Ricmotech DIY cockpit
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by MrSmurgle, May 17, 2014.
  1. MrSmurgle
    MrSmurgle CTO @ gagarin.is
    CTO & Software developer @ gagarin.is
    Reykjavík, Iceland
    351Coins
    I would like to get your opinion regarding this cockpit for a 2DOF rig.
    http://www.ricmotech.com/RS1_DIY_Cockpit_Plans_p/rmt-rs1-diy.htm
    Do you know about any successful modifications of the cockpit to add the motors? I was thinking about modifying the rear part where the seat is but just keep the rest as is. It is heavy and sturdy, which I think is a plus - although I have no experience.
    Best
  2. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    I saw one on a topic about two years ago. Was a tech school student project. They built the ricmotech and then built an ac motor platform, 2dof, and mounted the ricmotech. They did a nice job, but it's movement was slower than pond water. It was really not typical of an ac platforms performance.....but it did look pretty nice.
    Tom
    Sent from my iPad using Tapatalk
  3. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
  4. bsft
  5. eaorobbie
    20,488Coins
    Seat mover could be added to this easily , a good option because it will allow you to mount 3 big screens and not worry about the weight issue.
  6. MrSmurgle
    Reykjavík, Iceland
    351Coins
    Brilliant. Thank you.
  7. jem45472
    jem45472 Active Member
    Buffalo NY
    97Coins
    No problems. Might have to extend the rear a little bit is all.
