Arduino + Sabertooth
Discussion in 'SimTools compatible interfaces' started by RacingMat, Jun 22, 2014.
  1. RacingMat
    21,050Coins
    Hi guys,
    I intend running sabertooth + kangaroo but as a first step, I ran Arduino + Sabertooth.
    You can find the code here the Arduino code modified to suit to Sabertooth
    http://www.xsimulator.net/community/marketplace/arduino-code-2dof-for-sabertooth.103/
    The present code uses the Sabertooth "Simplified Serial" protocol:
    - it is OK with Sabertooth 2x25, 2x60 (don't use 2x12 which is too weak)
    - Sabertooth 2x32 is compatible by legacy.
    But 2x5RC, 2x12RC models don't seem to be compatible.
    The code requires 2 libraries
    - software serial is already in the Arduino IDE installation
    - and Sabertooth library has to be downloaded here https://www.dimensionengineering.com/info/arduino
    https://www.dimensionengineering.com/software/SabertoothArduinoLibraries.exe
    //Sabertooth DIP switches 2, 4 and 5 OFF
    // serial between Arduino and Simtools on RX pin: 115200 bauds
    // serial between Arduino and Sabertooth on SWSerial pin8: 38400 bauds
    Arduino pin8 <--> Sabertooth S1
    Arduino GND <--> Sabertooth 0V
    Arduino A0 <--> Pot1
    Arduino A1 <--> Pot2
    The wiring is extremely simple: only 3 wires between Arduino and Sabertooth
    Wiring schematic from Wanegain ;) Thks!
    Use the same presets as for Arduino and Motomonster
    Game Engine axes presets
    Game Engine Interface presets
    • Like Like x 6
  2. Pit
    30,490Coins
    Indeed You got it...
    Mate you are insane. As I promised to @RufusDufus I will send all my coins I have for the first guy here which will offer a code working with the sabertooths. :cheers
    Only to be sure: this code works with any sabertooth?
  3. RacingMat
    21,050Coins
    ha ha! :) keep your coins @Pit
    - it is OK with Sabertooth 2x12, 2x25, 2x60
  4. Wanegain
    Wanegain Active Member
    Bruxelles
    2,003Coins
    I wrote a new code for this solution.
    I share it here
    I am using this code for my simulator and it's working fine.
    • Winner Winner x 3
  5. Fabgen
    Fabgen Member
    575Coins
    Thanks a lot for your work. I want to use a arduino uno r3 and sabertooth for my simu 2dof with 24v dc. I already buy the arduino board but not the sabertooth. For you, shall I buy a sabertooth 2×12 or a 2x25? Thanks for your anser
  6. RacingMat
    21,050Coins
    Hi! sabertooth 2x25
    2x12 is too weak to be used with smolka for example
  7. telfel
    telfel Active Member
    4,738Coins
    Hi @Fabgen
    I have a Sabertooth 2x60 for sale £100.00 + shipping
    pm me if interested
    regards Terry
  8. Wanegain
    Bruxelles
    2,003Coins
    You can buy the new 2x32 for the same price than 2x25!
    The 2x32 is really better and it's delivered with 2 resistive for generative current. Very useful.
  9. Fabgen
    Fabgen Member
    575Coins
    Thanks for your offer but I dont need so powerfull sabertooth and it cost too much than I want to pay.
