New to Motion Sim
Discussion in 'New users start here - FAQ' started by FlyB, May 16, 2014.
  1. FlyB
    FlyB New Member
    244Coins
    2DOF, 3DOF, Arduino, Motion platform
    I'm FlyB ... new to the world of motion sim and to this site. Excited about learning more and getting started building my first 3DOF platform. Thanks for the acceptance.
  2. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    welcome to the club. I'm also building my first sim and i'm in the planning and part gathering stages too.
  3. FlyB
    FlyB New Member
    244Coins
    I want to start with a couple wiper motors and a aduino uno but I'm not sure about the wiring or the motor prep part yet so any help would be appreciated. I am also in the planning stage, good luck on your build.
  4. bsft
    3dof drift? Or 3dof lift frame? Did you have a design in mind or an existing build that gets your interest?
    Maybe start with a 2DOF seat mover and build from that.
    Also, may I suggest Pololu JRKS, they may cost more, but are easy to wire up, need no code written, handle 14v at 30 amps all day with 45 am spikes no problem.
  5. FlyB
    FlyB New Member
    244Coins
    I was thinking the 3 DOF drift and I don't have a exact design in mind, just the idwa of what I want to try first. Thanks for the input I am doing some search and checking out some videos on the pololu JRKS. Any build instructions are welcome because I am in the planning phase and open to suggestions so to not reinvent the wheel.
  6. bsft
    Ok, have a dig through the threads then . There is some build instructions, but no kit so to speak.
    Have a look through. You could incorporate a few designs into one.
    Best this is start with a seat mover and move up from there.
  7. FlyB
    FlyB New Member
    244Coins
    Thanks for the suggestions and for the insight on the pololu JRKS
  8. miguel aponte
    miguel aponte New Member
    Jacksonville, Florida
    432Coins
    what about those pololu's linear actuators? 1.7"/sec and loads up to 35 lbs. would those work or are too slow?
  9. FlyB
    FlyB New Member
    244Coins
    Actually I am trying some wiper motors and I'll see how they handle with some weight on the platform. Linear actuators weren't my first choice, I'm trying to keep it low profile and streamlined. But if all else fail that will be my backup.
  10. eaorobbie
    20,488Coins
    Just beware to test the wipers to make sure the earth(Gnd) is not connected to the body of the wiper, If it is this must be fixed.
    Or when motors go in reverse the 12v's will be running through the frame of the sim, not good.
    Last of all check that the forward speed is the same as the backwards speed , some differ in speed but can be fixed too.
    Wipers are a budget choice but as long as you check them properly and don't load too much weight on them they will be fine to use.
  11. bsft
    too slow, need about 6 " per second
  12. FlyB
    FlyB New Member
    244Coins
    Thanks for that insight on the motor. I really appreciate all the help and advice that you have been giving on this forum.
