eaorobbie
K8055 Interface V1 - 2 DOF Original EXE 2016
K8055 Interface 2DOF
  1. eaorobbie
    20,452Coins
    • Winner Winner x 3
  2. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    Great job Rob thank you very much:thumbs
  3. eaorobbie
    20,452Coins
  4. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    Real quick .... thanks to you eaorobbie and to all the staff of simtools :cheers
  5. auryza
    auryza Active Member
    Lithuania
    4,332Coins
    2DOF, 3DOF, Arduino
  6. eaorobbie
    20,452Coins
  7. auryza
    Lithuania
    4,332Coins
    2DOF, 3DOF, Arduino
    Yes it's ok now ! Thank you very much for help, now my k8055 working perfectly !!!
    I will post later my progress . when i will have more time to play on it .
  8. eaorobbie
    20,452Coins
    Thanks , new app is coming along a little slower but think I better put it away for now and build some instructions for newbies to follow.
    There is a lot going on , on one page, can be a little confusing , hence Im building a more user friendly app, first one is to prove it can be done, without the need for an Arduino. Let the K8055 live long.
  9. Ricardo Moraes
    Ricardo Moraes New Member
    315Coins
    2DOF, DC motor
    Hello everyone, I am new here and have a 2dof ready to Velleman and sybertooh, use the x-sim and am currently trying to understand how to run a simtools. I'm having problems plugin did you install, the error is that it will search the web installation, is helping me?
  10. ferslash
    ferslash Active Member
    4,798Coins
    dear rob:
    in your oppinion is this a better solution that the arduino solution?
    best regards from your mexican frined
    fer
  11. bsft
  12. ferslash
    4,798Coins
    jaja dont worry he will show up, :D
  13. -kevin-
    128Coins
    n fact .... but where is it ?? @eaorobbie :think
    I'm having problems with the application of the right engine someone has the same problem?
    yet time ago when I did the test was affixed ... I do not understand where the problem is.:confused::confused:
  14. Luc1gnol0
    Luc1gnol0 New Member
    Itala, Italy
    246Coins
    grazie ma ho gia visto quella pagina, appena apro il setup "impossibile avviare l'applicazione, contattare il fornitore dell'applicazione"
    150,043Coins
    +10,993 / 54 / -2
    Google translate -
    thanks but I've already seen that page, as soon as I open the setup " impossible to start the application , contact the application vendor "
    Is this on a 64bit machine and if so have you followed the earlier thread advice?
  16. Luc1gnol0
    Itala, Italy
    246Coins
    i have installed the 199.7k version, and i have copy and paste the file in the simtools folder, but dont work the setup.exe and the application... " impossible to start the application , contact the application vendor "
  17. eaorobbie
    20,452Coins
    Do you have the demo program that the K8055 comes with, if this can not access the card then you need to load the drivers for the K8055.
    Please use the updated resource which is just the exe file.
  18. Luc1gnol0
    Itala, Italy
    246Coins
    yes, i have the k8055 demo (green and yellow icon) and the 8055 work with xsim, the problem is only when i open the setup.exe
  19. Dronneau.Y
    Dronneau.Y Member Gold Contributor
    france
    95Coins
    I recently started using Arduino + SimTools and I would like to reuse my old K8055 card, but I do not quite understand what to do for the installation to succeed!
  20. eaorobbie
    20,452Coins
