Resolved asseto corsa dont work
Discussion in 'SimTools Plugins' started by leonaikikai, Jan 2, 2015.
  1. leonaikikai
    leonaikikai Member Gold Contributor
    85Coins
    Hi all, i have a problem with asseto corsa
    i have the lasted version of simstool v1.3 and the last plugin for asseto and i patch the good directorie : c/programefiles/steam/steamapp/common/asseto
    i play with dirt3,F1 2013,Grid2 wihtout problem
    thank you for your help and i'm sorry for my poor english
    Leonaikikai
  2. value1
    15,082Coins
    How do your axis assignments look?
  3. leonaikikai
    85Coins
    thanks for your speed but i tested with your value but the game dont start with gameengine et gamemanager
    but i have one question : the name of the plugin is asseto corsa EA but my game is only asseto corsa with steam
    so i think i dont have the good plugin
    thank for your help ;) Value1
  4. value1
    15,082Coins
    "Asseto Corsa EA" is the right plugin. Used to be "Asseto Corsa Early Access" and I haven't changed the game title yet. It works with the Steam version. (I think there is no other version anyway.)
    Can you try to repatch the game?
  5. leonaikikai
    85Coins
    I have patch the game tree time , i have uninstal and instal simstool on my pc ( i have on pc for the game and a laptop for game engine and i have no problem with another game)
    say me if you have the same directorie for the game and say me if it's a problem if my pc(for the game) is not connected to internet or à problem with the firewall
    tomorow i reinstall asseto corsa by steam but i'm not sure that the problem
    thank you very much
  6. value1
    15,082Coins
    "…\Steam\SteamApps\common\assettocorsa" is the right path.
    Please run the Windows Task Manager (with Ctrl-Alt-Del) and check the name of Assetto.
    Under "details" you should find a entry acs.exe.
    Can you confirm?
  7. leonaikikai
    85Coins
    when i launch the game and make taskmanager i dont see acs.exe but i see acs.exe in the file of directory of the game
  8. Nick Moxley
    You have to be On track for the acs.exe to be present. Sitting in the menu doesn't do it. weather thats the problem or not, Not sure.
  9. leonaikikai
    85Coins
    ok i go check this but the problem is that game engine and game manager dont change color (to the blue) when i launch the game asseto corsa
    with onother game , game engine and game manager change color (go blue)
    thank for your help
  10. bsft
    have you updated the game recently and downloaded all DLC? Did you try deleting the plugin and then re-installing, and also actually using the current plugin.
  11. value1
    15,082Coins
    They do not turn blue, even when you are in a race?
  12. bsft
    alt tab for AC is a bitch, you sort of have to press tab a few times to get the desktop showing up a bit like an overlay on the game
  13. leonaikikai
    85Coins
    Big thanks guys , asseto run i dont understand that the simu work only in race so i'm sorry .
    thank you very much for your speedy help :thumbs:thumbs:thumbs
    Somebody staffmember can put this thread Resolved please ;)
    Leonaikikai
  14. Nick Moxley
    Both my Machines Do Not require this. Must be your machine specific.
