[Solved] Power&Glory doesn't work
Discussion in 'SimTools Plugins' started by nclabs, May 23, 2014.
  1. nclabs
    196Coins
    I've just installed the awesome Power&Glory mod on GTR2, and I was going to do as always, copy the DLL of the plugin in the new folder to keep SimTools compatible, but I wasn't able to find it! What's this sorcery? Where is located the gtr2_plugin.dll that I find in the zipped plugin file?
  2. bsft
    the GTR2 plug in gets corrupted from downloading @value1 @yobuddy . I havd to download it 4 times to get it to work.
    I will look at another computer later (kids in the way), then I can advise.
    Give us an hour or 2
  3. bsft
    @nclabs
    start/computer/localdisc/username/appdata/local/simtools/gameplugins , then delete the gtr2 plugin. Try then re-installing the gtr2 plugin with the plugin updater. A friend of mine had to do it 3 times to get one of the copies of the GTR2 plug in to work.
  4. nclabs
    196Coins
    Thank you as always but I think that it's a different issue. It's a little bit my fault, 'cause I didn't wrote that I have a GTR2 that it's working, with the same plugin, but when you install the Power&Glory mod, the installer create a new folder, and doin that we lost the SimTools compatibility, because it's a different game for it. Usually, with other games, I just copy the .dll from the old folder to the new one, and SimTools regain the compatibility with it, but this time I wasn't able to do that, because I didn't find the dll that make the game SimTools compatible. What can I do? Someone play Power&Glory with SimTools?
  5. bsft
  6. eaorobbie
    20,488Coins
    Ok the GTR2 plugin modifies (yourname).plr in SimBin\GTR 2\UserData\
    It modifies one line - "Write Shared Memory=" set this to 1 and save.
    All should be good as long as they haven't changed the shared memory file name.
    If you can patch this with Game Manager and works, then this should work fine by changing the one line in the plr file.
    Note you must have played this at least once before patching.
  7. nclabs
    196Coins
    Thank you for the advice @eaorobbie , now it works like a charm!
