My First Motion 3DOF Sim Build...(Advice?)
Discussion in 'DIY Motion Simulator Projects' started by Ben Selph, Oct 29, 2014.
  1. Ben Selph
    Ben Selph New Member
    635Coins
    Great info, thanks! Does each board need a heatsink as well?
  2. Nick Moxley
    Yes they do. Cant remember what page, But i have the actual chip dimension's listed in my thread.
    152,989Coins
    +11,116 / 56 / -2
    My heatsinks are still coming, along with modified alloy mounting boxes for the JRKs.
  4. Ben Selph
    635Coins
    Ok, I've been looking at @rundmg build and I think have a good grip on the basics. My concern at this point is all of the smaller connections. I'm not sure how the metal rods attach to the pot and motors. I can see quite a few bolts and L-joints (sorry if that's not the correct term) and some glue on the top of the motors holding the joint in place. It's the small connectors that I can't quite see from the pics of how they all fit. I'm going to start the base frame build this weekend and am thinking about ordering the jrk boards, motors and pots soon (most likely the same ones from @rundmg build since it sounds like those are decent and quiet). Thanks for all the tips! I'm a little nervous about building this from scratch since I obviously don't want to screw it up and waste the money that I'll spend on parts, lol...I'm just trying to get as much info as possible before I start!
    152,989Coins
    +11,116 / 56 / -2
    There is a FAQ on various ways to connect pots: http://www.xsimulator.net/community/faq/how-to-connect-potentiometer.13/
    Using a coupler of the right size is a pretty easy way to go, if that fits your design and motors: http://www.xsimulator.net/community...f-simulator-conversion.5914/page-3#post-63809
    The bracket that hold the pot should have some give and it is better to attach to and move with the motor, rather than be attached to the frame, as the latter can cause binding and strain.
    Don't forget you can pose a specific questions or put forward an idea before doing anything as you go along.
    152,989Coins
    +11,116 / 56 / -2
    OK I just took these close up front and back shots of how I mounted my pots, which is just one way of many to do it.
    I used 20x2mm flat aluminium mounted directly to the existing back holes in the motor case. I was very careful in getting this bracket spot on and actually made about 6 of them before I was happy that they correctly aligned the pot with the shaft coupling. There are plenty of other ways to achieve the same thing.
    I had originally planned a direct attachment of the pot to the motor shaft, mainly to save space, but changed my mind at the last minute and grabbed a coupling as it allows for some variation and movement if the hole in the shaft is not dead center. Hence I adapted what I had already done in drilling the M8 hole in the shaft to how I needed to connect that to the pot coupling, so it is more complicated than it should have been if I had the correct coupling and planned to use that from the start: http://www.xsimulator.net/community/threads/dx-racer-compact-simulator.5866/page-3#post-63105
    Hope that helps more than confuses, just keep in mind we all tend to adapt a solution to suit ourselves!
  7. Ben Selph
    635Coins
    Thanks @noorbeast, I appreciate you taking the time to take the pics. That looks amazing! I don't have any mechanical equipment to drill into metal so can this be done with off the shelf items from a hardware store?
  8. Nick Moxley
    Coupler's are going to be your best bet Ben. They just clamp on to what ever round shaft you want, like the Pot and Axle bolt. Just get the proper size the first time for your Application.
  9. jem45472
    jem45472 Active Member
    Buffalo NY
    97Coins
    Here's mine. Very easy to setup.
    I used a piece of hose to connect pot to motor. Simple.
    I have since replaced the mounting bracket with a very light gauge aluminum. About the thickness of a soda can. You want the bracket to flex just a bit if it needs to avoid binding the pot shaft as the motor turns. Several of us have broken pots because the mounting bracket was too rigid.
    152,989Coins
    +11,116 / 56 / -2
    Some people have used metal straps common in hardware stores to mount pots, such as these: http://www.bunnings.com.au/pryda-75-x-380mm-nail-on-connector-plate-_p2430027
    The light aluminium I used came from the local hardware store.
    I consider that you really do need a power drill at least when building a sim. I also lashed out a whole $60 dollars and purchased a drill press for my project, which has been invaluable and a great time saver. You could get away without it though, as long as you measure carefully and take your time with a power drill.
  11. Ben Selph
    635Coins
    I'm good with drilling, just not so much the welding or metal cutting.... :) Ok so you just attach the pot to the metal plate and attach the metal plate to the motor. Am I seeing that right? I'm still a couple of weeks out from ordering the mechanical stuff since I'm planning on starting the frame build next week (parts for that should arrive around 11/22).
    Also, what is the difference between mounting the metal rods to the seat vs. mounting to a base that the seat sits on? I don't think I want to put holes in my new seat if possible but wondered if there was a big difference between the two types of setups? Thanks again!
  12. bsft
    Yes more or less, I used some metal strap, bent it , lined up where the pot needs to go, drilled the hole a bit bigger than the pot shaft size, bolted the pot to that, and araldite glues the strap to the top of the motor housing.
    As for your next question, perhaps you could draw something on paper, and put up a pic so I can get a better idea.
  13. noorbeast
    152,989Coins
    +11,116 / 56 / -2
    A sketch as @bsft suggested of what you have in mind would really help.
    Yes there is a significant difference in layouts for motors and rods, with a shoulder mount perhaps being the most straightforward. But different designs can be made to work, which @bsft and others have explored through various builds.
    Your planning picture does not need to be fancy, just a quick idea of what may suit yourself and then everyone can chip in with tips and ideas about the pros and cons, plus add potential solutions.
  14. Ben Selph
    635Coins
    Ok I received a few parts for the frame and should have completed over Thanksgiving weekend. I'll upload some pics when done. FYI that I'm actually going to build three of them for my fam with the center rig being the only motion rig for now (which will be mine of course :). Quick question on SimTools: Are the 'plug-ins' preset values for each sim game that I just add to the game somehow or do I need to hand-tool every field for every sim myself? The SimXperience SimCommander tool looks more user friendly but I don't want to be stuck with only the sims they support. Are there any other differences between SimTools and SimCommander?
  15. bsft
    You will need to change tuning centre numbers to suit how you like each force.
    Because there are so many variables for each persons ride, every setting is different .
    Bernards software is set because he uses the same equipment all the time
    Have a look at this doc
    http://www.xsimulator.net/community...-set-up-simtools-jrks-and-write-profiles.112/
    its for ver 1.2, but explains how to do each force and setting to get a profile right.
  16. Ben Selph
    635Coins
    What are the "plug-ins"? Are they pre-tuned profiles that you can plug into current sims?
    152,989Coins
    +11,116 / 56 / -2
