Arduino uno R3 and pololu vnh5019. Please help me walk through this.
Discussion in 'SimTools compatible interfaces' started by james wheeler, Apr 23, 2014.
  1. james wheeler
    - 143Coins
    I tried your suggestion @RacingMat and came out with some promising videos.
    Now I did notice that if I put the pots center wire into either a4 or a5 I get the same response. Could this mean there is a unwanted open circuit between the two?
  2. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,440Coins
    Hi, have you tried the same tests suggested by RacingMat using the other pot? Based on all videos I still think the second pot is either damaged or not wired correctly. In particular I think the wiper pin of the pot is open circuit.
    From the latest videos I would say both the Arduino and the H-Bridge are OK.
    The reason both motors seem to be driven by one pot is because the "other" analog input on the Arduino (ie the other pot input) is not connected and there is enough crosstalk on the board for the Arduino to pickup the signal from the other pot.
  3. james wheeler
    - 143Coins
    And I can assume that cross talk is a bad thing? How do i fix the issue? should I see if there is cross talk across all the channels?
    Second video is a run though of the channels
  4. RufusDufus
    Adelaide Australia
    16,440Coins
    No cross talk isn't necessarily a problem... It just means if you do these tests with just one pot connected at a time you are 'likely' to see both motors get driven.
    From everything I am seeing in the latest videos everything seems to be working properly now. What happened to the pot that wasn't working? Have you done these tests with "just that pot" to confirm it was faulty?
    As RacingMat said, you need to be very methodical, testing each part independently.
  5. RacingMat
    21,080Coins
    Thanks RufusDufus for your explanations!
    From what I understood, the conclusion could be:
    as your 2nd pot is faulty, there no signal to second pin
    because of no signal, the pin is "taking" the signal from next pin ("cross talk") -> hence both motors are driven...
    So, buy an extra pot (or two) and just redod the first trial with 2 pots and 2 motors, and that should be good! no?
  6. RacingMat
    21,080Coins
    Okay, I re-created the same situation as yours:
    if there is only one pot connected, the motomonster drives the two motors together (same ligths on both sides!)
    so, your initial problem was your faulty pot, sir! from the beginning...
    I wish to see your setup working fine soon ;-)
  7. james wheeler
    - 143Coins
    wow you guys are awesome. I haven't had time to figure out everything and i am sorry i have not been able to fill your curiosity. first rainy day I get here and I will be all over it. I am so close I can smell the fumes
  8. james wheeler
    - 143Coins
  9. RacingMat
    21,080Coins
  10. james wheeler
    - 143Coins
    As I said if its a rainy day I am getting back to work. And its raining :)
    So I took some time to rewire things and shoot some more vids
    I separated the wirers as @RufusDufus suggested. and made sure the boards were apart (thanks @eaorobbie ).
    I went through everything one at a time, thanks to @RacingMat and for his code.
    So here is what happened.
    then with both "controll wires" hooked up
    then changed some wires.
    pin 4 => pin 2 m1inA
    pin 5 => pin 9 m1 pwm
    pin 6 => pin 10 m2 pwm
    pin 7 => pin 7 m2inA
    pin 8 => pin 4 m1inB --->moved to pin 9<---
    pin 9 => pin 8 m2inB --->moved to pin 8<---
    5v => 5v
    GND => GND
    POTm1 => A4
    POTm2 => A5
    My question now is.......
    Since I have no true vlue as to what the moters are suppose to do,, which of the contections are correct? video 2 or video 3? I assume 3.
    Now that this might be figured out. How do I set the simtools engine?
    my COM port is
    COM6
    115200 b/sec ,8 , none, 1,
    (flow control l) hardware
    I have been trying to use the virtual output to test. But know results
    Here is a picture of what I have.
    so whats next?
  11. james wheeler
    - 143Coins
    How can you tell its a clone. It looks alot like mine. even the made in Italy
  12. RacingMat
    21,080Coins
    it's only serigraphy ;-)
    this arduino is sent from China through ebay.ca... I could swear that it never went to Italy even on a short trip for holidays ;)
    your video 3 looks perfect!! it's the correct behaviour! GO!!!
  13. james wheeler
    - 143Coins
    YAh. then problem 1 solved.
    Next I guess is the simtools engine set up?
    Can I use the output testing to test it?
    I tryed your presets but i am not sure what to expect.
  14. RacingMat
    21,080Coins
    Do you have already read the quick starting guides and all detailed documentation? This should help you to buil your own setup from scratch...
    But preset is a good way to have quick results ;-)
  15. james wheeler
    - 143Coins
    I DID IT. MY FIRST IS COMPETED.
    2 DOF
    DESK RACER
    with SUB IN SEAT
    500w Power supply Dell Poweredge 2650
    Bought on ebay from A guy in Alberta Canada $6
    2 Ford probe wiper motors
    Bought from Kenny u-pull in Hamilton. $30 (yes I ripped them out myself
    Civic Driver seat
    Bought from Kenny u-pull in Hamiton $25
    Arduino and pololu 5019 boards
    Bought from a robotic store in Markham Ontario Canada. $35 & $60 respectively
    2 10k Pots
    Bought from a electronic store in hamilton $4/per pot
    Old CV joint
    I had in my garage.
    Metal framing was picked out of my works scrap bin.
    Wood decking was from a old shelving unit I found on the side of the road.
    Computer is a Acer aspire z5101-e3142 All-in-one
    Bought from a guy in Brampton for $300
    10" Sub woofer
    Bought from a hamilton Salvation Army $20
    Wheel and pedels
    Bought from a lady in bolton Ontario $40
    Wireless keyboard and mouse
    Bought from Burlington Salvation Army $5
    TOTAL COST:
    $525
    Feeling of doing something people are amazed by
    Priceless
    https://www.youtube.com/watch?v=1i5AYG5mLJE
    I Really Want to thank everyone that helped
    BlazinH
    Historiker
    RacingMat
    eaorobbie
  16. BlazinH
    16,688Coins
    Thanks for sharing the video with us and congratulations! Its true people that don’t have a clue how to do this, like many new members lol (no offense :)), are amazed this is even possible. Myself included a few years back! Great starting rig there! If you really catch the sim building bug, you will probably start thinking of ways to make it better and better, especially now that you can actually feel the response from it, which helps you to know where to focus on improvements. But that’s all part of the fun! Welcome to the club! :cheers
  17. RacingMat
    21,080Coins
    Champagne!
    You did it in 2 months!!
    yours,
    Mat
  18. james wheeler
    - 143Coins
