2DOF Simulator by a Newbie
Discussion in 'DIY Motion Simulator Projects' started by mugge66, Jun 17, 2014.
  1. Pit
    30,482Coins
    yeah, the link is only for example purposes.
  2. bsft
    I found out quickly that the pot brackets needs to be fixed to the motor itself so they both move together.
    I this shot, the brackets are mounted like yours, but motor twists on its own brackets and pulls and pushes against pot shaft, breaking them.
    I should have known after 11 builds.
    This is better,
    pot moves with motor, no more breakages.
  3. mugge66
    mugge66 Member
    Denmark near Copenhagen
    167Coins
    2DOF, JRK
    Thank you all, Will du a remake pot mounting. :thumbs
    Today i will do some of the cabinet. and post some pictures, the only problem is the weather, have to saw outside.
  4. RacingMat
    21,039Coins
    Thanks @Pit
    I updated the FAQ :
  5. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Made the cabinet this weekend, Well it turned out quite larger than i expected. :think
    Will do a remake of this, Think i can cut off at least 20cm in length of cockpit.
    20140621_151849.jpg 20140621_151910.jpg 20140622_180751.jpg 20140622_180812.jpg 20140622_200633.jpg 20140622_200648.jpg
    Also got the joint shaft mounted, i think the cabinet is still quite heavy. I have my doubts the the motors can handle it.
    Will test when i get home from work.
  6. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    BSFT@ You wrote this in another Thread, Are the wiper motor i bought week compared to this.
    Wipermotors for a Golf III between 1990 - 1999
    What are your experience in this. ?
  7. Pit
    30,482Coins
    If they can handle can it, but there are more doubts about the stability of the moving parts. In a F1 car you expect hard turns and not a wobbly jelly, so IMO if using wiper motors they will be rather overcharged. Just my thoughts :)
  8. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    I Understand what you are saying, this is also my thoughts. When i Lifted the cabinet my thought were the wiper motor must perform really well or it will be a failure. The problem is when finding other motors and still want keep a low budget its not really possible if i want to import from US or Canada. Still looking for Eurodealer. ? Freight and Tax :mad:
  9. Pit
    30,482Coins
    What about winches? Cheap and strong (and loud :grin )
    PS: not so loud as it would be a problem.
  10. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Would you be so kind to post a link ? I searched here in Denmark but can only find 230v but is it possible to use 230v with JRK, OR is it really a 12V motor if i tear it down. :)
  11. Pit
    30,482Coins
    I built in a winch like this one:
    http://www.ebay.com/itm/New-2500-lb...Parts_Accessories&hash=item258e807c16&vxp=mtr
    BUT! 2500lb is to0 strong (for any standard h-bridge, max current about 40A and more), the mine is 2000lb and ~30A under load, peak up to 40A. Under full load (2000lb) they could burn up to 90A but this weight will or should never be reached.
    Some photos of the winches I used, but the thread is outdated and I made it differently from what I described in the posting:
    http://www.xsimulator.net/community/threads/2dof-sim-cxc-simulator-by-pit.5276/page-3#post-52485
  12. bsft
    winches would throw it about, and stay with 12v motors, dont try to run a 24v at 12v
    and of course a JRK would move them
    Going back a few steps, the frame looks heavy, wipers would struggle. You need to look at winches for that thing for sure.
  13. Pit
    30,482Coins
  14. bsft
  15. Pit
    30,482Coins
    ah ok sorry. Too much work at the moment and that is why I am distracted...
  16. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    In theory your wiper motors can still move it but you'll need to pivot it quite far away from the balance point.
    Just an idea: why not get rid of the wood on the top and replace it with a fibreglass shell to reduce weight?
  17. eaorobbie
    20,473Coins
    @Pit the Jrks will push your winches just as hard as the monster motor will, and maybe with a little more finer control too.
    But you rig already moves well so disregard my comment. There is no race , ones just simpler.
  18. Pit
    30,482Coins
    @eaorobbie: the "race" between the jrks and the monster motos was only a silly joke, nothing else.
  19. Historiker
    9,208Coins
    Off topic gentlemen. There is a thread for the comparison of various controllers/drivers. :)
    • Old Old x 1
  20. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Well i did cut 15cm from cabinet in lenght. and mounted it again on platform. Did a little test just connected the motor direct to PSU and it ran well. So far im not worried about weight. the motors did really well.
    I can lift the cabinet by my self "Without seat and steering whell offcourse".
    Next time i dismount the cabinet i will try to measure the weight.
    I will thou look for other motors, i can see there are many advantage with larger motors. :)
