Resolved Game Manager Closes / Crashes
Discussion in 'SimTools DIY Version' started by MasterYoda, Oct 7, 2014.
  1. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Guys,
    I have been struggling with this problem today.
    Don't remember it happening before.
    But, today, running either GSC or AC, the Game Manager closes by itself after 2 minutes of game play or so.
    On GSC, it gives no msgs, just closes itself silently.
    But, on AC, it gives the following error, no details:
    Game engine keeps running:
    Things I tried:
    . Re-installed 1.2 (keeping my settings).
    . Changed USB ports speed down to 9600 (based on other treads).
    Neither helped.
    Tried other things like killing other processes, etc.
    Windows 8.1 64bits
    SCN5
    Any help is appreciated!
    Thanks.
  2. frenchfly
    frenchfly Member
    Mold Maker
    Winnipeg, Canada
    - 344Coins
    2DOF, JRK
    I've been having this problem also, sometimes I can go for a long time with no problems and other times it happens a few times in a row. Only this that fixes it is a reboot for me.
  3. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Tried several reboots, nil fix.
    Just tried another SimTools install, from scratch, didn't keep any settings.
    Set up all from zero (pain in the neck), still same problem! :-(
  4. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Maybe, it is related to some Windows 8.1 update... Hard to tell!
  5. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    I have had this happen a few times and I am running win7 ultimate 32bit. It usually stops working with no notification. Maybe @yobuddy could look into this as a possible bug!
  6. frenchfly
    frenchfly Member
    Mold Maker
    Winnipeg, Canada
    - 344Coins
    2DOF, JRK
    I am running Windows 7 64bit, I forgot to mention that.
  7. Nick Moxley
    Crashes for me too on Assetto when exiting a track.
  8. yobuddy
    51,037Coins
    What is the output packet rate to the SCN's?
    We just need to narrow down where to look for the problem...
  9. Nick Moxley
    No SN5 over here.....
  10. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Yobuddy,
    I have them at 10ms, but I never touched that as far as I can remember, that is the value I have since first Simtools installation...
    I recently updated my plugins as AC had stopped working. And, I don't remember having this issue before that. :-(
  11. yobuddy
    51,037Coins
    Is everyone using the latest version of the AC plugin?
    Normally if GameManager crashes it spits out some errors.
    This tells me it may be in the plugin itself, then again maybe not. lol
    @value1, any ideas buddy?
    see what we can do :cheers
  12. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    AC gives the error msgs I posted on my first msg.
    GSC gives no error at all.
    They are all the latest plugins.
  13. frenchfly
    frenchfly Member
    Mold Maker
    Winnipeg, Canada
    - 344Coins
    2DOF, JRK
    here's the latest error i got. I was playing gower and glory 3 when this happened, I played assetto corsa for 3 hours without incident before this.
    Problem signature:
    Problem Event Name: CLR20r3
    Problem Signature 01: simtools_gameengine.exe
    Problem Signature 02: 0.1.2.0
    Problem Signature 03: 52e88fe0
    Problem Signature 04: System
    Problem Signature 05: 4.0.30319.18408
    Problem Signature 06: 52311185
    Problem Signature 07: 410b
    Problem Signature 08: 46
    Problem Signature 09: System.IO.IOException
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 4105
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
  14. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    I tried setting the packet rate to 30ms (stopped even quicker) and 1ms, same issue! :-(
  15. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Just tried a dual PC configuration and the Game Manager still closes out at the same time! :-(
  16. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Last test of the night, tried with F1 2013.
    No Game Manager crash for about 10min.
    Then, Game Engine crashed! :-(
    But, that does not seem to be related to the original problem reported here.
    I had the packet rate at 1ms, put it back to 10ms.
    So, looks like the Game Manager crash can be related to the plug in update, indeed.
    Does it help?
  17. bsft
    possibly a bug in AC somehow causing program to crash......
  18. Nick Moxley
    Hoping this gets resolved pretty quick, Not very fun spending 5 min getting things setup to run then have to jump out of seat(freekin seat belts) Unplug and reboot everything. Quite annoying i must say. :mad:
  19. frenchfly
    frenchfly Member
    Mold Maker
    Winnipeg, Canada
    - 344Coins
    2DOF, JRK
    I ran Assetto yesterday with no problems going in and out of the game several times, But the game manager does close on me a various times no matter what game. I'm running jrk's with wiper motors by the way. We all run different hardware so there's lots of variables to consider, but If it is a simtools issue I'm sure they will look into it.
  20. eaorobbie
    20,481Coins
    No issues here on crashing in or out of games. Last run was 4 hrs in 3 different games, Windows 7 64bit.
    Strange one.
