value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. iamcanadian2
    iamcanadian2 Member
    floating docks
    surrey bc canada
    90Coins
    Motion platform, 6DOF
    So I've been playing around with NL2 and well its hard to get some movement . I get some shaking and back and forth but not so happy so far. I know I have the AMC 1280 set up because in FSX with Ians BFF software I can get the simulator to stand on its head . Now for the life of me I cant find the "Tuning center"? My heave doesn't seem to make any.
    from what I have read there is no such thing as pitch or roll in NL2. That's what I need to make this thing feel real. Side to side is better than nothing but Pitch not going to happen or is there something a person could do. Attached is my setting in the interface and axis. any suggestions I'm all ears! Anybody else using Thanos MAC1280 ? 20141122_173043.jpg 20141122_175301.jpg
  2. value1
    14,236Coins
    @iamcanadian2
    Please show a screenshot of your Tuning Centre.
    (Right-click on the GameEngine icon in the system tray and select Tuning Centre)
  3. jem45472
    jem45472 Active Member
    Buffalo NY
    97Coins
    No limits 2 is being released Wednesday with oculus rift support! I can't wait.
    Between motion, shakers, and oculus this is going to be some serious fun!
  4. iamcanadian2
    iamcanadian2 Member
    floating docks
    surrey bc canada
    90Coins
  5. benj
    benj Member
    44Coins
    No Limits 2.0.8 has been released :D And is also on sale right now if anyone wants it a bit cheaper. Oculus support baked in, can't wait! Hopefully you magic guys can get the plugin update to work with this new update soon :cool:
  6. SilentChill
    20,601Coins
    Hi @value1 , Ive patched the plugin says it installed ok but I have nothing happening. I have looked into the install directory and there is no plugin in there ?? Anyone have the same problem ?
    I had it installed by Steam would that make any difference ?
    E:\SteamLibrary\SteamApps\common\NoLimits 2\ this is my install directory I am pointing the patching at
  7. Blame73
    Blame73 Well-Known Member
    8,313Coins
    Does the plugin work with the demo too?
  8. value1
    14,236Coins
    @SilentChill
    Hmm... I wasn't aware of a steam version :(
    As this is a memory hooked plugin, it might not work with the steam version.
    I could teach you however, how you can track down the right memory address, you let me know that and I amend the plugin with the address you found.
    What about that?
  9. value1
    14,236Coins
    RTFM
  10. SilentChill
    20,601Coins
    @value1
    Im making a right mess of this lol
    It was the demo I was trying fgs .....
    I dunno its doing me tree in lol
    Yes I would like to try and get it working if you can tell how to get the memory address I can follow instructions :) Show me the way sir !!
  11. value1
    14,236Coins
  12. SilentChill
    20,601Coins
    @value1 ahaaaaa you are the man !!!! I didnt even notice the version difference I will give it a try now .
    Thanks again :)
  13. SilentChill
    20,601Coins
    @value1 I have just tried but its not detecting the game when I load it, is that because the steam version has a different process name it is nolimits2stm.exe instead of nolimits2app.exe
    Other than that I don't know ??? It picks the demo up ok as soon as I launch it but motion doesn't work as it isn't patched but obviously it recognizes the process name.
  14. value1
    14,236Coins
  15. SilentChill
    20,601Coins
    @value1 wow that was quick thanks !! yes it picks it up now ..........but then the dreaded pop up window "Motion not Supported"
    What a bummer lol
  16. value1
    14,236Coins
    @SilentChill Thank you for testing!
    Ok, I will let you know tomorrow, how we can fix this together :cheers
  17. SilentChill
    20,601Coins
    @value1 thanks a lot :)
    Just to let you know the demo works fine so it has to be something to do with the steam version.
  18. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    The non-steam version works fine for me!
    Mike:thumbs
  19. value1
    14,236Coins
    @SilentChill
    So this is how you can find the g-forces in NoLimits:
    Download and install CheatEngine.
    Don't select just "Express" installation but choose wisely! ;)
    Start CheatEngine
    Start NoLimits 2 Roller Coaster Simulation in Steam
    Switch back to CheatEngine and click on the Select a process to open button
    This opens the Process List window where you select nolimits2stm.exe and click the Open button which closes the window ;)
    In CheatEngine under Value Type select Float, under Scan Type select Value between…
    Enter the values 0.6 and 0.8 in the Value boxes
    Switch back to NoLimits 2 Roller Coaster Simulation
    On the start screen click on Setup.
    In the Display tab uncheck the Fullscreen box, click on OK and confirm
    Start now the simulation with Play and select the "Wildernes Park" and click OK.
    Once the simulation has loaded, press F2 to show the simulation window.
    Wait until the coaster is in the lift area and the Vert. G-Force shows 0.7
    Click on First Scan and then a few times (10×) on Next Scan.
    Change then the search values from 0.6 - 0.8 to 0.9 - 1.1 and wait until the coaster is on the peak and the Vert. G-Force shows 1.0
    Click on the Next Scan button a few times (10×) again.
    When the coaster approaches the edge, change the Scan Type to Bigger than… and type in the value field 1.1
    When the coaster descends, the Vert. G-Force will quickly reach values well above 1.1 g. When you see such values in the simulation window, click on Next Scan.
    Should there be more than 1 single remaining addresses, click on Next Scan again when the Vert. G-Force is well above 1.1.
    Now double-click on this address to add it to the observation window of CheatEngine.
    Press New Scan and select Value Type 4 Bytes, Scan Type to Exact Value, check the Hex box and enter the address you found into the value box. Replace the last "8" with a "0" and click First Scan.
    There will be one green address in the Address window. Click on the Add Address Manually button and add the address 1405A0000.
    Take a screenshot and post it here.
    • Informative Informative x 6
  20. SilentChill
    20,601Coins
    Hopefully I have done it correctly :) Looks like same address to me ?
    Thanks again for your time and help @value1
