problem with dirt3
Discussion in 'SimTools Plugins' started by vulbas, Sep 14, 2014.
  1. vulbas
    vulbas Active Member
    france
    1,103Coins
    AC motor, 6DOF
    hello,
    I patched the game but my sim does not move.
    I changed the line. <motion enabled = "True" ip = "127.0.0.1" port = "4123" delay = "1" extradata = "0" /> this is ok? the software starts up but no movement
    thx for your help
  2. value1
    14,237Coins
    Hi @vulbas
    There come two different files "hardware_settings_config.xml" with Dirt:
    1. in C:\Programs\DiRT 3\system. That's the wrong one ;)
    2. in C:\Users\"vulbas"\Documents\My Games\DiRT3\hardwaresettings. That's the right one.
    Did you patch the second file?
  3. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    i patch C:\Users\sebjeux\Documents\My Games\DiRT3 that's correct ?
  4. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    if I try C: \ Users \ sebjeux \ Documents \ My Games \ DiRT3 \ hardwaresettings
    it does not work
    i patch C:\Users\sebjeux\Documents\My Games\DiRT3 and that's ok, but simlator don't move :(
  5. prilad
    Dubna, Russia
    9,666Coins
    3DOF, DC motor, Arduino, 4DOF
    Try to disable Firewall and Antivirus. And try to run SimTools with "administrator" rights
  6. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    I tried but the problem is the same.
    same problem with wing of prey
  7. value1
    14,237Coins
    Open the system tray (bottom right corner) and right-click on the Game Engine icon.
    There will be a list with Tuning Centre and Settings. Click on both to open both windows.
    Check you axis settings in the GameEngine.
    Select Dirt3 from the Game List and load All Out from the Presets.
    Click on Save Settings.
    When the game runs and GameManager and GameEngine run, you should see data in the Tuning Centre, "Game Running" in the GameManager and "Axis Assignments" and "Interface Settings" blued-out
  8. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    yes it turns blue. the simulator moves into position. but there is no info that moves in tunning center.
    same with wing of pray
  9. prilad
    Dubna, Russia
    9,666Coins
    Are you shure your interface setting is correct?
  10. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    I think. it works with GTR2 and rfactor
  11. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    but simulator don't move
  12. value1
    14,237Coins
    Sorry, I missed that but you need to have *some* interface setting in the GameEngine.
    Something like this:
    Please show us your interface settings and axis assignments for Dirt3 and Wings of Prey.
  13. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    it works with GTR2 and rfactor. I test the axis and dof and it works
  14. value1
    14,237Coins
  15. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    I just tested with FSX, it works.
  16. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    oops, i did not see the need to review the 1.0.5.1 version of prey wing. now it works
    I'm sorry.
    requires a particular version for DiRT3?
  17. value1
    14,237Coins
    Any version of Dirt3 will work. It might be useful, if you share your settings for Dirt3 as well like you did for Wings of Prey.
  18. bsft
    @vulbas , try completely uninstalling dirt3, deleting the files out of "my games" folder , the dirt3 ones that is. Then try re-install, teh play a few races static to create some saved games.
    Also with dirt3 plug in , try deleting it from simtools game engine folder the plugins live in, the re-install the WHOLE zipped plugin.
    The re-patch the game.
    It does work as I have run genuine and cracked versions of the game on Win 7, 32 and 64 bit pcs.
  19. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    thx bsft
    i'll test tomorow
  20. bsft
    oh and dont change the line of code yourself, just leave it. The patching fixes that
