6 DOF from one Arduino?
Discussion in 'SimTools compatible interfaces' started by DDU, Sep 21, 2014.
  1. DDU
    DDU New Member
    Melbourne
    908Coins
    I know very little about the Arduino, so it would be great if someone more knowledgeable could confirm/deny/discuss.
    The Arduino has 6 PWM pins, so you could drive 6 servos, right? So with the right code, you could have it control a 6 DOF sim?
    If yes, what low cost driver could accept the PWM signals and be used to drive 12v DC motors?
  2. eaorobbie
    20,487Coins
    mmm A Jrk 12v12 can be driven with an RC pulse. Was the way I first used them back in 2009, two Jrks hooked to a usb servo controller.
    Then discovered I could talk to them directly with USB commands.
    Opps sorry your looking for a low cost driver.
  3. RacingMat
    21,059Coins
    Driving many servos with arduino is no problem:
    you're right a single PWM pin per servo is enough.
    you even have dedicated board
    https://learn.adafruit.com/16-channel-pwm-servo-driver/overview
    yes, but a miniature scale simulator only. You can find some examples in the forum.
    here a 4DOF gSeat with servos from @Schluzu http://www.xsimulator.net/community/threads/ultraforce-gs-4-diy-software.5280/
    but if you want to drive 12V DC motor, they are not servos!
    For these, you need power and H-bridges
    or you can buy 12 DC servos but it's probably expensive.
    Do your sourcing and share back the results with us!
  4. DDU
    DDU New Member
    Melbourne
    908Coins
    How does the Arduino control the servos? Is the PWM signal like a standard RC servo signal? If yes, an ESC can accept RC servo signals, so can we use a bi-directional ESC to drive the 12v DC motors?
  5. RacingMat
    21,059Coins
    You can start by googling a bit and bringing answers rather than questions ;)
    Here are some answers
    http://dronesandrovs.wordpress.com/2012/11/24/how-to-control-a-brushless-motor-esc-with-arduino/
  6. RacingMat
    21,059Coins
  7. DDU
    DDU New Member
    Melbourne
    908Coins
    Thanks mat.
    I googled for some time, and used many different terms, but the info I found was not very clear. I understand how an ESC works - I'm just asking if it's suitable for this or is there a better solution?
  8. eaorobbie
    20,487Coins
    Im in the middle of finishing off code for a K8061 to run 3x sabertooths to run a 3 to 6 dof sim off one cheap controller.
    No code will be require by the user like in my existing K8055 application that successfully controls one Sabertooth.
    BTW Mat did you finish your Ard code to run a Sabertooth, your existing code fails.
  9. DDU
    DDU New Member
    Melbourne
    908Coins
    Clearly you guys are more knowledgeable than me when it comes to this stuff, so I'll just throw another idea out there. Forget the ESC for now.
    As a single Arduino can already control 6 x servos, can we unhook the servo output from the small motor that is inside the servo, and hook it up to a driver to amplify the signals to run a large 12v motor?
    If yes, this would make a very cheap 6DOF controller.
  10. eaorobbie
    20,487Coins
    Can be done.
    Here's a video of it. I heavily researched it before finding the Jrks in 2009.
  11. DDU
    DDU New Member
    Melbourne
    908Coins
    Thanks for the vid Rob! Looks like it is indeed do-able.
  12. RacingMat
    21,059Coins
    Unfortunately, it is still a Work In Progress and I haven't finished it. Maybe one day someone could start from this and finish it...
