Request (Feature) Simtools isn't working with rFactor 2 x64
Discussion in 'SimTools DIY Version' started by Rinus janssens, Jul 24, 2014.
  1. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    Is Simtools going to be compatible with rFactor 2 x64 build 798 and the new map structure ?
    Game Manager search for the map where the launcher.exe is in and then place the plugin in the totally wrong map.
    When I replace the plugins to the originally correct map Simtools still isn't working.
  2. eaorobbie
    20,491Coins
    Sounds like a fix is needed , Need to pass that onto the maker @value1
  3. value1
    14,173Coins
    Thanks @Rinus janssens for letting me know! :thumbs
    I have updated the plugin and it now works with the old builds as well as the new.
    You can find the plugin here.
    • Winner Winner x 3
  4. Matthias Griese
    Matthias Griese New Member Gold Contributor
    - 12Coins
    For me the new build 798 and xsimulator the motion is not running. I patched the game in the main rfactor2 folder. I hav no motion. What is my mistake?
  5. value1
    14,173Coins
    @Matthias Griese: When you start the race, do you see the plugin icon in the upper left corner?
  6. Matthias Griese
    - 12Coins
    No i dont. In the older build i saw it.
  7. value1
    14,173Coins
    Try to remove the patch
    and patch again
    Maybe run GameManager in Admin mode when patching.
    Only when you can see the plug in the upper left corner, you will be able to see data in SimTools.
  8. Matthias Griese
    - 12Coins
    Thank you. I will try it soon. The patch path is still the rfactor2 main folder right?
  9. Rinus janssens
    Holland
    2,153Coins
    SCN5
    Did you do a complete new clean install with rFactor2 ot are you using the update feature in rFactor2 ?
    If you did update rFactor2 with the updater try a clean install first then try to patch the fresh install again with sim manager.
    Do you have the latest 64x plugin ?
    BTW I use a triple screen setup and when I apply the bezel correction I don't see the plugin icon in the upper left but the plugins are still working after the usual 15 seconds.
