Plug Installed successful but don't appear in game list?
Discussion in 'SimTools Plugins' started by floripaoliver, Sep 14, 2014.
  1. floripaoliver
    floripaoliver New Member
    What? Do I need to work?
    Brasil
    34Coins
    2DOF, SCN5
    Hi eveyrbody,
    What I am doing wrong? I downloaded some game plugins and used the drag&drop function to install them in my Game Manager. I did also get the message "Successfuly installed" or some similar message, how ever when I close the plugin manager and open my game manager the game does not appear in the list.
    what I am missing here?
    thx
  2. Pit
    30,490Coins
    Do you use two separate PC's?
  3. value1
    15,032Coins
  4. floripaoliver
    Brasil
    34Coins
    2DOF, SCN5
    I not even get so far that I could patch anything. I try to simple install the plugin from DCS. I drop the file into the Drag&Drop box, get the message successful installed but in my Game Manager I cant select/choose anything else as the original LFS. (thx for your help)
  5. floripaoliver
    Brasil
    34Coins
    2DOF, SCN5
    Nobody with any tip in days? this is not what I expected... :(
  6. value1
    15,032Coins
    Have you tried to run the updater in Admin mode first and then the GameManager in Admin mode?
    Please check, if the DCS_plugin.dll is in the subdirectory C:\Users\YourName\AppData\Local\SimTools\GameManager\Plugins (or similar).
  7. yobuddy
    51,037Coins
    "I downloaded some game plugins and used the drag&drop function to install them in my Game Manager"
    Are you using the Plugin Updater?
    You don't install them with the game manager is why I ask...
  8. Claudemir
    33Coins
    Olá, meu amigo!
    Estou tendo um problema com o instalador de blugins.
    Depois que eu formatei meu computador istalar os blugins jogos não concigo!
    gerente no jogo da forma como o jogo, mas encontra não dizer nada.
    Seus plugins intalar manualmente?
