New Sim Idea
Discussion in 'Commercial Simulators and Peripherie' started by telfel, Aug 11, 2014.
  1. telfel
    telfel Active Member
    4,739Coins
    • Creative Creative x 2
  2. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    That's ambitious!
    153,824Coins
    +11,150 / 57 / -2
    If it worked I imagine it would be cool for flight sims, but not so much for racing.
  4. riton
    riton Active Member
    1,006Coins
    in the past, a member has already made a simulator in a sphere
    I did not find image
    153,824Coins
    +11,150 / 57 / -2
    Do you recall how it was driven? I would think a sphere gives pitch and roll but lacks heave and bump type simulation.
  6. AceOfSpies
    19,614Coins
    The lack of heave and bump would be provided by a good motion profile with low numbers in the " Tuning centre" and in "Axis Assignments". This is assuming that the sim is well balanced.
    Mike :thumbs
  7. RaceRay
    Hamburg, Germany
    23,884Coins
    Looks comfortable. Definitely the winner for a design-furniture contest...and yes, very ambitious, but not so bad at all.
  8. traveltrousers
    traveltrousers Active Member
    Timbuktu, Tombouctou, Mali
    890Coins
    Thanks for the kind words guys.
    Heave will be an optional add on once the base unit is working and there is plenty of room for tactile transducers.
    I'm also running a raffle on the site to help drum up support for the Kickstarter, so put in your name and you can win one!
    153,824Coins
    +11,150 / 57 / -2
    Hi traveltrousers.
    You may want to pose some of the questions on your website to this forum, such as motor options, as there are some exceptionally knowledgeable and helpful members here.
  10. traveltrousers
    890Coins
    Yeah, it's a good idea. Now I'm sure the panels are affordable I've started looking more at the motors and there are a million options.
  11. traveltrousers
    890Coins
  12. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    Ciao @traveltrousers
    Una piccola descrizione sarebbe gradita della foto che hai messo:)
    Cos'è una trasmissione a catena con rulli... e come funziona?
    Puoi spiegare anche cosa sono i trasduttori tattili?
    Hello @traveltrousers
    A small description of the picture would be appreciated that you put :)
    What is a transmission chain with rollers ... and how does it work?
    You can also explain what are the tactile transducers?
  13. traveltrousers
    890Coins
    Um, sorry :)
    It's an idea to rotate my sphere, instead of using omniwheels I mount a series of rollers to a regular chain, which massively increases the traction for very little cost...
    A tactile transducer is a speaker that doesn't produce noise but rather low fequency vibrations, such as a 'buttkicker'.
    http://en.wikipedia.org/wiki/Omni_wheel
  14. -kevin-
    128Coins
    Ah.. quindi sarebbe una buona soluzione e anche economica.:thumbs
    Mi sà che da un pò di tempo mi sono dimenticato come si fà la ricerca su google.... buttkicker :grin
    Però non vedo come farai a simulare il sollevamento e l'urto con un trasduttore tattile..:confused: non credo che si ottiene la stessa sensazione.. va bene per avere le vibrazioni del cambio o del motore ma non credo per il sollevamento ed urto questo almeno e quello che penso io.;)
    Ah .. so it would be a good solution and also economic. :thumbs
    I knows that some time ago I have forgotten how to search on google .... Buttkicker :grin
    But I do not see how you're going to simulate the lifting and collision with a tactile transducer ..:confused: I do not think you get the same feeling .. okay to have the vibration of the gearbox or engine but do not think for lifting and impact and this at least what I think .;)
  15. traveltrousers
    890Coins
    Yes, but heave motion is 'expensive' as you need powerful motors to lift the platform. I will add this as an optional add on when the platform is successful.
  16. -kevin-
    128Coins
    Era quello che non riuscivo a capire... come facevi a simulare il sollevamento... quindi una struttura apparte optional :thumbs scusami ma ne tradurre il testo avevo capito male.;)
    It was what I could not understand ... how did you simulate the lift ... then a structure belonging optional:thumbs I'm sorry but I translate the text I had misunderstood. ;)
  17. traveltrousers
    890Coins
    I've been working on the base concept.
    I will probably add a couple of omnichains to control yaw too...
  18. noorbeast
    153,824Coins
    +11,150 / 57 / -2
    It certainly is an interesting approach, do you plan doing a working model prior to a prototype?
  19. traveltrousers
    890Coins
    It will probably be several.... I guess I need to lock in the design first :p
  20. bsft
    groovy design
