1 DOF Motion simulator
Discussion in 'New users start here - FAQ' started by Thomas Harvey, Aug 15, 2014.
  1. Thomas Harvey
    Thomas Harvey New Member
    110Coins
    DC motor
    Hi Everyone,
    I am thinking of making a motion simulator but am overwhelmed by the amount of information I have found on the internet.
    I want to build a 1 dof machine that reads te lateral g force of a game and effects the pitch of the platform.
    I am thinking of 2x dc motors, 1 for each side of the platform. I get the idea that I will need to connect these to a dc ac converter and then pass it through a relay card and then on from there to the PC via USB.
    the pc will have some sort of motion software to control the motors.
    My questions are how do I choose the relay card ? how do I wire it up? Do I need it to be an intelligent system, (I only want the motor to move to a position based on the lateral force output).
    Any help and direction would be greatly appreciated.
    Thanks,
    Thomas
  2. bsft
    one 12v12 JRK and a feedback pot on the motor is the simpler and easier option for any DOF.
  3. Thomas Harvey
    110Coins
    DC motor
    Thanks for your reply
    Do I need a feedback pot? I only want the motor to move a set of predetermined steps based on the lateral force output.
    I have a andruino uno board and a H-bridge.
  4. value1
    14,236Coins
    Yes, you need a closed loop/feedback, i.e. potentiometer. Otherwise the position will be out of sync in no time.
    Check this post and this of @eaorobbie where he explains how to connect the software with the hardware and motors.
    The general principle is the same for arduino and jrk.
  5. Thomas Harvey
    110Coins
    DC motor
    Thanks for taking the time to reply, this is what I need.
  6. ferslash
    ferslash Active Member
    4,798Coins
    my two cents... if you feel you can invest some time, and complicate your self a little bit with electronical stuff... you need two motors, two pots, one arduino uno and a motor driver card to connect it to the arduino and the motors. (there are some of the shelve motor driver options)
    i you want a quick simple, and grate solution, then you two jrk12v12 cards, sold by the pololu company, two pots and two motors, each jrk card will costo you around 99 usdlls. but they works just grate and are so so simple to use and instal...
    ** consider that this options we are talking here, are to construct a two degrees of freedom simulator (wich is kind of the simplest, you mentioned only one degree of freedom, but maybe it is not such a good idea, but... if you insist, in only one degre of freedom, then you only need one motor, and one jrk)
    ** also consider that the simple way of constructing your first sim is using dc 12v motors, some of us even use car wiper motors... if you want to use ac motors then you will have to spend a lot of money and deal with a different set of electronics (but of course it can be done)
    ** lastly... this forum is full of grate guys willing to give you a grate advice, some of them have been constructing sims for ages and had try a lot of ideas ans designs... it is a good idea to ask them so you can avoid common mistakes.
    best regards from mexico
    fer
  7. Thomas Harvey
    110Coins
    DC motor
    Thanks for your replies everyone. Really helpful
    After this I am going to go for the 2dof motion. Can you recommend specific brands of the motor driver card please?
    Thanks,
    Tom
  8. bsft
    http://www.pololu.com/product/1393 , one per motor, 7 wires, one usb, NO CODE TO WRITE.
    Will run 14v at 30 amps continuous all day with heat sink and fan cooling.
    In fact, some of us spike them at 40 amps no problem.
  9. shanothegreat
    shanothegreat Member Gold Contributor
    Technician
    Melbourne, Australia
    496Coins
    2DOF, DC motor, JRK, SimforceGT
    I'm with bsft here, stick to the jrk, with a good balance on the platform and a spring to counteract backlash you will be on a winner.
  10. bsft
    a LIGHT duty spring to create a LIGHT load against the motors IF NEEDED.
  11. Thomas Harvey
    110Coins
    DC motor
    I have bought some parts just so i can test a small setup. as below.
    I have looked at most of the tutorials on line on how to wire all this up but dont seem to be getting anywhere. everytime i plug the funduino board into my laptop, the laptop switches off completely.
    Here are the parts and how I wired them together. Any help or guidance please.
    Thanks,
    Tom
  12. eaorobbie
    20,502Coins
  13. Thomas Harvey
    110Coins
    DC motor
    Yes a model first of all and then step it all up when i understand it all a bit more.
