Can i use this hbridge for 2DOF Desk-racer?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Martin.Berger, May 26, 2014.
  1. Martin.Berger
    Martin.Berger Member
    216Coins
  2. eaorobbie
    20,481Coins
    A might but might require a change to the code, mmmmm 2 possible codes to check -
    http://www.xsimulator.net/community...otor-driver-and-windows-utilities.4957/unread
    And think @RacingMat code could be a possibility.
    Taken from their Manual:
     Rotate forward: EN = 1, RPWM = PWM, LPWM = 1, DIS = float (Here ‘1’means High, i.e.5V.)
     Rotate reverse: EN = 1, RPWM = 1, LPWM = PWM, DIS = float
     Stop and brake: EN = 1, RPWM = 1, LPWM = 1, DIS = float
     Stop but not brake: EN = 0, RPWM = 1, LPWM = 1, DIS = float (Here ‘0’means High, i.e.0V.)
     Prohibit the use: EN = X, RPWM = X, LPWM = X, DIS = 1 (Here ‘X’ means any status)
    So maybe a slight customizing of code this could be used.
    Like the 100amp peak possible could be a strong driver, looks a lot like the old tronic H bridge, lol.
  3. Martin.Berger
    216Coins
    Hi eaorobbie,
    thanks.
    Can you please explain to me what does EN and dis mean
    how can i handle 2 pwm Pins?
    THX,
    martin
  4. eaorobbie
    20,481Coins
    EN is the engage pin, if this is high - 1 - (5v) the H bridge is active and will supply power to motors when set low - 0 - (GND) the power is disrupted and the motors wont run.
    Reading the manual Dis , Im not sure as no explanation given the only thing it says it to connect nothing to it, as in no wire connection.
    Ok to go forwards we need to set:
    EN = high(5v)
    RPWM = PWM , this will range from 5v - 0v depending on the speed required, this pulses.
    LPWM = PWM set to high 255 so it gives a steady 5v's
    DIS = no wire connected to it.
    Now to reverse we just set the RPWM = PWM set to high and on LPWM sets the speed with a PWM signal.
    This is just a theory needs to be tested.
    Another way tried is to wire a card in between like this :
    This would be my preferred method.
  5. Martin.Berger
    216Coins
    Hi
    Thanks for help. That cleared Dome things. So i have to find out how to connect to arduino. At the Moment i did Not get the board. So i Test it when i got it.
  6. RacingMat
    21,050Coins
    I agree with you, it could be easily modified the way you described to Martin.Berger :thumbs
    Martin this will be your first exercise to learn Arduino ;)
  7. Martin.Berger
    216Coins
    Hi Racing mat
    I ll try
    By the Way Thanks for your Tutorial.
  8. RacingMat
    21,050Coins
    Thanks! I hope to see your sim shaking you soon! :cheers
  9. Martin.Berger
    216Coins
    At the moment i m just learning and searching parts.
    I think it will last till autumn i can build something. ;)
  10. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,259Coins
    A couple of alternate ways of using these H-Bridges with existing Arduino controlles:
    1. Use the H-Bridge EN pin as the PWM input and use the PWM inputs as the Direction pins. Sounds odd but this drives the H-Bridge in drive/coast mode which is generally fine for motion sims as they are always in motion.
    Arduino DIR1 -> H-Bridge LPWM
    Arduino DIR2 -> H-Bridge RPWM
    Arduino PWM -> H-Bridge EN
    2. Use the SMC3 Arduino software in MODE2 - its already configured for this type of H-Bridge (Refer to the doco for connection setup details) This will drive te H-Bridge in drive/brake mode.
  11. bsft
    when an ard and h-brdige and wipers do this, then I will be impressed
    JRKS and big worm gear motors rated at 160 rpm at shaft
