value1
City Car Driving Plugin 2.0.8.3
SimTools game plugin for City Car Driving
  1. value1
    14,239Coins
    City Car Driving Plugin - SimTools game plugin for City Car Driving
  2. Uros
    Uros New Member
    265Coins
    2DOF, SCN6
    What is new in latest Update?
  3. value1
    14,239Coins
    CCD has recently been updated to V1.4
    So I thought I better update the plugin as well.
  4. Uros
    Uros New Member
    265Coins
    2DOF, SCN6
    OK, i understand that, but is any difference, in plugin itself? will old one work fine with v1.3?
  5. value1
    14,239Coins
    Yes, the plugin works with both City Car Driving V1.3.3 and V1.4
  6. value1
    14,239Coins
  7. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    hello,
    I can not run this game with the simulator. I wonder if this is not a record of the problem when patching. What folder did you choose ?
    My simulator works correctly only yesterday, ELITE DANGEROUS and ASSETTO CORSA are good. :(
    (bonjour, je n'arrive pas à faire fonctionner ce jeu avec le simulateur. je me demande si ce n'est pas un problème de dossier au moment du patching. Quel dossier avez-vous choisi ?
    Mon simulateur fonctionne correctement depuis hier seulement, ELITE DANGEROUS et ASSETTO CORSA sont bon)
  8. value1
    14,239Coins
    Hi @leaedman
    These plugins (memory hooks) are extremely sensible to the game version.
    What exact version of City Car Driving are you running?
    (and please check, that there are no weird settings for City Car Driving in the Axis Assignment of GameEngine
    Axis Settings CCD.png )
  9. leaedman
    470Coins
    thank you value1
    I use version 1.4 (it is a legal version purchased). I will control again tonight settings such as the screenshot :thumbs
    (J'utilise la version 1.4 (c'est une version légale acheté). Je controlerai à nouveau ce soir les réglages comme la capture d'écran)
  10. leaedman
    470Coins
    I still can not. Here are my settings on Game Engine :
    For Game Manager I selected the "Forward Development" folder. I also tried the "City Car Driving Home Edition" folder. I made a mistake somewhere? :think
  11. leaedman
    470Coins
    I really do not get to run this plugin. Can anyone share his setup or display personal values to compare? Thank you :(
    Otherwise: Assetto Corsa, Elite dangerous, WRC 4 Grid autosport, RRRE work perfectly with SIMTOOLS.
    (Je n'arrive vraiment pas à faire fonctionner ce plugin. Quelqu'un peut partager son setup ou afficher ses valeurs personnelles afin de comparer ? Merci
    Sinon : Assetto Corsa, Elite dangerous, WRC 4, Grid autosport, RRRE fonctionnent parfaitement avec SIMTOOLS.)
  12. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    I tried to download the plug-in but the download is not available is not my problem or plugin?
    thanks
  13. noorbeast
    153,836Coins
    +11,151 / 57 / -2
  14. leaedman
    470Coins
    Please spyderwash, you can confirm that the plugin works with you when you have installed?
    I never got it to work :sos
    _____________________________________________________________________________________________
    S'il te plait spyderwash, tu pourras nous confirmer que le plugin fonctionne chez toi quand tu l'auras installé ?
    Moi je n'ai jamais réussi à le faire fonctionner
    :sos
  15. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    ok realized I thank you for the coins you're too kind
    I hope to use simtools good to help other people
    thanks
  16. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    just I can not finish the configuration of the engines say if it works, the next few days
  17. leaedman
    470Coins
    OK, thank you spyderwash :thumbs:cheers
  18. noorbeast
    153,836Coins
    +11,151 / 57 / -2
    I can confirm the City Car Driving plugin works.
    Sorry somehow I missed this earlier when you posted it @leaedman. Unlike most other driving simulators City Car Driving only supports pitch, roll and yaw axis, as per here: http://www.xsimulator.net/community/marketplace/city-car-driving-plugin.117/
    So what you have set below will not work, please try again with pitch, roll and yaw instead:
  19. leaedman
    470Coins
    Ahhh ok !!! thank you noorbeast :cheers
    I did not understand. I test tonight !
  20. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    I've tested CityCarDrving last night but I've no data. Alreday patched game.
    I've game version 1.4.1 and plugin version 1.0.0.4
    Any suggestion?
