Full size motion platform motors
Discussion in 'New users start here - FAQ' started by ekulekrub, May 3, 2014.
  1. ekulekrub
    ekulekrub New Member
    Hatfield, Hertfordshire, United Kingdom
    204Coins
    Motion platform, 6DOF
    hi, could anyone recommend the best type of motors to use for a 6dof motion platform?
  2. Historiker
    9,208Coins
    I am using boat winches, noisy but I wanted something that I knew could carry the load. That is the cheapest option that I know of. There are others who designed theirs around large AC motors with gearboxes. Have a browse through the forums, Speedy did his 3DoF with AC motors but could easily be adapted to 6DoF, MerchanE did his with wiper motors but that is a seat mover not a full platform.
  3. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    @vulbas is doing, and about completed, a 6 dof using ac motor/gearheads/vfds -
    I am also about finished with a 3dof ac setup - the AC route with VFD's is an expensive endeavor - but as I did, found all mine on eBay and they were all NEW - about 1000.00 us - vs. full price of 3400.00 us.
    Good luck and please post you progress. We love new members and new projects.
    Tom
  4. BlazinH
    16,671Coins
    It somewhat depends on what the main purpose of you're rig will be used for, flight or racing, and how much total weight it will have to carry. I would have to say DC motors though because they will work in either situation! And with 6 of them working together, you should be able to find some with enough power to avoid the usually more costly AC route. For racing though, DC for sure!
  5. Marcio
    Marcio New Member
    343Coins
    Hi I found 750w servo motors for $ 150.00. I do not have experience in building YES, but I think this servo motor is a good option.
    Product Description
    Specifications
    1. AC Servo Motor
    2. Frequency: 50 - 60Hz
    3. Voltage: AC220V
    4. Power: 750 -1000 W
    5. Speed: 2000~3000r /min
    type: 750w servo motor and controller
    Motor model
    90ST-M03520
    Rated power (W)
    750W
    Rated rotation (r/min)
    2000
    Rated torque (N. M)
    3.5
    Maximum torque (N. M)
    10.5
    Rated line current (A)
    Rated line voltage (V)
    220
    Rotor inertia (Kg. M2× 10-4)
    3.4
    Brake
    Coder line number (PPR)
    2500
    Torque Coefficient 1.2
    Weight (Kg)
    3.8
    Insulation grade
    CLASS B
    Rating
    Continuous
    Ventilation protection
    Completely sealed, self cooling
    Installation mode
    Flange (60, 80, 90 110, 130)
    Protection Class
    IP65
    Operating environment
    Indoor, lower than 1000m, no corrosive and inflammable gas, dust and oil mist
    Ambient temperature and humidity
    Environment temperature: -20° C ~+40° C; Relative humidity: <90% (no condensing)
    Please inform if it is a good application for simulator 2 dof
  6. cthiggin
    Self-Employed
    Montgomery AL USA
    15,210Coins
    If I'm reading "right", the maximum output in ft.lbs. = 10 - Not enough torque to move very much.
    I'm using AC motors 1hp/60:1 Gearheads and my output in 113 ft. lbs., quite a difference.
    Some of the heavies here may be more informative, but I would never use a servo or motor/gearhead that would only put out 10 ft.lbs. torque.
  7. Marcio
    Marcio New Member
    343Coins
  8. yobuddy
    51,237Coins
    But couldn't put a gearhead on this motor?
    Say a 30:1 and you would get:
    ~300 ft-lbs listing power at about 66rpm?
  9. bsft
