours that can kick your butt for free :grin
    Just a joke, sorry :thumbs
