Tutorial English Guide for SCN5 Interface
Discussion in 'SimTools DIY Version' started by nclabs, May 18, 2014.
  1. nclabs
    196Coins
    And now, the english guide for the SCN5 Interfaces setup.
    SCN5 configuration.
    • Click on Interface Settings, Interface1, Output Type and select SCN.
    • Under ComPort, select one of the COM ports connected to you SCN5 (if you don't know it, check the Control Panel on Windows, under the COM Port section).
    • Under Packet Rate select 10 ms.
    • Under Assignment Axis, select Axis 1.
    • With the Speed bar you can adjust the speed of the actuator, select a temporary value of 10.000 (value that you can increase after some testing).
    • With the Acceleration bar you can adjust the acceleration of the actuator, select a temporary value of 500 (same thing here, you can increase it after).
    • Now do the same thing with the Interface2, using the other COM port, and selecting Axis 2 under Assigned Axis (important!).
    • Last thing. Click on Axis Assignment, Axis Limiting and, to any axis connected with a SCN actuator, select a value of 90%. This is very important to preserve your actuator in the long term. Not doing this can lead to mechanical damage.
    • Like Like x 5
  2. nclabs
    196Coins
    Note: SCN5 will work fine, but the support for SCN6 actuator it's still in work in progress now.
  3. RacingMat
    21,050Coins
    Great job nclabs!
    I'll add it into the Quick Starting Guide :) it will be usefull for many people
  4. yokoyoko
    yokoyoko Member
    Test engineer - automobile industry
    Germany - Bad Eilsen
    829Coins
    3DOF, DC motor, SCN5, Arduino, JRK, SimforceGT
    Well done. Is already a tutorial for connecting the scn5 done?
  5. nclabs
    196Coins
    Thx! You mean, another tutorial? I know that @seppel did it but in German language.
  6. RacingMat
    21,050Coins
  7. hooshang
    hooshang Active Member
    275Coins
    might be yokoyoko means tutorial about scn5 wiring...also can be useful to add here
  8. eaorobbie
    20,481Coins
    I agree it would be nice to get it all in one place and I feel with a bit more info it will need a stickie for all to find easily.
    Well done @nclabs ,
    and thanks.
  9. nclabs
    196Coins
    Ok guys, it will be done!
  10. nclabs
    196Coins
  11. eaorobbie
    20,481Coins
    Thanks @nclabs all the scn5 users will appreciate this greatly.
    Notice it has earn you a stickee too , +1 for the SCN5's
  12. Hicsy
    Hicsy New Member
    168Coins
    SCN6
    I'm still not getting any motion from my SCN5's. They are connected to COM5 and COM6.
    If I exit software, and open up X-Sim Profiler, they work normally (under those specific COM ports)... and if I leave SimTools engine open when I launch X-Sim Profiler, it fails to find the actuators - so SimTools is definitely connecting to them when it opens.
    Any thoughts where I should try looking first?
  13. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    Did You set the id from both actuators to 0 instead of 0 and 1
  14. Hicsy
    Hicsy New Member
    168Coins
    SCN6
    Using the MSVT Servo Configurator? They are both set to 0
  15. Rinus janssens
    Holland
    2,153Coins
    SCN5
    The easiest way to adjust the ID is to use x-sim.
    In the x-sim software you can find this
    Under change id you can change your ID :grin do this or check both actuators.
    Ohh uhhh its not the red circle .... but on the right beneath that.
  16. Hicsy
    Hicsy New Member
    168Coins
    SCN6
    I have tried with both set at 0 and also different set at 0,1... no difference.
    now i'm wondering if its just a difference with the controller/adapter that I need to sort out
  17. Rinus janssens
    Holland
    2,153Coins
    SCN5
    Do you have no motion at all ? or maybe just one
    Do you have you're actuators hooked to one controller ? (simtools require two rd485 to usb controllers)
  18. Rinus janssens
    Holland
    2,153Coins
    SCN5
    With bot actuators set to ID 0
  19. Hicsy
    Hicsy New Member
    168Coins
    SCN6
    No motion
    okay. both ID's set back to 0
    2 controllers (COM5, COM6).
    Perhaps instead I can make SimTools talk to them by configuring the output type SER instead of SCN?
  20. Rinus janssens
    Holland
    2,153Coins
    SCN5
    Did you Patched the game ? with game manager ?
