No motor movement at all
Discussion in 'New users start here - FAQ' started by marky000, Aug 26, 2014.
  1. marky000
    marky000 New Member
    306Coins
  2. value1
    15,082Coins
    Hi @marky000
    First of all: Are you getting data in Tuning Window?
  3. prilad
    Dubna, Russia
    9,663Coins
    3DOF, DC motor, Arduino, 4DOF
    No, @value1 and @marky000 ;)
    At first - what Arduino sketch do you (Marky) use? Send us your code, please.
    May be your code can't receve data from PC?
  4. eaorobbie
    20,488Coins
  5. marky000
    marky000 New Member
    306Coins
    The sketch data I used to get some motor movement in Arduion IDE is at the bottom of this page http://arduino.cc/en/Tutorial/DueMotorShieldDC
    However, I saw no reference to providing sketch data in the Simtools Quickstart guide so I am curious why you ask this question.
    I was under the impression that the slider test in Game Engine should generate some motor movement without the need for any Arduino sketch. That was how I interprated the Quick Start Guide anyway.
    I am a novice when it comes to sketch code so at this stage I am happy to just get some random motor movement in Sim Tools (as I was able to achieve via Arduino IDE program).
  6. marky000
    marky000 New Member
    306Coins
    Glad you asked. Problem was I couldn't find the "tuning window". I assumed it was accessed under Game manager but couldn't find it. Found nothing in FAQ about it as well.
  7. bsft
    its under game engine, along with settings
  8. marky000
    marky000 New Member
    306Coins
    Can you be more specific? I have had a look in Game Engine before but I have not seen something referred to as the Tuning Window. I only know of the Output testing window with the sliders which did not work for me.
  9. prilad
    Dubna, Russia
    9,663Coins
    Hi, @marky000 . Let me briefly instruct you on the work of the simulator.
    "Data flow" from game to motors is..
    1 - SimTools with specific plugin extracts motion data from your favorite game.
    2 - SimTools recalculated "motion raw" data into "axis" data and sends it to motion controller ( SimAxe, Arduino, JRK ets.)
    3 - Motion controller receives data and makes control values for motors.
    Very important thing - motion controller should understood format data are sent from SimTools.
    If you use Arduino as motion controller, you should upload to arduino special "sketch" which can receive and decode data packet from SimTools.
    You can found an example of sketch there:
    http://www.xsimulator.net/community/marketplace/arduino-code-2dof-and-2-pins-direction-hbridge.67/
    Moreover sketch must be configured so that the desired signals received on the appropriate controller's pins.
    Regards,
    prilad.
  10. marky000
    marky000 New Member
    306Coins
    Thanks for explaining.
    Am I right in say that "motion raw" = DOF?
    Just so I am getting the terminolgy right here.
  11. prilad
    Dubna, Russia
    9,663Coins
  12. marky000
    marky000 New Member
    306Coins
    From Wikipedia:
    Six degrees of freedom
    The motion of a ship at sea has the six degrees of freedom of a rigid body, and is described as:[2]
    Translation:
    1. Moving up and down (heaving);
    2. Moving left and right (swaying);
    3. Moving forward and backward (surging);
    Rotation
    1. Tilts forward and backward (pitching);
    2. Swivels left and right (yawing);
    3. Pivots side to side (rolling).
    So I guess I was right :) DOF = Motion Raw Data
