shiftknob+brake shock
Discussion in 'DIY peripherals' started by kon, Jul 29, 2014.
  1. kon
    kon New Member
    234Coins
    hi im new here and want to ask for some help. i machined my shift knob from my g25 to house a mini-motor from a cellphone to have shock. my question now is how can i make it work at certain rpm? i think i will need a plugin, and somehow a way to connect it to make it function... but how?
    same goes for the brake but i havent put a motor on the pedal yet.
    here are some pics(not very promising soz i will take higher res ones) that will give you an "image" of the build: [​IMG]
    the sim i use(and want to continue use) is rFactor
  2. bsft
    bass shaker support is yet to be done, and this could work, just not yet.
    Maybe you could use a motor controller and an axis off simtools to make is spin, but thats about it at this stage.
    No I dont know how.
    Cheers, David.
  3. kon
    kon New Member
    234Coins
    i have tested the voltage of it and seen that around 0,8 to 1,3v it has a very good feeling for idle rpm, while at around 3v it has a good feeling for rev limiter or also it can start 500-1.000 rpm before limiter. i was also thinking that an easy way to make it function will be to wire them through a led indicator(like the ones the g27 uses). for example 1voltage constant and when the leds flash the voltage will raise to 3. but i dont have a g27 i have a g25 and i need to build a led indicator to make them work. if anyone has a link of a diy rpm light i would be grateful.
    151,467Coins
    +11,039 / 56 / -2
    It certainly is a neat idea kon.
  5. kon
    kon New Member
    234Coins
    yep but without some help it will stay on the shelf at it was sitting for over a year now... so PLEASE if anyone can help im even interested in donating his engage ring for his wife :D +beers and condoms for a year all free :p
    • Funny Funny x 2
  6. bsft
  7. kon
    kon New Member
    234Coins
  8. eaorobbie
    20,473Coins
    How did you go ? Any progress.
  9. kon
    kon New Member
    234Coins
    not any progress at all as i just have migrated to germany and i dont have tools, my notes nor any free time. but for until i find spare time i read some posts here and there cause i want also to build a moto controller( http://forum.piboso.com/index.php?topic=1195.msg14426#msg14426) as far concerning this upgrade i have purchased the dx tm1638(http://www.dx.com/p/jy-mcu-8x-red-light-digital-tube-8x-key-8x-double-color-led-module-104314) and im planning on making the shock function everytime the leds need to light on(meaning closing to rev limit). can someone tell me which way im going to get those information from the sim? arduino chipsets do so?
  10. RacingMat
    21,039Coins
    Hi @kon
    You have to use GameDash software: go to FAQ ;-)
    I wrote a tutorial about Rev light: look for 7 segments 12v gear indicator (i can't search the link with my phone)
    Yours
    Mat
  11. kon
    kon New Member
    234Coins
    i cant find that tutorial your talking about. :sos
  12. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
  13. kon
    kon New Member
    234Coins
  14. RacingMat
    21,039Coins
    Thanks @insanegr !
    @kon :
    if you read it carefuly, you will see that you can get the RPM from the game through GameDash companion app of Simtools.
    Once you get the RPM, you can light on the rev light whten it reaches the level you want.
    Yes Arduino can do the job
    Yours
    Mat
  15. kon
    kon New Member
    234Coins
    One moment please. So far i have bought a tm1638(http://www.dx.com/p/jy-mcu-8x-red-l...x-double-color-led-module-104314#.VFC0VldERAo) so i guess next thiing to buy is a way to connect this board to another board with a usb on. but ive found numerous different forums here and there pointing at 2 arduino boards. the nano v3(http://www.dx.com/p/nano-3-0-atmel-...d-w-usb-cable-for-arduino-152052#.VFCx71dERAo) and the uno rev3(http://store.arduino.cc/index.php?main_page=product_info&products_id=195) so which one of the two is the right one? sorry i cant read all you have written on your forums cause i dont know a little about electronics its like reading chinese. but i can understand the basics. can someone also tell me if its easier just to buy this (http://www.symprojects.com/shop/spi-d-digital-speedometer/) whats the pros and cons?
  16. RacingMat
    21,039Coins
  17. kon
    kon New Member
    234Coins
    which of those 2 must i buy after? have they got any difference?(http://www.dx.com/p/arduino-nano-v3...affiliate&utm_medium=dealextreme#.VFDN9ldERAo) or this one(http://www.dx.com/p/nano-3-0-atmel-...d-w-usb-cable-for-arduino-152052#.VFDOU1dERAp)
    also i cant find the tutorial, u mean the posts eaorobbie wrote on the gamedash dl page? its on the discussion tab.. these ones?
  18. RacingMat
    21,039Coins
  19. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
    here is @eaorobbie tutorial http://www.xsimulator.net/community/threads/tm1638-multiply-page-display-with-gamedash.5003/
    have tried it with an original uno rev3 and works perfect with a tm1638 like the one you have(blue pcb)
    and tried it also with an arduino nano v3 and cant make it work.i can see the logo when i connect it to the pc or press reset button ,
    but when i open a game my display stays black suppose my settings are ok as i can see nano's led (rx if i remember right)
  20. kon
    kon New Member
    234Coins
    yes i follow this exactly thread of eaorobbie. i will come with more results when all parts come to my hands. one more question please, is this the same like the uno r3 of the official site? or is it a cheap copy or something? http://www.ebay.com/itm/UNO-R3-Deve...570?pt=LH_DefaultDomain_0&hash=item258d976672 compared to the original http://store.arduino.cc/product/A000066
