Motherboard fried
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by jem45472, May 30, 2014.
  1. jem45472
    jem45472 Active Member
    Buffalo NY
    97Coins
  2. ferslash
    ferslash Active Member
    4,798Coins
    Over clocking seams risky ... And hard to achieve ...
    Let us know what you do... Maybe i follow your steps :/)
    On the other hand talking about speeding a pc i had a grate experience using ssd in old pcs.. give it a tray
    Fer
  3. jem45472
    Buffalo NY
    97Coins
    A 2500k processor has an unlocked multiplier. It's one of the best gaming processors for this reason. Very easy overclocking, and runs cool.
  4. jem45472
    Buffalo NY
    97Coins
    I am also thinking of ssd, still a little pricey though.
  5. M1shap
    M1shap New Member
    458Coins
    I have a 2500k &o\c'd it to 4.5 stable. it's a beast for the price & personally I am more than happy with it for games. just need to make sure you have a decent after market cooler & good air flow through your tower as the std cooler won't do it.
    ssd for operating system, decent hdd for for games. (unless you want to load a little quicker).
  6. jem45472
    Buffalo NY
    97Coins
    Did you have to mess with voltage for 4.5?
  7. M1shap
    M1shap New Member
    458Coins
    Yeah it was as simple as going into bios & changing multiplier to 45. 45=4.5ghz then I stress tested it for 12hrs using prime 95 & kept an eye on it with real temp. best to work up to it though start small & increment up till it fails then wind back clock. not all cpu's are the same some clock higher some lower. it's just how they are
  8. eaorobbie
    20,502Coins
    Im running an AMDx8 3.9 , no need to OC but will reach that comfortably, 32 gig of ram and 2g video.
    That's enough to run any of my racing games, flat out and on Ultra graphic settings.
    Only draw back is the Sata3 HDD , SDD way to expensive here, I will wait till they drop in price.
  9. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    Hello folks,
    I've built quite a few pc's and overclocked for the past 10 years.
    Just built a new one with 4820K Intel
    I will NOT oc' without liquid cooling - I've been using the Corsair H-105 series - about a 100.00 (several versions start at 69.00 us) - then oc'ing is a done deal on the heat issues.
    If you've never overclocked before, there are many youtube videos that show you how and many will have the CPU you are going to use.
    Tom
  10. yobuddy
    51,524Coins
  11. bsft
    For sim use, I would be surprised if overclocking the CPU even makes a difference.
  12. BlazinH
    16,689Coins
    I use a 2500k on a Republic of Gamers Maximus IV Extreme-Z motherboard. I had it overclocked at 5.0ghz (on water) for about a year but then had to back it off to 4.9 because I started experiencing BSD screens. But I agree probably not really need for most titles. 3ghz is pretty good for most. I built it for FSX though which requires every bit of GHZ you can through at it!
  13. Historiker
    9,205Coins
    The i5 2500k seems to be a very popular chip, I too use it in my simpit.
  14. cthiggin
    Self-Employed
    Montgomery AL USA
    15,210Coins
    Guys,
    I'm sure we don't need a "screamer" for most racing sim titles, but a good gpu really helps.
    Like BlazinH, IF you're into flight simming also, FSX or Prepar3D, CPU horsepower is where it's at...along with P3d now shifting some of the load to the GPU, a high end GPU is very necessary.
    Like I said earlier - "me" would not oc without being on liquid cooling.............even the 69.95 Corsair does a very good job - and it's installation is very simplistic. Been there with the "Turbo Towers" air cooling
    for CPU and several others, and they just cannot cut it in comparison with todays' low prices of liquid cooling. My first liquid cooling was a Swiftec setup..............took me ALL day to modify and install and cost over 300.00 US - that was about 8 years ago......
    In any event, Good luck on your purchase and build.
    Tom
  15. BlazinH
    16,689Coins
    I agree with you Tom! A high end GPU is as important if not more so than a super fast CPU. I had been using a GTX 460 and thought everything was great. But then I wanted to try a triple screen setup that the 460 just cant do. So I upgraded to a GTX 770. Wow! I thought the graphics looked good before because I didn't know what I was missing!
    I hope your sim is coming along well and about ready for the electronics fun @cthiggin !
  16. cthiggin
    Self-Employed
    Montgomery AL USA
    15,210Coins
    Hello........................BlazinH,
    Good to hear from you friend. About finished with all my "mechanical" on 3dof -
    Been "down" due to my Mom (up north) having a terminal illness - been to see her - 650 miles away....just tough man!!!!!!
    I bought the Evga 770 Classified Oc'd - WOW - thought my 570 Classified was good..........just no comparison.....
    Stay in touch friend.
    Tom
  17. BlazinH
    16,689Coins
    Yes! It is tough as I have been down that road already myself so I know how hard it can be.
    But it is good to hear that you are about ready to tackle the electronics for your sim! Although I don't know much about setting up an AC system, I'm still here to help you in any way that I can though!
  18. cthiggin
    Self-Employed
    Montgomery AL USA
    15,210Coins
    Hello again BlazinH,
    About the "only" things left mechanically: Place my custom spring and anchor / fabricate a holder for my 3 pots and anchor - then all that is left "of the build" is electronics....
    Speedy and yobuddy are helping me out there....so, very close.
    Still have to finish my new pc build....just trying to find the time as my business is "on fire" right now....
    and my priority is my Mom.....don't care how blessed of a life one has had, you cannot go through life without pain and heartache....."they say" it makes you grow and become stronger,
    but what a price to pay for 'that' strength. Thanks for your thoughts.
    Stay in touch my friend.
    Have a most blessed one, to all.
    Tom
  19. BlazinH
    16,689Coins
    Terrific! :thumbs Sounds like you're in good hands then! And things just "lit up" even more here a couple of months ago too! :sos
  20. cthiggin
    Self-Employed
    Montgomery AL USA
    15,210Coins
    BlazinH,
    Yes, it's been about two months since I've pm'd youbuddy & speedy......GLAD I will have waited for the mechanical to be DONE - before tackling the electronics - which is my weakest area.
    I'll be able to give 110% to the electronics build and not have to worry about springs & heims & all the other mechanical build.
    Your reference to "things just lit up" a couple of months ago....brief me...as I'm not on the same page with you friend....
    Thanks and have enjoyed our latest communications.
    Tom
