Showroom 3070W 6DOF Seat Mover (WIP Surge_Sway table)
Discussion in 'DIY Motion Simulator Projects' started by Pit, Mar 5, 2014.
  1. Pit
    30,499Coins
    I can adjust only the profile for all the 3 projectors generally but not separately. If I connect the Qumi to an other PC like a notbook the issue persists. Thank you for helping.
    @All: I made a short clip testing Assetto Corsa Plugin by @value1 :) I do not know if all is right at the moment. Accelerating or breaking appears to me a little bit week, but the curbs are really heavy...:grin
  2. bsft
    looks great man! Just spend time fiddling with each profile, then mix them all together and you should be right.
    Winches are quieter than I though.
  3. Pit
    30,499Coins
    Winches are quiet because I opened them for greasing. Finally they are mounted onto a stone. The stone absorbs the noises very well. The winches stay cold all the time. So at the moment I think to buy them was a good choice.
  4. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Mounted onto a stone, that's a good one, never thought of that.
  5. bsft
    stoned winches...........
    • Funny Funny x 3
  6. eaorobbie
    20,488Coins
    Ok adjusting your profile, can you provide the numbers you are using.
    Accel and Braking is using the surge so lower the values in the Tunning Centre to obtain stronger effects.
    I actually use less for braking as I don't want to be thrusted against the steering wheel every time I touch the brakes, but if change gear or stomp on the pedal I want to be thrown back in the chair. But this is all personal, we are all different.
  7. Pit
    30,499Coins
    I am totally agree with you breaking should be less instead of acceleration. I will try out some tuning settings.
  8. bsft
    nah, just smash yourself into the floor on breaking..........:cool:
  9. eaorobbie
    20,488Coins
    Yea fine tuning of the base profile is the key to setting up, makes it so much easier later when you can just tickle the values with the Game Manager - Profile Editor in seconds and be back racing with a new profile that can be saved for later and are unlimited.
    I tune a little differently to most , I set all my DOForces to 20% max, that's is 20% of the Actuator travel, which means the sim will reach its extents and all DOForces will still be present in the motion cue. Then I set one to 20 and the rest to zero, go into game and test the motion feel for timing with screen movements etc, and then set the next to 20 and the rest including the one I done to 0 and work my way through the 5. Once happy with all I turn them all back on and test the final base profiles and still might tickle it here and there, but once happy, I never touch the Game Engine for that game again, and solely use the Game Manager to manage the profiles and change them for different cars and situations in the game, It makes racing with motion a pleasure compared to what we have gone through in the past.
  10. Pit
    30,499Coins
    Update: after playing around using different values of the Ki term (while reducing the Kp term) I could raise up the speed of the winches. They are working now rather stable on the road, only if I enter the gravel tab sometimes the winches stops but only just a few seconds in the most cases.
    At the moment I am happy but dissatisfied :p. I am looking for more options so I found at popolu.com an interesting motor driver which can deliver more current as the moto monster or the jrks: Pololu High-Power Motor Driver 18v25.
    This driver enables bidirectional control and can deliver a continuous 25 A without a heat sink, with a heat sink up to about 35 A of continuous current. Furthermore the driver can tolerate peak currents in excess of 200 A. The winches need a high peak current when turning on so that would be really a great help to avoid the stops...
    Your questions and ideas and experiences and thoughts and comments are welcome :popcorn
    PS the 18v25 costs about the half as the jrks12...
    PPS: Why it is recommended to connect large capacitors across the power supply? Any ideas?
  11. bsft
    18v25 might cost less than JRK, but JRK is 12 bit resolution, and arduino is 8 bit. If you want performance, speak to @eaorobbie about his old winch motor JRK setup he had.
  12. Pit
    30,499Coins
    After a really heavy testing day going to the limit one axle of one winches has been broken *lol*. That is reality as I like :)
  13. Pit
    30,499Coins
    Update: I must reduce the very fast turns to simulate the vibrations. Those vibrations are responsible for the stops and the very heavy load onto the axles. So I decided to buy a Buttkicker Gamer 2 adding to my rig.
  14. Pit
    30,499Coins
    Today (EDIT: this week) I will update the thread. Until then you will have a long close look at the photo... :)
  15. bsft
  16. Pit
    30,499Coins
  17. Historiker
    9,208Coins
    Good to hear that all is well again!
  18. Pit
    30,499Coins
    Update: after months of fruitless waiting for repair (the VIVITEK projectors have already been returned 2 times) they will be returned a third time to their factory service centre in Germany. The issue "green tint" still exists. VIVITEC says the 3 units are very close in white level uniformity native wise, so the color (green) tint must be coming from either source, cabling or internal calibration (which is part of the projector mainboard programming).
    They will do a calibration on mainboard level with HDMI source attached to see if they can bring the units closer in white levels. If this is not able to, they will have them measure out the values of the white level to compare to factory specifications to see if they are met or not. This means, if they are within the specification I will have to accept the issue...
    More about potentiometers: the cheaper potentiometers are beginning to be noisy after a while so I decided to spent some more money and bought P270-DS22 B-10 KR from TT Electronics for testing with (conductive plastic):
    http://www.conrad.com/ce/en/product/453335/TT-Electronics-AB-4114813545-Rotary-Potentiometer
    Angle of rotation (mechanical) 312 °
    Axle diameter 6.35 mm
    Resistor 10 kΩ
    Shaft length 22.3 mm
    Content 1 pc(s)
    Case dimensions 27 mm
    Type 4114813545
    Electrical angle of rotation 300 °
    Resistance 10 kΩ
  19. Pit
    30,499Coins
    Update: today I got the other Monster Moto from AliExpress (Sparkfun samples! ). I wired all and all seems to be right in place. First testing connected to the PSU was successful. Tomorrow I will power on the winches and I hope the seat will beat the daylights out of me. :)
  20. Pit
    30,499Coins
    Winches connected and successfully tested!!!!:D :cheers
    After starting AC the first time using the old values of the tuning center the server PSU (69A) was shutting down at the very first start (surge), WOW :) In addition to it I controlled the 6 voltages rails of each plug if they are all connected. I optimized them for the better fitting and started again (before I will attach a second PSU...). Each winches has 750W if I would use them to the full they need min. 62.5 A. The Monster Motos are now working in "Single Parallel Mode" and can resist the high demand of current. Furthermore the heat development is negligible, too. Finally if we are talking about the cost (Power <=> $), the two Monster Motos Sparkfun samples cost each 17$ (Aliexpress), the Arduino is equally expensive. The final costs are about $50 of the electrical parts without PSU. This is insane! :thumbs
    • Disagree Disagree x 1
