Arduino Uno crashes
Discussion in 'SimTools compatible interfaces' started by doctorxeno, Aug 5, 2014.
  1. doctorxeno
    doctorxeno Member
    607Coins
    Hi guys,
    I am 1 step away of finishing my simulator. When its all done and works flawless I will post it.
    Have only 1 problem to overcome. I am doing tests with Race07. The simulator runs fine, but with hard bumps or crashes my arduino crashes.
    When I reset it and close and open Simtools engine and manager it runs fine again.
    What could this be?
    The pots and motorcontrollers get their 5 volts from arduino. 12 volts come from car battery that is charged by a atx powersupply. Arduino powered by USB. Because when I use external power and USB is disconnected and simulator is on 1 motor starts spinning. That problem is not present when I use only power through USB.
    Using pololu 18v25 motorcontrollers with xsimctrl2.2 (prilad). Hall effect 10k pots and arduino uno
    What I do know is when I set KP parameter lower then the problem does not occur, but the simulator
    gets to soft.
    Hope you guys can help me out here.
    Jeroen
  2. Pit
    30,490Coins
    IMO not an Arduino related problem, the bridge shuts down due to the high load.
  3. prilad
    Dubna, Russia
    9,657Coins
    3DOF, DC motor, Arduino, 4DOF
    Hi, doctorxeno.
    It looks as if the "high current" pulses makes interferences.
    This is the eternal theme of protection from interference. I prefer to use galvanic isolation.
  4. Pit
    30,490Coins
    ....if a galvanic isolation is not available at the moment, try out a separate notebook where Simtools is installed to avoid any influence for testing with, if I am not at fault, perhaps @prilad would kindly confirm this testing method.
  5. prilad
    Dubna, Russia
    9,657Coins
    I think @doctorxeno have PC (not notebook) with game.
    And I agree with @Pit - you can try to connect Arduino to notebook instead PC. And try to test SIM in this configuration.
  6. TecRacer
    TecRacer New Member
    275Coins
    It could also be a COM port related problem. Maybe the Arduino somehow draws to much current on the USB port. Just a little thought.
    I could be completely wrong, but hey, i'm learning from my mistakes :nerd:grin
  7. doctorxeno
    doctorxeno Member
    607Coins
    I use a USB galvanic isolator.
    I am thinking it is something like that. Maybe use the 5v supply from ATX to power pots and controllers?
    The USB isolator has also a power jack. Is it an option to connect 5v to that jack?
  8. RacingMat
    21,047Coins
    hello!
    can you share a link about your galvanic isolator and your wiring?
  9. doctorxeno
    doctorxeno Member
    607Coins
  10. doctorxeno
    doctorxeno Member
    607Coins
    Well I found the problem. I had to set the KP parameters to a lower value and I have increased the minPWM. Now it keeps running.
    I will do some more testing for a while...
    Thanks for all the replys.
    Jeroen
  11. doctorxeno
    doctorxeno Member
    607Coins
    My simulator is running fine now. Have made profiles for a few games. Now I am playing and fine tuning for
    a while. Soon there will be a new project to be seen on the forum.
    Thanks all
