3Dof sim
Discussion in 'DIY Motion Simulator Projects' started by Lucian, Nov 6, 2014.
  1. noorbeast
    153,770Coins
    +11,150 / 57 / -2
    Sorry my mistake there @Lucian I should have looked closer at the pictures you posted.
  2. bsft
    Yes @Lucian , if you are moving the seat, and it is balanced, then you are done.
    The rest of the frame is static
  3. Lucian
    Lucian Member
    Sweden
    363Coins
  4. Lucian
    Lucian Member
    Sweden
    363Coins
    How CAn i remove that round thing to rotate that white thing?
  5. Nick Moxley
    Just yank UP on that Big white gear, the whole gear and bearing's should pop out from the case, then just flip the gear. If its a little tight, Hold the gear box upside down and give the other side a tap with a screw driver or something. It should't be All that tight in there.
  6. dave w
    dave w Member
    Minnesota USA
    1,068Coins
    [​IMG]I would recommend locating a bearing separator (see above), since the plastic gear is already damaged this is your best bet to get the bearing off without damage
    or use a jaw type puller (see below)... this style is more likely to cause damage to the bearing but should get it off of the shaft
    Here in the states our local auto parts stores rent these tools for free, not sure about Sweden, good luck!
  7. Nick Moxley
    Good idea but Total overkill dave, No need for a puller. The bearing's are just a press fit and are easily removed.
    PS what damaged gear ?
    PPS where in MN are ya. I do a bit of RC racing down in Foley/Staples in the summers.
  8. dave w
    dave w Member
    Minnesota USA
    1,068Coins
    Nick never had a motor apart, appeared to be pressed wasn't sure how tight a tolerance :)
    I'm in the Twin Cities
  9. Nick Moxley
    Ya they aren't very tight. And he also doesn't need to remove the bearing's at all, Just flip the gear. Bearing's And all.
  10. Lucian
    Lucian Member
    Sweden
    363Coins
    Yepp did that Done and done ty
  11. Lucian
    Lucian Member
    Sweden
    363Coins
    The Rod is 47,7 cm
  12. Lucian
    Lucian Member
    Sweden
    363Coins
    CAn i make the red and black cable from the motors longer or its not recomended?
  13. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    you can extend the cables if you want with at least the same awg.
    my opinion is having shorter cables as you can
  14. bsft
    Yes, I think I extended mine about double the length and I used a slightly smaller gauge cable to it would fit in the terminals of the control board.
    It will not affect the overall power.
  15. Nick Moxley
    Ideally you want 14Awg wire, Its what the JRK connector is listed for, Or if you want to use something that maybe isn't listed in Awg sizes. anything from 1.3mm to 1.6mm in diameter.
  16. Nick Moxley
    How stiff are those brackets Lucian ? If you push Sideways on them, Do they move ? As in push from the Pot side and the lever side.
  17. dave w
    dave w Member
    Minnesota USA
    1,068Coins
    brackets look a little thin, I think I could ninja kick those off! :)
  18. dave w
    dave w Member
    Minnesota USA
    1,068Coins
    I would recommend at a minimum doubling them up and using nuts and bolts with a backing plate if "L" brackets are all you got
  19. Nick Moxley
    We can also Lower the motor's which will take off some leverage on the Brackets.
  20. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    IMHO, I would look at the shafts (w/heims) from motors to back of seat - under "load", there may be some undesirable flex...
    Nice project.
    Tom
