Tutorial Monster Moto Shield acts as a single motor driver = more power!
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Pit, May 9, 2014.
  1. CalSim
    CalSim building things
    bacteriology analist
    Spain
    1,310Coins
    DC motor, Arduino, JRK
    No i need to buy a small amp gauge to measure that.
    I'm pretty sure you will draw more than 10A. The driver i used got a bit warm when my first tests, so im sure its gettin 23 amps.
    My 54A 80+Silver was shooting down due to high draw. My new NOX URANO TX 850 has 70A on 12V rail and shouldnt.
    I will look at the chinese MM later, first I want max quality on this rig.
  2. Pit
    30,510Coins
  3. CalSim
    Spain
    1,310Coins
    Ok @Pit , there is no short circuit when dir changes, it works, 1 mm can handle 1 big motor. This is a great new
    Would be possible to plug in pararell 2 moto monsters and double amps? Tested it? just with same wires from ard
    I've burned 2 VHN5019 and 3rd seems to fail...those pololus cant handle this motor. i'm so close to buy 4 of these and forget about the H-bridge in terms of power, before I go to the SyRen 50A or sabertooth big boys.
  4. Pit
    30,510Coins
    There cannot be a short circuit if you have read the specification.
    never tested it. But I imagine that it could work. You must use any fuses to avoid short circuit between the MonsterMoto's if the timing of switching between the poles are different.
    If one mm can handle a big motor why doubling them?
  5. CalSim
    Spain
    1,310Coins
    Why doubling them? because the pololu I've used has "single motor" mode, and it theorically runs 24A constant 60A peak w/o heatsink, basically the same achieved with 1mm on single motor. Just to ensure its posible and have a bigger gap to limits.
  6. Pit
    30,510Coins
    I know the MM are very "sure", if overheating or to much current they are shutting down immediately, that is my experience due to my insane testing using the winches, and they need really much power...
    I suggest you to try out first the "normal" MM as a single motor driver (already 2 VNH2SP30 doubled). This could work so long as they are well cooled.
    Good luck :)
  7. CalSim
    Spain
    1,310Coins
    I'm interested cause you say your winches are 24A, this motor is 23A, and you could set PWMmax to 250 (OMG i have 120)
    My pololu wasnt even warm, its heatsinked.
    Thanks. Trying mm on next
  8. Pit
    30,510Coins
    I never said my winches have 24A...the specs say 120A :), but under full load. The seat + rider result in a load of current ~40-50A depending the "heave" settings and the total weight.
    The MMs will be VERY hot w/o cooling if not cooled they will be damaged (thermal paste, cooler and fan is a must to have)
  9. CalSim
    Spain
    1,310Coins
    Sorry. Bad understanding. You said in message #28 your winches require 25A, thats my fault
    Well, 120A is quite a lot. And just 1 MM moving it. Impressive. You could even set Kp >400 and PWMmax at 250??
    Ordering 4 chinesse mm tomorrow, no more things to think about. I'll try this same config. also ordering a 12v battery.
    My concern now is just the motor, yours is much smaller than mine, and it draws much more power.
    Grear work Pit, and big balls!!! haha :D
  10. Pit
    30,510Coins
    kp is 480 and PWMmax 220. I will show you tomorrow a new video, you won't believe how the rig will (ratter) edit: rattle :grin and shake :)
  11. CalSim
    Spain
    1,310Coins
    <---THIS is a Prague Ratter( 1 of my dogs haha) and it really shakes a lot. I want my actuators to do the same. Lookin forward to that video.
    I'll have a painful waiting time when order the mm from aliexpress
  12. Pit
    30,510Coins
    OMG.. crazy spelling mistake :eek: :D
  13. Pit
    30,510Coins
    Here it is. Do not stop before 2:30...
    Don not wonder about "Surge". It is reverse, so less moving is needed. I suggest to try out this very interesting experience of "pressing" in the seat while accelerating.
    • Old Old x 1
  14. SilentChill
    20,601Coins
    Hi @Pit I have also used the MM as a single driver but I can't get them to work as you have in your final diagram with one side driving negative and one positive it was just shorting out all the time. I have had to wire both up as you had in your original diagram where each side has a negative and positive output.
    I am pushing easily 40 amps without it cutting out and my psu's are only 43amps anyways so all is good.
    Before it was cutting out all the time was really annoying. I will post some pics and a video hopefully as soon as I get my traction loss addition completed.
  15. Pit
    30,510Coins
    This is very dangerous. It works for the moment but a short circuit is more than likely. Please make s photo of the wirings so i can help you to guide through it.
    Good luck, but don't forget you will run into an issue if you will stay where each side has a negative and positive output.
    PS: I have successfully wired 3 MM!
  16. RacingMat
    21,081Coins
    +1 : @SilentChill stick to the specs!
    @Pit : please a picture of the monstruous motomonsters!
  17. CalSim
    Spain
    1,310Coins
    3motomonster hAahaha I can see really big rigs with that.
  18. Pit
    30,510Coins
    This one? Sorry for the spaghetti syndrome :p I would do it better, but so long it works - never touch a running system :). The color wiring is NOT like it should be, the wiring was soldered BEFORE I switched to single mode.
  19. Jymä
    Jymä Member Gold Contributor
    Finland
    184Coins
    Hi Pit. I have the same motors as CalSim and they indeed need a lot of power. I tried them with a 0-10A 12V psu and with no stress a single motor needed about 3 seconds with 10A until it reached full speed and the current started to drop... So I ordered another 12V 47A psu and will try this method of yours straight out.
    But how do you wire 2 Moto Monsters (1 for each motor) to 1 Arduino? Or are you using 1 Ard for 1 MM? And do you use SMC3 MODE1 or MODE2 with that wiring?
    EDIT: I think you just wire the second MM the same way but use Ard 4,5,10 istead of 2,3,9 for first MM? And pot to A1 instead of A0. And still use SMC3 MODE1?
  20. SilentChill
    20,601Coins
    I have wired my MM exactly like this diagram .
    As I said I did do it as in your first post and it did not work so I may try look again but I spent a long time trying to get it working but to no avail.
