value1
iRacing Plugin 2.0.3.2
SimTools game plugin for iRacing
  1. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,449Coins
    Yes me too... I was beginning to think it was just me having problems. :grin
  2. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    You are right about that but the download file is called the same as the previus version.
    I know its a a little effort to change the file name but I forget to do that constantly so when I push the download button I overwrite the old file.
    Thanks in advance all you guys are doing great work :cheers:thumbs
  3. value1
    14,242Coins
  4. value1
    14,242Coins
    Thank you @eaorobbie! Fixed now with 3.0.2.2
    @Rinus janssens: You can download any old version via the Version History:
  5. eaorobbie
    20,503Coins
    Thank You @value1 will run some races tonight and test, actually been enjoying Iracing with motion the other software made the ride feel like crap this not bad at all.
  6. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    How many coins do I need to be able to download this plugin?
  7. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    Hi @ shannonb1, maybe you should wait until you've got something worth listening to instead of spamming the forum.
  8. Historiker
    9,205Coins
    Is Heave broken for anyone else? The build released yesterday seems to have broken it. In game Heave goes to 100% and stays there. It was working fine the day before the release. I tried min/max settings, profile settings, axis settings, etc; regardless heave goes to 100% of its travel and stays there. I had to turn it off to get decent motion on the other axis back :(
    I used Virtual Axis to verify this.
    Just to be sure that it is not my system I checked in Assetto Corsa and rFactor, both work fine.
    Help :)
  9. value1
    14,242Coins
    @Historiker: There was an update of iRacing on April 23 but it should still work w/o problem. Heave works here fine in 64 as well as 32 bit mode.
  10. Historiker
    9,205Coins
    Hi Tomas, for me Heave goes all the way to positive and stays there. No changes in my sim and heave works in all other games. I will try a couple of things today including uninstalling and reinstalling iRacing.
    Thanks for checking into it
    David
  11. RufusDufus
    Adelaide Australia
    16,449Coins
    Hi David, when in tuning center iRacing seems to have heave "center" value at 1, I have always assumed iRacing considers this to be the 1G of downward force from gravity. If you therefore scale the heave too much you always have an offset in your motion. I seem to recall BruceAust having some trouble with it a while back.
    I have sort-of worked around it by setting the minimum to 0.5 and the maximim to 1.5 and reducing the heave % in the interface setting. It still makes the sim sit slightly off horizontal though (seatmover).
    I have also thought about adding a rather slow washout to the heave on the assumption it will filter off the steady state 1offset but be slow enough it doesn't effect the bumps etc... Haven't got round to trying this yet ;)
    Maybe a future plugin update can remove this offset (and add traction loss) :grin
  12. value1
    14,242Coins
  13. Historiker
    9,205Coins
    Hopefully I will be able to load this up later in the weekend. I am still having the issue with Heave, tried Rufus' work around but no luck. What is really odd is that one day it was working and the next it was cockeyed. No changes to the rig at all other than the iRacing update. I still need to uninstall everything and reinstall to see if that fixes it but I did unpatch and repatch with no luck.
    Thanks for keeping us updated Tomas, it is very much appreciated.
  14. eaorobbie
    20,503Coins
    Thanks for the new patch testing tonight , cheers.
    Lets race !!!
  15. value1
    14,242Coins
  16. Historiker
    9,205Coins
    You really are my hero! :)
    I will try this out when i get home fron NYC
  17. Crowdpleazer
    Crowdpleazer New Member
    Torres Novas
    300Coins
    Why cant i download the iracing plugin?? I dont have a motion Rig but want to give it a try with a couple of bass transducers..
  18. Historiker
    9,205Coins
    Hi Crowdpleazer, you do not have enough coins to buy a download package yet.
    You get more coins by taking part in discussions on the forums. Please be aware though; if you spam the forums with lots of useless posts (such as "Wow, Cool, Nice" etc) you will have your user access removed (banned).
    You could also pay real money for a download package as well. Please go here:
    http://www.xsimulator.net/community/shop/
  19. Capitan
    Capitan New Member
    202Coins
    Hi anyone know if getting 250 coins for a single serving or download used to download all the plugins?
  20. Rinus janssens
    Holland
    2,153Coins
    SCN5
    If you buy or get a license with your earned coins, say for one week, you can download as many, whatever and as often u want in that particular week :cheers
