My 2Dof Wiper Sim
Discussion in 'DIY Motion Simulator Projects' started by mracs, Aug 30, 2014.
  1. mracs
    mracs ...
    Indonesia
    1,766Coins
    Hello, i'm new here
    I like to show my homemade racing sim
    it's use arduino UNO and 12v car wiper motor.
    i would like to test it with simtools. i read @RacingMat tutorial and will use it
    thanks in advance
    here's the picture
    I don't know if i make it right
    sorry for my bad English.:grin
    153,758Coins
    Your English is fine @mracs and thanks so much for the pictures...it looks like you have done a great job :thumbs
    I am sure we will all look forward to a video once you have Simtools up and running. There are some really clever and helpful people on this forum so please do post any questions you may have.
  3. mracs
    mracs ...
    Indonesia
    1,766Coins
    thanks @noorbeast :)
    I will share my video when its already running
  4. RacingMat
    21,081Coins
    Very well done mracs! it's really a beautiful simulator!! :thumbs
    I'm glad to know that my tutorial was hepful ;)
  5. mracs
    mracs ...
    Indonesia
    1,766Coins
    thanks mat
    yeah your tutorial was very helpful
    i also use your code for my arduino:thumbs
  6. eaorobbie
    20,502Coins
    So any issues or you are up and running ?
  7. mracs
    mracs ...
    Indonesia
    1,766Coins
    @eaorobbie thanks for your concern.
    I've tested it with lfs, my motor running with no issues
    but I'm still learning to setup the axis
  8. mracs
    mracs ...
    Indonesia
    1,766Coins
    here's my video
    test assetto corsa with simtools:)
    what you guys think?
    153,758Coins
    Great to see your rig up and running @mracs :thumbs
  10. RacingMat
    21,081Coins
    Hi!
    The amplitude of movement are a bit too small IMO.
    What is your lever length?
    Maybe you can use the tuning center or Game Engine to calibrate greater movements?
    It's up to your feeling and needs ;)
  11. bsft
    motion looks good, maybe some refinement, but that is learn in time and also personal preference.
    However, I can see a lot of twist in that frame. A draglink setup to help stop the twist would improve the motion feeling.
    Also, maybe try @RufusDufus or @prilad codes as well. They are more complicated, but you may get a better result again,
  12. mracs
    mracs ...
    Indonesia
    1,766Coins
    hi @RacingMat do you mean this length?
    I lowered settings. i use 60% in game manager.
    thanks @bsft, you're right, It feel much twisted. I will arrange to put the draglink
    i will try that code, to see the difference:thumbs
  13. RacingMat
    21,081Coins
    yes! 65mm and 60%
    interesting information !
    Have pleasure driving your sim, you deserve it!!
  14. bsft
    I had a thought, you could attach a wiper to the drag link and give yourself a bit of "drift" in the frame.
  15. mracs
    mracs ...
    Indonesia
    1,766Coins
    hi bsft , i don't get it :grin do you have a example to do that?
    thanks
    • Dumb Dumb x 1
  16. bsft
    a drag link is a rod with ball joints (rod ends) on it to help stop twist. I though maybe put a drag link on on corner at the back and attach it to a motor, and run "yaw" force through it.
  17. mracs
    mracs ...
    Indonesia
    1,766Coins
    thanks a lot for the explanation bsft. :thumbs
    I will try to apply it with my simulator.
    but does it matter if I put it in the front of the simulator? I have an empty spot there
  18. bsft
    front or back, it was just a suggestion thats all, could be interesting to add it seeing you already have frame twist, why not add a drift bit to it.
  19. mracs
    mracs ...
    Indonesia
    1,766Coins
    okay man. I will work on it :)
    thanks for your help
  20. eaorobbie
    20,502Coins
    Should try to run the Game Manager at 100%.
    Axis Assignments % when totalled per Axis should not exceed 100% too.
    Then once in the game use the Game Engine - Tuning centre and modify the Min Max values, all simulators are different in build so this needs to tuned in for your simulator and to the amount of movement you want too.
    If movement for example of Roll in 6,6 for Min Max and the sim seems to roll around heaps then you increase the values and it will not reach the extremes of the Axis setting as quick.
    When tuning I turn off all forces except the one Im testing in game so not to confuse any other movement with the one Im testing.
    Im sure with proper tuning and fixing the twist with a link setup it will be fine on the code its running.
    Overall love seeing another dream coming true, Top Work.
