Actuator w/ Feedback for Traction Loss
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Pit, Jun 12, 2014.
  1. Pit
    30,499Coins
  2. yobuddy
    51,239Coins
    At 8mm/s it could only simulate a slowly leaking tire. hehe
    0.3 inch a second is way to slow I'm afraid.
  3. Pit
    30,499Coins
    LOL, you are completely right :)
    Here the right link: http://www.gimsonrobotics.co.uk/GLA-S_linear_actuator.html
    Faster but w/o feedback. So I think I can delete the thread....
  4. RacingMat
    21,061Coins
    @Pit : you can add feedback with a pot on the pivot :) rather than on the actuator itself
  5. yobuddy
    51,239Coins
    they don't look fast enough either.
    ~.75 inches a second - just a faster leaking flat tire. hehe
    • Funny Funny x 3
  6. yobuddy
    51,239Coins
    For example a scn5 actuator runs at 400mm/sec max. speed.
    A scn6 actuator runs at 200mm/sec max. speed.
    So something in that range of 200 to 400 mm/sec is what you are looking for.
  7. Pit
    30,499Coins
    ok ok. I got the message :) Probably those actuators won't be cheap so I could delete this thread once again :p
  8. eaorobbie
    20,488Coins
    AH under load the SCN5 struggle to push 200mm/s but still damn quick. With the extra torque of the scn6 they push between 100-150mm/s underload.
    I would use a dc motor like others have done , looks impressive with plenty of speed.
    Mines a little way off but have all the components just need to finish a couple of my outstanding projects first then I can play again.
  9. moon310
    moon310 Member
    615Coins
    2DOF, 3DOF, DC motor
    I bought the same Linear Actuator But very slow
    Is it possible to increase the speed of
  10. moon310
    moon310 Member
    615Coins
    I can Removing the motor cover and gears
    But how do we increase speed
  11. eaorobbie
    20,488Coins
    Test the output speed of the motor you removed, then source a motor that is faster.
    Another I have seen done (good old YouTube) a pully was attached to one end of the actuator and another on a high speed dc motor, see you don't need much torque to turn a ball screw setup. But plenty of input speed to gain a nice and fast motion, but there is a physical limit the actuator will handle too.
  12. moon310
    moon310 Member
    615Coins
    Fantastic
    The same image
    Is it enough speed For simulation
  13. bsft
    if the motor is fast enough to move the actuator shaft, then yes.
  14. moon310
    moon310 Member
    615Coins
    understand
    Thank you
  15. bsft
    I converted some actuators I was given by chance a while ago.
    Mind you, they are fast in the first place and industrial strength. I just had to re-motor them with 12v motors.
    I use 4500 rpm motors, 1:1 drive
    and then do a custom feedback setup to suit the motor controllers, in this case, the JRK
    initial test
    link to current build they live on
    http://www.xsimulator.net/community/threads/actuator-2-dof-seat-mover.5065/
    • Like Like x 5
  16. tronicgr
    tronicgr
    Like for using x-sim motion software for the video!
    • Funny Funny x 2
  17. riton
    riton Active Member
    1,006Coins
    Before you say 400 mm / s for a SNC, you need to look like the torque fall with the load and speed too !!
    must watch manufacturer curve!
    and think about removing power to the load inertia!
  18. eaorobbie
    20,488Coins
    Agree @riton I have used a local simX unit was not impressed doent kick as hard as my DC motors (about 200mm/s) owner then came over and had a play on my unit and offered straight away to do a swap, sorry keep ya 20k of crap, sorry mate. His selling the stage 1 kit off the full rig and converting to Dc motors and SimTools , was very impressed.
  19. ericRacer
    Pilot
    Canada, Quebec
    952Coins
  20. SeatTime
    Just be careful, the cheap actuators rarely use a ball screw, they normally use a 'acme lead screw' which is allot cheaper and nowhere near as efficient.
