Best method to connect the pot to the motor?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by siantic, Oct 22, 2014.
  1. siantic
    siantic Member
    616Coins
    Hi to all.
    Which is the best method to connect the pot to the engine?
    1. insert the rod of the pot directly into the back of the motor
    2. using a threaded rod into the back of the motor connected to the rod of the pot via a elastic coupling
    Thanks for your help!
  2. Nick Moxley
    Using a Flex Coupler would be the EASIEST Guaranteed way to not transfer the Damaging forces a motor can induce on a pot. Elastic coupling's can actually lead to issues in itself with quick motor movements.
    152,676Coins
    +11,089 / 56 / -2
  4. siantic
    siantic Member
    616Coins
  5. RacingMat
    21,061Coins
    That would have been clearer if you linked the FAQ in your first post indeed. ;-)
    It depends of your motor model! What motor have you got?
    Yours
    Mat
  6. Mazhar Salam
    Mazhar Salam Member
    Melbourne
    907Coins
    mounting the pot to the motor has been bothering me since a while. Actually none of the setup is perfect but all of them is workable
  7. siantic
    siantic Member
    616Coins
    Hi @RacingMat, now i am using 2 motors for wipers (if they'll be weak i'll change them)
    152,676Coins
    +11,089 / 56 / -2
  9. bsft
    heres another idea, use a plastic cut out lever for single turn pot, granted it uses less range, but the pot will not break
  10. siantic
    siantic Member
    616Coins
    yes... i had seen it but i think that it is difficult to create.
  11. bsft
    ok, thats how I started, but what ever works for you
  12. siantic
    siantic Member
    616Coins
    I'm thinking to put the potentiometer on the back of the motor.
    Yesterday i have opened my 2 wiper motor to see where i can drill to put the potentiometer but when i opened it i noticed that there is pcb rear:
    How can i do?
  13. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
    take it out and leave connectors going to the brushes (if they are connected through the PCB)
  14. siantic
    siantic Member
    616Coins
    but for the project the pcb into the motorwiper is needed or not?
    i can remove it?
  15. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
    you just need the two wires going to motors brushes thats all (high speed).
    pcb is there for parking mode(when used on car for wipers).
  16. siantic
    siantic Member
    616Coins
    Hi insanegr, thanks for your replay. ;)
    But there is online a manual/tutorial on how to modify the wipermotor?
    For me is the first project and i don't want to mess :)
  17. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
  18. siantic
    siantic Member
    616Coins
  19. RacingMat
    21,061Coins
    See the brushes:
    go behind the PCB and solder your wires straight on them
  20. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
    @siantic do what @RacingMat told you.
    you have only one speed as you have only two brushes
