Showroom My Triple Screen
Discussion in 'DIY Motion Simulator Projects' started by RyanSmerdon, Apr 22, 2014.
  1. RyanSmerdon
    RyanSmerdon New Member
    Auburn, Maine
    144Coins
  2. RyanSmerdon
    Auburn, Maine
    144Coins
    Think if I remove the back cabinets I can fit the actuators in there
    Sent from my SM-G900T using Tapatalk
  3. jem45472
    jem45472 Active Member
    Buffalo NY
    97Coins
    Yes its doable with a little modification.
    Nice setup!
    Everything you need to know can be found in these forums.
    Just finished mine yesterday, Im having all kinds of fun now.
  4. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    Nice setup already.
    If you're talking about SCN5 actuators just search on SCN5 there is a lot of info in the forum.
    I think this one from Seppel is a great example for you and to fit into your rig.
  5. Nick Moxley
    Awesome rig u got there Ryan, What size screens are those ?
    Motion's a breeze when you understand it all. How are you planning on going motor wise ? Actuator, Gear motor, or maybe even Dbox ? Seat mover is what im thinking your wanting.
    I personally went Gear motor and seat mover for the cost/size and the fact some Highly rated sim builder's Prefer their seat movers over Full frame movers.
  6. RyanSmerdon
    Auburn, Maine
    144Coins
    Thanks Rinus. They are 40inch I need to go cheap. I have to much money in this. What do you recommend. I don't have enough for scn5 but want my set to move with the turns and gas/braking
  7. RyanSmerdon
    Auburn, Maine
    144Coins
    Nick, how do you like the gear motors? How much did you spend
  8. Nick Moxley
    Hey Ryan, I Highly suggest going the route i went, I have less than 8-900$ into the project and that was with spending a bit more than i wanted to in my Seat Frame and Miscellaneous welding.
    here's my thread, have a look and see if there's a way to incorporate the motor's to your current rig, The Motor's at the end of the thread also might suite your need to keep thing's more "inboard"
    http://www.xsimulator.net/community/threads/2dof-diy-seat-mover.5271/
    Oh and I am Extremely pleased with the gear motor's on my Rig, Couldn't really ask for much more to be honest, They are Uber fast and dont have a problem pushing my larger buddy's around. (im 150lbs, buddy's are 200+) I did have a little quirk with one of the gear boxes but when you read my thread you'll see the seller's an awesome guy and is swapping the "potentially defective" box. Currently working great however.
  9. jem45472
    Buffalo NY
    97Coins
    Ill second Nicks post. My gear motors are fast, silent, and plenty of torque. Im glad i decided against the scn5.
    Ill bet you can incorporate motion in your setup for about $600-700.
  10. bsft
    I third @Nick Moxley advise for sure. I have played on SCN5 shoulder mount seat mover, and DC motors and JRKS for sure will do the same if not a better job in a smaller area needed than SCN actuators. DC motors are Fast, strong, easy to setup than SCN5, cheaper.......
    JRKS maybe be a little costly, but the simplicity and the performance far out weighs any starting cost. No mucking around with them, wire up , plug them in, adjust PID and motor settings and you are off in stuff all time. No codes to check and remod.
  11. RyanSmerdon
    Auburn, Maine
    144Coins
    Nick I know your post was from April but I am now ordering all my parts. My rig has evolved little . I took a pic from the back to show how much room i have on each side of the seat. I beleive I would need to remove the side cabinets. Also my seat is sitting right now on a movable sliding frame bolted to mdf board. I think I will go with the motors you suggested. In my rig, what benefits or choice would i have over 50:1 or 25:1 in my setup. Also i will not have my wheel moving. just the seat.
    @bfst I have been reading different post with different rigs. You have been a big help to many. Thank you for being a kind person and helping everyone out. I sure in do time, you will have a lot to offer with my rig :)
  12. RyanSmerdon
    Auburn, Maine
    144Coins
  13. RyanSmerdon
    Auburn, Maine
    144Coins
    Lastly, I would like everyone opinion, Should my set up be motor to back of seat or motor to a platform my seat sits on. Pros and cons?
    153,734Coins
    I think a shoulder mount seat shaker would be a simple and effective way to add motion to your existing rig @RyanSmerdon. The pros are simple design, good movement and easily incorporated into you existing rig.
    • Agree Agree x 3
  15. Nick Moxley
    +1 Shoulder mount, You have more than enough room to fit some gear motor's in between your current side's
    Difference between 25:1 or 50:1 is really personal weight, Im a little guy at 150lbs so 25:1 Other buddy's near double me so we went for 50:1's the 50's also hold their position pretty well when not powered.
    For sheer reference material, here's what i ended up with for the rear angles, Angle doesn't need to be as extreme as say the SimX units with the fragile Actuators.
  16. Nick Moxley
    Also what PSU's are you looking at ?
  17. RyanSmerdon
    Auburn, Maine
    144Coins
    I'm 210lbs so i will go with the 50:1. I was looking at the 600 psu that you used. Should i go with the 700w?. I agree, I am going to go with your setup
  18. RyanSmerdon
    Auburn, Maine
    144Coins
    Wish i had the buttkickers. I wanted to put the mini's on all four corners of my box
  19. Nick Moxley
    IMO Mini Lfe's lacked big time in comparison to the Gamer 2, Luckily i scored a deal with Guitammer and Ive been rattling my brain ever since. :thumbs
    Also remember the Seat mover you are only attached At One point to the base frame, Having shakers at all 4 corner's would be near impossible to feel, Part reason i favored Shakers on my Seat only, Im tempted to make a Heel plate that Doesn't Touch my CSP's at All and have that Shake too, Just haven't gotten around to it.
    For PSU's i would vote for the 750's actually the Dell Poweredge 2950's. I haven't had a chance to test them under motion, But im sure they will be good. The 700's with No internal fans aren't worth the hassle imo.
    http://www.ebay.com/sch/i.html?_fro...nkw=Dell+Poweredge+2950+power+supply&_sacat=0
  20. bsft
    go 50:1 to allow the extra, and go a bigger power supply as well. Nothing wrong with too much power on hand.
