Cheap and easy Traction Loss Frame
Discussion in 'DIY Motion Simulator Projects' started by pitstopp, Sep 21, 2013.
  1. pitstopp
    pitstopp Active Member
    Dortmund
    634Coins
    3DOF, SCN5, SimforceGT
    Here i present my latest extension
    I sattle for a 5 Point mounting Frame .
    Why?
    You prevent torsion, its cheap cause the frame could be lighter and easy to build.
    I bought some Bearings ( whats the correct tech. expression?) New OldStock on Ebay - 5 for 10€
    I had some daubt about the Quality, but no Problem at all.
    I inserted some Tube to give the bearings a correct fit. The Tube is fixed with two welding points.
    Here is shown the Front Frame and the Rear Frame.
    In Front and Back 2 Point Mounting and one in the middle , right under the seat.
    Here you can see the Bearing with Bracket for the upper Frame.
    Very small, cause ther are only small forces to assume . Another 10€
    Here in Detail
    Underneath the Top Frame I installed some Stainless Steel Plates.
    First I tried Plastic but they were worn out immediately.
    Here is the Acctuator Mounting
    Left side
    Right side.
    First test
    mhhh not bad but the upper frame lifts a little bit in hard bends.
    Here is the solution for not hopping around
    Works fine !
    ca. 10 Hrs worktime
    bearings 20€
    Scn5 100mm used on Ebay 180€
    Tubes were found in my Garage:)
    Thanks for your interest
    Cheers
    Kai
    • Like Like x 5
  2. RacingMat
    21,039Coins
    Beautiful and cheap ! thanks for sharing this !
  3. Historiker
    9,208Coins
  4. bsft
    Thanks for adding that, eventual thing to add to seat mover, a yaw frame.
    everything except SCN actuator is cheap here in Australia. I will use a dc motor I thinks
  5. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Does that front bearing still hold up after use?
  6. pitstopp
    Dortmund
    634Coins
    Hi
    yes they still work great.
    No Problems so far
  7. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Good to know, thanks. thats my next step/.
  8. Gelatin
    Gelatin Active Member
    Hungary
    - 376Coins
    3DOF, SCN5
    This is what I'm looking for exactly, thx for sharing.
    Just started planning :)
  9. Gelatin
    Hungary
    - 376Coins
    3DOF, SCN5
    I built one of this, but you have to know that it is works well, bearings are strong enough, but it's so noisy...
    I suggest rubber wheels everywhere instead of bearings :)
  10. hooshang
    hooshang Active Member
    275Coins
    and the value we have to use for this actuator? is it yaw?
  11. Historiker
    9,208Coins
    Hi Hooshang, Value1 recently updated many of the plugins to include an additional DoF for traction loss. Check the thread for your favorite plugin to see what changed.
  12. hooshang
    275Coins
    thank you Historiker for your useful reply and thx also Value1 for adding DOF for traction loss
    but I just want to know which value or set of values are involve with Traction loss and
    another question that doesn't have anything to do with Traction loss:p but important
    why we don't have special value for RPM and speed in simtools as we had in X-sim for most of the games?
    regards
    Hooshang
  13. Historiker
    9,208Coins
    Hooshang, we have a dashboard app that takes care of RPM and Speed but there are also several plugins that have Extra 1, Extra 2, and Extra 3 where you can find the RPM and speed as well as Traction Loss (which answers your original question).
    David
  14. eaorobbie
    20,473Coins
    All dash data was intended only to be used in GameDash.
    Why have two different Programs then mix them up, doesn't make sense to me. lol Its an Xsim way, lol.
  15. hooshang
    275Coins
    thank you David and Rob for introducing Game Dash, I just didn't know about ito_O...intresting
    anyway now I should work and study how to work with...
    well after around 2 years of working with X-sim it takes time for shifting to the new one:thumbs
    regards
    Hooshang
