Drive System Europe actuators?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Rainer, Oct 13, 2014.
  1. Rainer
    Rainer New Member
    Sweden
    250Coins
    Hi!
    Sorry this is another "can I use these?" thread but at least I introduced myself in the "new here" thread before posting. :)
    I´m looking for actuators for my motion rig but as I´m from Europe (Sweden) I´ll have to pay big $$ for shipping and customs duties if ordering from e.g. mirai or motion dynamics.
    So I´m looking for an altenative in Europe and stumbled across these:
    http://www.conrad.com/ce/en/product...ms-DSAK4-12-50-300-IP54?queryFromSuggest=true
    As far as I know the speed is OK but I´m concerned about the torque and if I´ll need JRK:s or such to control them? Does anyone have experience of using these?
    Sorry for my bad English. Not my first language.
  2. RacingMat
    21,082Coins
    The thrust is 5 kg... it's quite low.
    A smolka motor + 6 cm lever gives = 24kg
    Remind to check speed under load in the pdf and see what you get!
    Beware the "einschaltdauer 15%" is a very low duty factor... probably not suitable for continuous use during 1 hour of race
    yours
    Mat
  3. value1
    14,239Coins
  4. bsft
  5. RacingMat
    21,082Coins
  6. Rainer
    Rainer New Member
    Sweden
    250Coins
    Thanks for the quick replies guys!
    It´s nice to see that forum gods like you still take your time to point noobs like me in the right direction. I salute you!
    The motors that you Value1 linked to look very good. :thumbs
    I want to build a 2 DOF sim like the one in your A to Z thread Mat but with the addition of traction loss.
    I assume the same motor will work for for the TL aswell?
    bsft - Yes, I was planning to use JRKs for just the reason you mention.
    yours
    Rainer
  7. bsft
    yes, same motor for traction loss is fine, you would need a 3rd jrk though.
    Ask as you need to and go hard!
    Dave.
  8. RacingMat
    21,082Coins
    @Rainer You're a lucky guy! there is 25% on JRK for Halloween
    code HW14JRK12v12
  9. Rainer
    Rainer New Member
    Sweden
    250Coins
    That´s great news! Thanks for the information Mat! :cheers I´ll order them ASAP. Anything else I should throw in the cart while shopping at pololu?
    Thanks for both your advice and the 200 coins Dave! :)
  10. Nick Moxley
    USB Cable's if you dont have then.
  11. Rainer
    Rainer New Member
    Sweden
    250Coins
    Thanks Nick! Think I've got some of em lying around the house though. :grin
  12. Lucian
    Lucian Member
    Sweden
    363Coins
    Hello im also from Sweden and i whant or need help with an motion sim rig like simexperince stage 4 so i whant the slide of car rear end. Only the shipping from USA Will cost me 1500 dollars and the total price for stage 4 and theyr seat and the aluminium floor its like 6670 dollars? Can i do cheaper or i need to pay does money?
    And sorry for bad english
  13. Lucian
    Lucian Member
    Sweden
    363Coins
    Im thinking of buying playseat F1 with t300rs so i CAn play ps4 and iracing IF the F1 seat its not good for hours of playing the i buy a normal seat please advice.
    Is IT possible to make 3dof of that playseat rig or i need another rig? I have pre order okulus rift dk2 the t3pa pedals and the rs8 shifter. IF i cant use the playseat please advice what rig seat should i buy? for the begioning i Will Go with one monitor and oculus IF i dont like dk2 il buy 3 monitors. Or IF its not possible to play many hours with dk2
    153,830Coins
    +11,151 / 57 / -2
  15. Lucian
    Lucian Member
    Sweden
    363Coins
    The problem is how hard is it where do i start?
  16. noorbeast
    153,830Coins
    +11,151 / 57 / -2
    Start by having a look at the links I gave, read through their respective builds carefully.
    Go through the FAQ section.
    Assess your own skills and interest.
    Then start your own thread and ask lots of questions as you plan.
    We all started from the same place and are fortunate to have so many experienced members here who make sim building possible for the rest of us.
