value1
Microsoft Flight Simulator X / Lockheed Martin Prepar3D Plugin 2.0.2.0
SimTools plugin for Microsoft Flight Simulator X and Lockheed Martin Prepar3D
  1. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    Ok Thank you, I ask because I can never get the FSX to move the Sim, The profiler says game connected. IS there more in the FSX game other then patch that needs done? I have not tried Run as Administrator yet, I however did not get a error on patching?
  2. eaorobbie
    20,491Coins
    Have setup SimTools correctly as in done an axis assignement and setup an interface, without nothing will be present.
    One way to check if data is flowing is to check the GameEngine - Tuning Centre , if values are rolling in the green area then the plugin is working and it will be your setting that are wrong. We need more information to inform you what is actually wrong.
  3. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    I will check values in the green area.
    The motors do center when power on
    I can run the motors from sim tools, using test and changing settings to axis, I can then slide each motor left n right works
    I can run the motors sending commands from Aurduino terminal window.
    Thank
    you
  4. eaorobbie
    20,491Coins
    Ok sounds like a plugin patching issue, another recent issue can be that you may need to run the GameManager under Admin ie right click on the GameManager icon and "Run as Administrator"
  5. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    Update: I get rolling in Green area that seems to match FSX I bank left number get larger right smaller ect. Crash it all stops :) still no movement in motors so there is a settings issue somewhere, Do you have a suggest presets for FSX?
    I can run the motors using AXIS testing no problem, dof testing nothing happens until I change to axis testing
    Both computer say connected and game running like there suppose to.
    there is a section that is axis assignment, sway , yaw pitch ect and 1dof and 2dof ect
    thank you for looking into this
    System:
    Udrino UNO
    MotoMonster
    2 big gear motors
    laptop running Urduino
    Desktop running game
  6. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    I got it working, was the Roll and Pitch over written by the next step in Instructions for setup, IT is now controlling motors with the FSX game,
    Thank you for your HELP! :)
  7. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    Now the motors wont center they just go left/right real fast like its so fast it goes past center and visa versa
  8. value1
    14,180Coins
    153,039Coins
    +11,116 / 56 / -2
    I was just heading off to bed but can't wait to test this update out. Guess it is going to be a very late night for me.
    Thanks so much @value1 :thumbs
  10. minanke
    minanke New Member Gold Contributor
    Developer
    Hong Kong
    - 374Coins
    Need some help. I'm not able to run this plugin with FSX - steam edition.
    I can patch FSX and also copied the "SimTools_GameManager.exe.config" file to the "C:\Program Files (x86)\SimTools" folder
    When I start FSX, the GameManager crashed with this error
    Microsoft .NET Framework error
    Could not load file or assembly "Microsoft.FlightSimulator.SimConnect Version=10.0.60905.0" or one of its dependencies. The system cannot find the file specified"
    Any idea what is this error?
    Previously this FSX - steam edition also have problem with my TrackIR. The solution to make TrackIR work is run this msi once "C:\Program Files (x86)\Steam\steamapps\common\FSX\SDK\Core Utilities Kit\SimConnect SDK\LegacyInterfaces\FSX-XPACK\SimConnect.msi" to re-install the SimConnect. Then the TrackIR work with this FSX - steam edition.
    Mike
  11. value1
    14,180Coins
  12. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    same issue here with the new steam version
  13. value1
    14,180Coins
    So have you tried running *all* the simconnect.msi you find in the installation directory?
  14. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Im at work but I will tonight, I was just reporting that I have steam and it did the same thing.
    153,039Coins
    +11,116 / 56 / -2
    Thanks go again to @value1 for tracking down the fix, it does indeed work with Prepar3D so I expect it will with FSX.
    Once you get it running do try out @value1's other recent plugin innovation and use Extra 2 in place of roll. With the Rift it is a far more of a natural motion simulation, particularly with jets and other aircraft capable of very fast roll rates.
  16. minanke
    Developer
    Hong Kong
    - 374Coins
    Thank you very much, Value1.
    The steps you provided are able to fix this FSX problem.
    Those installer are under this folder
    D:\Program Files (x86)\Steam\steamapps\common\FSX\SDK\Core Utilities Kit\
    Mike
  17. minanke
    Developer
    Hong Kong
    - 374Coins
    Hi Noorbeast, Thanks for your advice, I'll try using extra 1 as roll and see how it feel.
  18. noorbeast
    153,039Coins
    +11,116 / 56 / -2
    I will be interested in how you find it @minanke, compared to the traditional roll where the rig flicks from one side to the other quickly half way through the roll. Just note it is Extra 2, not Extra 1.
  19. minanke
    Developer
    Hong Kong
    - 374Coins
    I tried using the Extra 2 as roll, but I can't get any motion from Extra 2. Are you using version 3.0.1.1?
  20. value1
    14,180Coins
    Have you assigned the values to the respective axes for the FSX_P3D plugin?
    And do you see at least changing data in Tuning Centre?
