2DOF wiper Seat mover
Discussion in 'DIY Motion Simulator Projects' started by Ramok, Mar 25, 2014.
  1. Ramok
    Ramok Member SimAxe Beta Tester Gold Contributor
    Slovenia
    1,130Coins
    Hello
    These is my seat mover.
    First i would like say thanks to RacingMat for all help :)
    I use a Arduino and motomonster to move seat.
    IMG_6760.JPG IMG_6764.JPG IMG_6765.JPG IMG_6767.JPG IMG_6768.JPG IMG_6773.JPG
    • Winner Winner x 3
  2. RacingMat
    21,050Coins
    Thanks Ramok!
    You've achieved a very nice simulator! Hope you have much fun!
    I like the Ampmeter :cool:
    Mat
  3. LostMyEd
    LostMyEd New Member
    479Coins
    Wow that looks a great build - love the amp-meter showing the current draw. Awesome !
  4. Ramok
    Slovenia
    1,130Coins
    Thanks guys :)
    :sos I have a problem.Simtools Game Engine stop work frequently in games and test zone . I think is arduino a cause of all these crashes.
  5. RacingMat
    21,050Coins
    Huh, that's strange...
    - Is it the last version?
    - What error message/screenshot do you have?
    - Is it occuring with different games?
    - You disconnected Arduino and saw that there were no freeze anymore or you are guessing?
    :confused:
  6. Ramok
    Slovenia
    1,130Coins
    Hi Mat
    The version of Simtools is 1.2. These happens in all games and also in testing. I disconnect a 1000 times arduino sometimes work for a 10 min some times 0 min
    Here is some screenshot of error.
    Greetings
  7. Ramok
    Slovenia
    1,130Coins
    NO Assistance :(
  8. Historiker
    9,208Coins
  9. bsft
  10. eaorobbie
    20,481Coins
    That's the serial port on the Ardunio crashing , caused by an overflow of data, Typical of an Ardunio the Usb port is not that stable on some machines.
    Try lowering the baud rate to help the Ard.
    Try using a different USB port, even a different cable too before changing any code etc.
    Noticed too your motion is very soft, but there.
  11. Ramok
    Slovenia
    1,130Coins
    Hi
    I change the baud rate to 9600 for now works (15 min test and AC). It is Possible movements are Slower?
    I'll do some more tests tomorrow.
    Thanks guys for help.:)
  12. Historiker
    9,208Coins
    Where did you change the baud rates and did you make sure that the original baud rate matched in Windows and Simtools? You might have had one set to 9600 and the other something different. Changing the one that did not match 9600 allowed them to communicate but you might still be able to run at a much higher baud rate.
    Mat's code is set for 115200, both Simtools and Windows should be set to the same speed. This worked perfectly for me with this code.
    As Rob mentioned, if you have a poorly performing USB port try using a different port on the PC or a different USB cable. I too had an issue with an Arduino dropping out and found it was the cable going to that controller.
  13. RacingMat
    21,050Coins
    As Historiker told you, can you check all the settings in the post:
    - windows
    - Arduino IDE
    - Simtools
    Give us some more screenshots ;-)
    There should be a mistake somewhere in your setup as more than a dozen sims are doing well!
  14. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    I saw your design on youtube the other day and had an idea for an attachment that you could quickly attach to a office chair and stow away in a closet for easy hiding. Do your arms and base disconnect?
  15. Ramok
    Slovenia
    1,130Coins
    Hi shannonb1
    Easy to disconnect just pull out a pin and unscrew on motor.
    Mat what screenshot do like to see.
  16. RacingMat
    21,050Coins
    the same as I did in the tut ;-)
    windows com port
    windows com port properties
    arduino ide baudrate
    simtools interface preset (you have sent it earlier)
    PS: @Ramok : a useful hint, if you want that a notification is send to someone
    use the following syntax in your post @username
    I could have not seen this one ;-)
  17. Ramok
    Slovenia
    1,130Coins
    @RacingMat
    Screenshots :)
    Another question. Why i cannot download a plugin? :confused:
  18. RacingMat
    21,050Coins
    @Ramok : if you lowered in the Com port, did you change also within the code?
    You have to make everything coherent everywhere ;-)
    Code:
    // INITIALIZATION
    void setup()
      // serial initialization
      Serial.begin(115200);
    I guess it's hardware somewhere:
    - arduino: What kind of arduino did you buy? Do you have a link
    - as said Eaorobbie: usb port on computer or hub?
    - your PC powersupply is too low and arduino not supplied enough: try an external supply maybe?
  19. bsft
    mine fits in my wardrobe
    and its same floor area as office chair, so its possible
  20. Ramok
    Slovenia
    1,130Coins
    @RacingMat
    I bought Arduino R3.
    Yes. Changed everything even in ard code.
    Now testing with external power supply,looks like working for now
